View Full Version : f1 hornet
steve1a
04-09-2016, 08:25 AM
Hi any body no how to go about mounting a probat stelleto outboard leg .on to a hobby king f1 hornet. what to use for mount .any help thanks Steve.
Beaux
04-18-2016, 09:29 AM
hello and welcome. I used a prather style adjustable mount. on my k&b lower unit to mount to my hornet. offshore electrics sells different mounts . i got mine from mecoa off ebay. check with ose you can e-mail steven and he'll help you.
Beaux
04-18-2016, 09:30 AM
ose even sell the proboat outboard.
steve1a
04-23-2016, 05:09 PM
yes they do have one. emailed Steven at ose . for info on mounting a proboat outboard leg to f1 hornet. said to check forum. there is a you tube video on one but can,t see how it,s mounted. the outboard that comes on the hobbyking f1 hornet is junk.so i have heard . can,t get flex shaft for it, so went ahead and picked up a proboat out board leg. just trying to figure out how to mount it. has any one done this if so please let me no what you used to mount it.
Beaux
04-23-2016, 06:18 PM
hey steve, what are you having a problem with?
Beaux
04-23-2016, 07:42 PM
Steve if you'll let me know what you need I still have a stock hornet and one with a K&B leg on it I'll take it a part and send you pictures.
steve1a
04-24-2016, 06:05 AM
Beaux i picked up a k&b mount .not looking like it will work to mount proboat outboard leg.are you useing a proboat outbord leg. if so do you have a pitcher how you mounted it to the back of boat.or no what to use thanks.
Beaux
04-24-2016, 10:38 AM
ok Steve, I have some pictures for you.
142650142651142652142653142654
Beaux
04-24-2016, 10:53 AM
This is how I did mine with the prather mount on the inside where the wood is that the mount screws to, you either need to put a thicker piece of wood or a couple layers of fiber glass and longer screws. I just put two more layers of fiber glass on mine and used nuts and bolts. The bottom two screws are a pain to get in, and you may have to re-drill a few holes to make the connection. Be sure to fill the holes where your stock motor screwed or it will leak. I've two of those motors one cable lasted about six good runs one cable is four or five years old. Just don't put an expensive prop on because when the cable breaks you lose it all. I hope this helps, if you need anything else please ask and run that stock motor till it breaks. Asyou will see you only need one steering rod.
142655
steve1a
04-24-2016, 04:36 PM
Beaux thank you for the pitchers.what outboard leg is that.
Beaux
04-24-2016, 08:10 PM
It's a K&B 3.5 with a 3650 leopard 2930 kv. The mount is a prather 3.5. If you need anything please ask good luck.
Beaux
04-26-2016, 09:11 AM
Just thought I would share a picture of my f1 hornets with you.
142675142676
steve1a
04-26-2016, 04:34 PM
Nice thankyou
Beaux
05-15-2016, 06:22 PM
Hey buddy, how's the hornet coming?
steve1a
05-29-2016, 08:37 PM
Hi haven,t had much time to work on it. with over time at work will be soon.,
Beaux
05-30-2016, 03:15 PM
When you do get back on it, I found the servo mount to be weak. I glued all the way around the inside of the box where the flat piece attaches to the wall and glued a 1/4 inch piece along where the two front servo screws are, it helped a lot.
