View Full Version : MHZ Lizard extreme with outboard
iop65
01-09-2016, 10:03 AM
now for something different
started from a MHZ lizard extreme and should become a Bernico F2 extreme scale like model
using the Thunder tiger outboard
not aming for top speed but 40-50 km/h would be scale speed i guess
working at the transom at the moment
139985139986139987
shua
01-09-2016, 10:38 AM
Very Neat!! Looking forward to this one.
iop65
01-19-2016, 01:37 PM
more work done , transom getting shape
140232
Beaux
01-29-2016, 01:19 PM
looking good! I am happy to see another outboard.Starting to feel like an only child.
Darin Jordan
01-29-2016, 01:25 PM
Love outboards. Should be a fun setup.
Beaux
01-29-2016, 01:43 PM
what do you think about aqua 36-56-2030 kb leg on a f1 hornet from hk?
kfxguy
01-29-2016, 02:10 PM
Nice work! What outboard is that? Tfl?
iop65
01-29-2016, 02:21 PM
no it's the thunder tiger unit , has an 1900kv 36 mm outrunner in it
designed for use with a 40.6 mm prop and 4s
but'm going to use it for with a beautifull 40mm 3blade cnc prop and only 3s , less rpm : easier on the flex
have to say that i like the design : flex makes an angle of 45° and not 90° like most outboards do ( there is a gear inside and motor is tilted in an angle )
sorry for my english : it's not my native language
iop65
01-29-2016, 02:23 PM
i'm not an expert Beaux but if flex makes an angle of 90° : i'm not sure about the rpm's this can handle
Beaux
01-29-2016, 02:47 PM
thank you iop65, english looks ok to me.that cnc prop sure is pretty, I have some Two blades ,nice.
Beaux
02-05-2016, 03:53 PM
hey iop65, how's the boat coming?
iop65
02-07-2016, 05:02 AM
i'm a slow builder ( just needs to be finished in a few months)
work,wife, kids...too little time :-)
put in an extra 200gr/m² glasscloth in the hull
attached the motor because i'm working on the servomount : have to make that myself
as you can see : still needs some sanding , but's that an outside job and the wether is just to bad for that
140788140789
Beaux
02-07-2016, 09:12 AM
Looks like a decent size motor on the out board. just got my f1 hornet together with that 3650 last night. the water is not frozen down here, we,ll be back in the 60,s this week so i will get to run maybe monday. good to hear from you good luck and stay warm.!
iop65
02-20-2016, 07:16 AM
servo mount in + applied some spray-putty:
141037141038
NativePaul
02-20-2016, 11:34 AM
Nice work, it is always good to see scratch builds or extensive modifications like these to show that despite the prevalence of prebuilt hulls and RTRs the skills aren't disappearing yet.
The younger Bertels from Bernico are keen FE racers in Europe as well as full size racers, I hope they see this as I'm sure they would get a kick out of it.
Beaux
02-20-2016, 03:36 PM
very nice. What type of putty are you using?
iop65
02-22-2016, 05:42 AM
i'm using Motip spray cans ( putty , primer , ....)
Beaux
02-23-2016, 04:29 PM
she looks good, nice work on the inside also.
kfxguy
02-23-2016, 04:55 PM
Looking good!
iop65
03-11-2016, 10:53 AM
first coat primer :
141476141477
Beaux
03-11-2016, 11:03 AM
you can't even see the addition . Very good looks factory.
iop65
03-19-2016, 03:28 AM
Been busy this week :
141640141641141642
Beaux
03-19-2016, 09:35 AM
Wow won't be long now., looks good.
Brushless55
03-19-2016, 01:23 PM
Great job man, looks awesome !
looking forward to a running video of this one...
iop65
03-20-2016, 04:22 AM
Thanks guys
Hope to get it in the water next weekend
Beaux
03-21-2016, 09:21 AM
what kind of plate did you use to make the servo mount? Where did you get it? Thanks.
iop65
03-21-2016, 03:20 PM
2 mm gfk
Like it better then cfk:dont like that black dust 😉
Live in Europe, i get it from als German webshop
Beaux
03-21-2016, 03:55 PM
ok thanks.
iop65
03-26-2016, 03:16 AM
busy week , just managed to get started on changing the hatch:
used 1 mm gfk
141918
Beaux
03-26-2016, 10:03 AM
looks good , I'm still trying to find some of that thin fiber glass.
iop65
04-12-2016, 01:34 PM
had in in the water and tried it with 3s : just too slow
it changed when using 4 s : good speed ( have to gps it but i guess the 50 km/h will be obtained)
but bad handling , chine walking and spinouts
raised the outboard 1 mm to solve the chine walking and moved the cog to the transom to solve the spinouts ans added some trimtabs i had laying around
put it in the water this weekend : me very happy :-)
it ran great in rather bad/windy conditions
boat is stable and makes a very nice sound : i think it's the outrunner+ the gears but the sound reminds me at a V6 2 stroke outboard
will try to post video
Beaux
04-12-2016, 05:41 PM
sounds like your getting her dialed in.
axel
06-05-2016, 05:38 AM
what about the video?
