View Full Version : SV Upgrade
SJFE
05-27-2007, 12:42 AM
I ran into a little bit of luck when I won the auction for the inline hardware. The guy also had listed a CC Cuda 80 with the water cooling installed pluss a Feigao 8XL with an OSE water jacket. He had about 10 runs on it. Listed for 150. Smokin deal I thought. Well no one bit....:confused: . I tossed him an offer for 135 delivered and he bit. What you see hear is just that. I cut off his deans. I didnt like the look of the solder joints. The motor end has them big 6mm bullet conectors. The joints looked fine. I tossed in a hextronic 23 volt Ubec I had layin around and there she is. I will be gettin just over 29000 rpm with this setup on 12 cells. Yes I will run 14 also. I will be on the water with this and the bullet Monday. Look for the videos late in the evening:D.
[IMG]http://i42.photobucket.com/albums/e343/STOAK/DSC00820.jpg
http://i42.photobucket.com/albums/e343/STOAK/DSC00821.jpg
Jeepers
05-27-2007, 01:03 AM
:p what your bullet wasnt fast enough? so now you have a smaller boat with more power! :rolleyes: nothin wrong THAT!!!! try a X438to start those motors like the small diameters than maybe a 640-642
SJFE
05-27-2007, 01:13 AM
Welp for now I have the stock prop on it. The only smaller props I have are the 42mm cf on the bullet and a 40,, cf in the box. Believe it or not the Sv is quite bigger than the bullet. It has way more freeboard and its longer by 2 inches almost. One of them will be going on the market by the end of the week. I only need one fast sub 30 inch mono. To complete my collection I need the following boats A Fast 25 to 27 inch mono. A 30 to 35 scale looking mono(Triton or Rio). I am getting a Jolly Cat, and last I want a Micro Hydro. That would make the perfect collection for me. Maybe down the road I will pick up a Team lindaneu rigger. They are the only one I seem to like the looks of.
Jeepers
05-27-2007, 01:21 AM
oh sorry! I thought I saw the bullet was 33" inches some were! :o I tested my hydro with an 8xl x445 motor came back 150 degrees :eek: It was flyin though! I have a heavly modified X 645 I want to try ,test tomorrow! :eek:
SJFE
05-27-2007, 01:25 AM
Man I am so chompin @ the bit to get back out there. I fight off the go feaver and remember every thing...LOL.
part time
05-27-2007, 08:31 AM
here is what fe cal says x632 42.34mph 49.38 amps and 4 minutes run time. this is for a hacker 8xl but the feiago shpoul be pretty close and the feigao has another 100rpm/v over the hacker.
hammertime
05-27-2007, 02:22 PM
nice work........ should be sweeeet.
hammertime
05-27-2007, 02:24 PM
how did you mount the speed control to the motor..... wont that build more heat or no
