View Full Version : Darin's Method for Making Paralelling Adapters
Darin Jordan
06-09-2016, 09:28 AM
Thought I'd share my method of making Paralleling Adapters. These are made with 5.5mm contacts from, where else? OffshoreElectrics.com.
I use Copper Tubing to provide a solid joining of the three contacts.
I drill an appropriate sized hole all the way through the middle contact, and just through one side of each of the outside, then press them together.
143851
143852
Then I solder them together, filling in the wire barrels as well, and cover with heat-shrink. Pretty basic. Seem to work very well.
143853
143854
143855
shua
06-09-2016, 09:59 AM
A very simple and most helpful post!
I would never have thought of the copper tube to aid in soldering and making a stronger assembly.
Thanks!
T.S.Davis
06-09-2016, 10:24 AM
I made some similar for 8mm connectors but I used solid copper grounding wire in a huge diameter. Nearly filled the 8mm sockets.
Darin Jordan
06-09-2016, 10:28 AM
Yes. I really wasn't thinking of the copper as "the" conductor... just "a" conductor that helps hold things together. The solder, and touching contacts, are what I was after. Just after making a few of these with JUST the contacts, I got tired of fighting the soldering! One could easily do the same thing with just wire between them.
Been using these for a couple of seasons now and they seem to work really well. Bench testing shows them to have all the conductivity that I'm after. ;)
T.S.Davis
06-09-2016, 11:20 AM
I always wondered about that. I use Stabrite so as much silver as I can get but still am relying heavily on solder to conduct. I don't think of solder as the best conductor.
I've used actual strand wire too. Sure makes it easier to plug in some of these monstrosities I have going with a little flex.
longballlumber
06-09-2016, 11:52 AM
While I understand why these adapters are popular and the standard set-up for 2P configurations, I have adopted splicing 2P wires onto the controller (pigtail). Much easier to solder and you eliminate and extra connectors sets. I don't have a picture, but it's work great even on my P-Limited boats that use OEM Aquacraft controllers.
don't need 2P but need the controller, I simply secure and cap off the extra connections with rubber protector boots.
Just another way to skin the cat. :cool2:
langevn
06-09-2016, 12:12 PM
Do you sell the if so how much
Sent from my SGH-I337M using Tapatalk
zooma
06-09-2016, 01:50 PM
What size heat shrink tubing? From where?
Darin Jordan
06-09-2016, 02:36 PM
It's standard 3/8" heat-shrink (like what comes from OSE with the contacts). I use a pair of needle-nose pliers up inside it to stretch it open wider to fit over the larger section. There are smaller pieces over the individual female contacts, and I double layered the black over the larger section.
T.S.Davis
06-09-2016, 04:05 PM
Tom does his that way too. So much easier to deal with and less resistance to boot.
Darin, try this stuff some time. It's silicon with no glue. Stick to itself and has a higher melting point than shrink tube. I use it on everything sparky.
http://www.uline.com/BL_6422/Silicone-Self-Fusing-Tape?keywords=Silicone%20Tape
Shooter
06-13-2016, 07:55 PM
Cool! Thanks Darin!!!
