View Full Version : Delta Force Sniper 45" (no name yet)
gixx1k2
02-26-2016, 06:48 PM
I'm getting started on my DF Sniper build for SAW T-mono class. Will be using Speedmaster hardware with flooded tube for max adjustment, will be powered by single LMT 3060/7 and MGM 40063. Motor mount and cooling jacket from Dave at HRC, Dave is making a custom ESC plate to mount the massive MGM above the motor. I've already did some reinforcing with coremat and will be starting the inlay this weekend. :rockon2:
srislash
02-26-2016, 10:59 PM
Nice. Did the strips of core matt stiffen it much? I have some here but haven't used it yet.
gixx1k2
02-27-2016, 12:23 AM
Yes it works well, but it soaks up quite a bit of resin. So if you're trying to keep it light I would recommend using sparingly :beerchug:
gixx1k2
02-28-2016, 09:21 PM
Got part of the inlay done last night, working on the sides this evening. What a PIA it is with these rails
gixx1k2
03-07-2016, 12:26 AM
Inlay is finally done, and drilled holes for the strut and trim tabs. Waiting on the servo mount before I drill for the rudder. Next I'll be making a transom doubler to strengthen it up a bit.
gixx1k2
03-13-2016, 10:46 PM
Well the motor finally showed up, I got it mounted in the HRC mount along with the HRC cooling can. Mounted the servo and rudder, also drilled a huge hole in the hull for the flood tube. Also got started on the stuffing tube, I epoxied it into the flood tube and will also epoxy from the other side as well for added strength. I don't want it to move when adjusting the strut
Mxkid261
03-13-2016, 11:14 PM
What speeds are you shooting for and on how many cells on this one? Just out of curiosity
gixx1k2
03-13-2016, 11:36 PM
Will be running 10s, as far as speed goes hopefully fast enough to take the T-mono SAW record for IMPBA. So mid 90's would be great :thumbup1:
Mxkid261
03-14-2016, 09:23 AM
Very cool get some videos when its finished :cool2:
gixx1k2
03-14-2016, 01:00 PM
Absolutely. It's almost time to get the boats in the water, the ice is gone for good. :rockon2: hopefully lol
gixx1k2
03-17-2016, 08:55 PM
Working on getting the motor mounted along with the flood tube
gixx1k2
03-20-2016, 06:56 PM
Got some work done on the ESC mount and battery tray, man it was a long day and seems like I didn't do much lol. The batteries will tuck up under the ESC nicely.
gixx1k2
03-28-2016, 09:28 PM
Got a little work done this weekend, flood tube is now permanent, steering is all set, mounted the strut,rudder, and trim tabs. Still working on the Esc mount hopefully have that done shortly.
gixx1k2
03-29-2016, 02:02 AM
Esc mount is complete, got the Dzus fastener brackets installed, the Esc is mounted to the mount via standoffs with rubber o-rings to dampen the vibrations, getting the motor wires shortened up now. Hoping to have the plumbing done next weekend
gixx1k2
04-07-2016, 02:28 AM
Hatch bolts done and had to throw a makeshift windshield on her. Ready for the maiden run and hopefully not at the SAW event in a couple weeks. Lol
rayzerdesigns
07-04-2016, 10:11 AM
How did it run?? Any videos
Beaux
07-04-2016, 01:32 PM
Looks sharp.
Punisher 67
07-16-2017, 11:18 AM
A little glimps of what to expect
https://www.youtube.com/watch?v=4l1ZOcnjbIs
https://forums.offshoreelectrics.com/showthread.php?26369-Sniper-build-ll-quot-PREDATOR-quot
07-16-2017, 11:31 AM
Year-old thread. I expect the OP has already run it by now - but he hasn't been on-site for 8 months. :wink:
Punisher 67
07-16-2017, 12:11 PM
You are so right ....... not enough coffee this morning didn't notice the post date.....:laugh:
