View Full Version : 4s Keps Rigger.
785boats
01-12-2016, 02:37 AM
While I've been building the Wasp & the SharpShooter Hydros, I've also been building a rigger loosely based on the Keps .21 rigger, with a pair of sponsons bought from 'The Build R/C' & a slightly wider scratch built tub.
Here's a few pics of the finished boat & a link to the build over on R/C Groups for those interested.
http://www.rcgroups.com/forums/showthread.php?t=2566209
kfxguy
01-12-2016, 07:54 AM
Looks good! I like the wood and red paint with a stripe together.
785boats
01-12-2016, 02:23 PM
Thanks buddy. We'll see how she goes in testing this weekend.
Tamelesstgr
01-12-2016, 04:47 PM
I so want to start the construction project on one of these this year! Trying to pull together an approximation for the build materials.
Tamelesstgr
01-13-2016, 08:32 AM
Also, I read your thread on rc groups. When you refer to the ski on the bottom, does that refer to the triangular housing that the stuffing tube is enclosed in? Am I correct in assuming that helps lift the main body out of the water?
785boats
01-13-2016, 02:11 PM
Yep.
You are correct on both counts.
785boats
01-25-2016, 04:52 PM
The first test day was going well on Sunday until the spar inserts pulled out of the starboard sponson in a turn. We were going to get a video on the next run too.
I'll get them glued back in, & with a wafer head 1/4" machine screw tapped into the inserts from the outside of the sponson they should be a lot stronger.
I'll also add a 1/8" rod from the side of the tub to the turn fin bracket, to take the strain in the corners.
I'm calling her the "Water Spider". You'll see why in the pics.
CRSalt
02-29-2016, 10:16 PM
Are these your own design sponsons? I'm building a new dual brushless rigger and am trying to figure out a good design for them
785boats
03-12-2016, 06:54 PM
Sorry mate.
I only just saw your post. Please don't think me rude for not answering earlier.
But no. They're not my design. They are sold by "The build R/C" as spare parts for their cheap copy of the Keps rigger.
http://thebuildrc.com/rc-boats/arr-without-motor/31-6-rc-ep-frp-epoxy-fiberglass-sea-arrow-arr-racing-outrigger-boat-754.html
The real plans are available for download here if you want.
Here's the newer electric version.
http://www.ne-stuff.net/2016/02/keps-fe-4s-p-open-freebie.html
Here's the original nitro version.
http://www.ne-stuff.net/2015/12/keps-t3-21-freebie.html
Here's a video of a test run last weekend.
It was going well until I hit a buoy & broke a spar.
https://www.youtube.com/watch?v=6liU4f2rgKk
Brushless55
03-20-2016, 12:17 AM
I don't know about you, but to me it looks like its running really good !
T.S.Davis
03-20-2016, 07:30 PM
Very cool. I looked at those plans just for sponsons alone. Thought they were slick.
785boats
03-21-2016, 04:20 AM
Thanks Todd.
It's only a cheap 3674 2250kv motor in it at the moment. It was running well. A bit wet maybe, but it's not fast enough to compete with the other riggers in our club yet. She needs a 40mm 2400kv motor in it to do that. Maybe later. But it is certainly very precise in the turns.
Terry.
I also have a set of those plans & intend to build a pair of those sponsons too. Maybe the whole boat. Aaahh!!! So many boats. So little time.
785boats
05-21-2016, 12:37 AM
Well last weekend I entered this little bird in the EA Rigger class.
I only replaced the broken booms the night before, so it had no practice before the first race. So that race was atrocious. Too much rudder throw & had too much left trim in it so I was fighting it all the way.
After a few adjustments to the linkages & the Tx trim. She performed much better in the next two races giving me two wins.
Here are the last two races.
Still with the little 3674 2400kv motor in it
https://www.youtube.com/watch?v=8R5rxbSHr9o
785boats
05-21-2016, 12:38 AM
The last race.
https://www.youtube.com/watch?v=iLiLhgsJNFc
