View Full Version : How to loctite 2mm (0.078) wire to shaft drilled for 4.75mm?
dmitry100
01-21-2016, 06:46 PM
I heard some of you guys loctite a few tubes to fill in the space to get a 4.75mm shaft to attach a 2mm (0.078) wire...
What size of tubes should I use for this? Would it be a good idea to do this on the collet side as well?
Figured I might do that for the collet too... instead of buying a 2mm clutch, as I have 4.75mm MBP collets which I thought I'd make use of instead...
JimClark
01-21-2016, 07:04 PM
good luck finding metric tubes. Probbaly better off getitng someone to make a step down insert
ray schrauwen
01-21-2016, 11:33 PM
Is it actually metric or .078"? If it is .078 then try k&s tubing. Terry Davis would know more.
dmitry100
01-22-2016, 12:08 AM
You guys know of anyone who can make a step down insert?
JimClark
01-22-2016, 12:13 AM
4.75 mm is .1870079 inches so that is 3/16th of an inch so tube may work
dmitry100
01-22-2016, 01:24 AM
Will brass tubing be strong enough?
Man... Jeff wolt is supposed to a pro with this stuff. Can't seem to get ahold of him though.
martin
01-22-2016, 09:10 AM
If you cant get hold of Jeff wohlt OSE has .078" wire drive to 3/16" stub x 16" long, the OSE ones are made by Wohlt.
NativePaul
01-22-2016, 10:17 AM
I have used K&S brass tubing one inside the other for stuffing tubes in the past, but each sliding fit tube can introduce eccentricity and angular misalignment especially with short lengths. I wouldn't use that method on a stub and expect the wire to last long, if it is not perfectly aligned it will break at the nose of the stub.
I would just but a 2mm stub shaft, it will be much cheaper than several brass tubes if you don't have them already and will better alignment.
dmitry100
01-22-2016, 02:11 PM
Paul: Hmm... yea thats what I was thinking. Would you recommend getting some sort of stub adapter for a .187 collet to grip to as well? I have some decent MBP ones, figured they'd work better or as good as the 2mm MBP clutches.
I was initially thinking about using 2.5mm or 0.093 wire though but it's too bad OSE doesn't carry MBP clutch sizes for this.
So I guess I'll try the 2mm first. Hopefully it doesn't break my new LMT motors in case the wire snaps from the load...
Do you guys think 2mm/0.078 wire would be strong enough to handle 65k rpm spinning something like an x447 prop (twin) ?
