dmitry100
01-06-2016, 03:59 PM
Hey guys...
I've been hunting for some good quality flex cable lately-- came across 5mm Gundert (is this 4.75mm?), 4.75mm MTC (Model Center Lorenz), and the Hydromarine.de 4.75mm cable.
Which ones are the strongest and best performing cable out of all those that can hold up for SAW?
Do any of you guys know where I might be able to find 6mm shafts drilled for spring steel wire (2mm or 2.5mm)? I was thinking to try it out on one of my Twin cats...
Figured it might help in terms of high rpm performance over flex cable... or would performance gains not be that much noticeable over good quality flex cable?
Also, do any of you guys use Speedmaster or MTC struts for Twin Cats? I was thinking to use the flat bottom speedmaster struts on one of my cats... but it seems like 2 struts for a twin can prove to be a bit annoying to adjust and to keep water out. I was thinking to maybe use a piece of hose between the strut tube and the transom stuffing tube and do the same in the area between the flex cable, collet stuffing tube to keep the water out...)
