View Full Version : 33.5 CARBON KELVAR mono deep V build finished, waiting for your comments, advices
tuncd
02-13-2016, 02:32 PM
[33.5 carbon mono deep V, Leopard 4082 1600 kv, Turnigy 180A, HD Power 20 Kg. servo, 45 mm prop, 2x3s 70c revos. waiting for your comments and advices. Any Q. welcome.By the way, I have a RTR boat which is surge crusher (upgraded motor and esc), I had an other one and sold it, but this is my first built by my own.....
140900140901140902ATTACH=CONFIG]
kfxguy
02-13-2016, 02:33 PM
Nice. I like that hull. What is it?
tuncd
02-13-2016, 02:41 PM
140907140908140909140905140906
tuncd
02-13-2016, 02:50 PM
140910140911140912140913140914
tuncd
it is from ebay, no name.
tuncd
02-13-2016, 02:54 PM
140915140916140917140918140919
tuncd
02-13-2016, 02:58 PM
140920140921140922140923140924
tuncd
02-13-2016, 03:06 PM
140925140926140927140928140929
tuncd
02-13-2016, 03:09 PM
140930140931140932140933
dmitry100
02-13-2016, 04:04 PM
tuncd: Nice boat. Love the carbon look. BTW... Where did you buy those T-Nuts for hatch ?
tuncd
02-13-2016, 04:56 PM
From HK. You may find all diameters.
785boats
02-13-2016, 05:14 PM
Nice build.
one thing that concerns me though, is that there is only one screw in the sides of the motor mount & I can't see anything holding the rear of the motor in place. It may just be the photos. But if there is nothing supporting the rear of the motor it will start to move up & down, especially in a hard tumble, & will probably break the flex at the stuffing tube.
I've got one waiting to be built up for our EA class racing. Just haven't got around to it yet.
Bought mine online from 'dymotorshop'.
tuncd
02-13-2016, 05:20 PM
Nice build.
Same shop I bought. exept rudder and prop (TFL) all hardware from that shop. I made only a mistake I didnt place the shaft saver in to the stinger all the way.
But there is no leaking in the hull even a drop.
tuncd
02-13-2016, 05:39 PM
Nice build.
You are realy watchful. I had to move out rear support because of water jacket lenght. I was wishing to order shorter water jacket for the motor and reinstall rear support. Do you think that I really do this immediatelly?
785boats
02-13-2016, 09:09 PM
Yes.
The single bolt in the side of the motor mount will not hold the motor steady. It will become a pivot point.The motor angle must stay in line with the flex shaft coming out of the stuffing tube or the whole thing can fly to bits.
You can of course leave the water jacket & just bolt on or glass in a couple of brackets to the rear of the motor mount further back so that the tail ring will fit behind the water jacket. Just a couple of bits of thin carbon fiber plate or aluminium will do the trick.
Offshore actually sell a little kit, but the brackets are easy enough to make
http://www.offshoreelectrics.com/proddetail.php?prod=ose-83005
But you can just see the aluminium brackets I added in these pics for the tail ring.
tuncd
02-14-2016, 05:18 AM
Yes.
I dont think that this trick Works for me with this jacket. it is realy long and there is no space left on the motor for the rear support even with this. I think I am gonna go for shorter jacket immediately.
NativePaul
02-14-2016, 07:22 AM
You could glue a wedge of wood under the rear of the jacket with a hole in, then put a zip tie round the jacket to hold it down.
785boats
02-15-2016, 01:29 AM
That's a good method that works too Paul.
Anything to keep the motor in line with the stuffing tube tuncd.
iop65
02-15-2016, 05:39 AM
looking at the pictures i think there's enough motor left to put the ring on
good thing somebody pointed it out , i guess you wouldn't got far with the motor hanging on like that !!
785boats
02-15-2016, 02:04 PM
I tend to agree. There is enough room to get the ring on there. You may need to file a few nicks in the ring where the screw heads for the endbell are to get it fully on.
But I have had the rings only half way on to the motor because of those bolts & it held just fine.
tuncd
02-15-2016, 02:46 PM
I tried it but jacket leaks from the front side. Ordered shorter jacket already from RCECHO. But the store is not a serious one. I can not see my orders on their webpage. They did not even respond yet.
TRUCKPULL
02-15-2016, 08:09 PM
One other small point.
Have your water outlet from the motor strait up at the top, so you get full water circulation around the motor.
Larry
