wickedgmc
10-27-2008, 09:41 PM
I bought this to run in a super crawler I was going to purchase, but decided to power the truck with 2 motors and 2 esc's so this one needs to go. It is new in the package unopened. I am selling this here for 115.00 shipped in the USA.
http://i235.photobucket.com/albums/ee276/MPValentine/IMG_5084.jpg
http://i235.photobucket.com/albums/ee276/MPValentine/IMG_5085.jpg
The following specs are from Novak
SUPER DUTY XR SPECIFICATIONS
Input Voltage: 6-14 cells (1.2 VDC/cell) [Forward/Braking/Reverse] or 2-4S Li-Po when used with Novak Smart-Stop Li-Po Module (#5470, #5471 or #5472)
Footprint: 1.75” x 2.17” (44.5 x 55.1mm)
Motor Limit
# Cells Single Motor Dual Motors in Parallel
6 cells (7.2 volts) None 10 Turn
10 cells (12 volts) None (550 Size Only) None (550 Size Only)
12 cells (14.4 volts) None (550 Size Only) 12 Turn (550 Size Only)
14 cells (16.8 volts) None (550 Size Only) 12 Turn (550 Size Only)
On-Resistance: 0.0011 ohms (Forward)
Rated Current: 400 Amps (Forward) @ 25°C MOSFET Temp.
Braking/Reverse Current: 180 Amps @ 25°C MOSFET Temp.
BEC: 6 Volts/ 3 Amps
Maximum Discrete Steps: 512 (256/Forward, 256/Reverse)
Motor/Battery Wire: 14 Gauge
SUPER DUTY XR FEATURES
100% Digital Microprocessor-controlled
3 Throttle Programs
Ideal for Dual Battery Packs
Gold-Plated PCB Direct-Solder Wire Tabs
Smart Braking II
Gasket Protection
Power Output for 5-Volt Accessory Fan (#5646)
Reverse Disable (Program #2)
25% Reverse & Brakes (Program #3)
User-replaceable Input Harness
One-Touch Set-Up
Radio-Priority Circuitry
Polar-Drive Circuitry
Thermal Overload Protection
Digital Anti-Glitch Circuitry
Motor Limit
3 Throttle Programs
Smart Braking II
Gasket Protection
One-Touch Set-Up
