View Full Version : 37"Daytona:Bullitproof
srislash
12-27-2015, 04:10 PM
Well guys I've finally decided to get on with my first Dihedral design hull. So here is what I have:
37" FC hull
2 Trackstar 4074 2560kv motors
110 stingers(to be shortened)
MBP collets and 150 R&L cables
A customized mini rudder from OSE
Savox 'shorty' servo
And a pair of SK 120 ESC's(which I am still undecided if adequate)
http://i1128.photobucket.com/albums/m488/SRIslash/Daytona/Daytona%20003_zpsiiqvdkqz.jpg (http://s1128.photobucket.com/user/SRIslash/media/Daytona/Daytona%20003_zpsiiqvdkqz.jpg.html)http://i1128.photobucket.com/albums/m488/SRIslash/Daytona/Daytona%20001_zpst3wure9e.jpg (http://s1128.photobucket.com/user/SRIslash/media/Daytona/Daytona%20001_zpst3wure9e.jpg.html)
dmitry100
12-27-2015, 06:01 PM
Since when did you get yourself some MBP Clicks on your Fantasm, shawn? :) How do you like them?
Do they stand up to SAW ok? I heard they can sometimes move (left/right) etc after a crash...
srislash
12-27-2015, 07:58 PM
Those have been on there since I built it Dmitry. They have been great but mine are a little stiff to tune as I got a little loose with epoxy back there when I built it.
iridebikes247
12-27-2015, 08:12 PM
Looks like a fun build btw what cell count you thinking?
srislash
12-27-2015, 08:28 PM
Thinking 4s Mike but I have 5's as well, lol. Y'know, sport!:just-kidding:
kfxguy
12-27-2015, 11:51 PM
5s is gonna haul. The 120's may do it but you might be cutting it close. We like overhead, just in case. Pair of seaking 180's would be ideal. I know you've got plenty of props to play with so it would be safer. This should be a very fast but budget build. Can't wait to see it done!
srislash
12-28-2015, 08:32 AM
I have a few Castle 200/240's here Travis, The garage sale air versions. I have been thinking of tuning a couple up for this. Once running maybe the 120's will be fine.
srislash
12-29-2015, 11:33 PM
As per my usual I installed a piece of 1 1/4"x 3/8" aluminum stock into the transom overhang. This I later drill and thread for the rudder standoff. I layed a piece of CF cloth across the transom section first then the aluminum and then another strip of CF wrapped right around the seam up to where my stingers mount.
http://i1128.photobucket.com/albums/m488/SRIslash/Daytona/Daytona%20006_zpsddmf3vtw.jpg (http://s1128.photobucket.com/user/SRIslash/media/Daytona/Daytona%20006_zpsddmf3vtw.jpg.html)
I also like to make stringer/deck braces for additional strength. I have found it really helps to stiffen it up and prevents the deck from collapsing if the boat takes a dive.
http://i1128.photobucket.com/albums/m488/SRIslash/Daytona/Daytona%20010_zpsfqg8cpmp.jpg (http://s1128.photobucket.com/user/SRIslash/media/Daytona/Daytona%20010_zpsfqg8cpmp.jpg.html)
ls1fst98
12-30-2015, 12:38 PM
Looks good as usual! Makes me want to finish my daytona I started like 3 years ago hahah
srislash
12-30-2015, 02:01 PM
You were one of the reasons I bought one.
srislash
01-04-2016, 09:02 AM
I got my stringers in, inlay and transom doublers in, and then drilled for my stingers and installed my motor mounts. All this done within a couple day window so all was mounted 'green'.
http://i1128.photobucket.com/albums/m488/SRIslash/Daytona/Daytona%20013_zpsgcegzkqr.jpg (http://s1128.photobucket.com/user/SRIslash/media/Daytona/Daytona%20013_zpsgcegzkqr.jpg.html)http://i1128.photobucket.com/albums/m488/SRIslash/Daytona/Daytona2%20003_zpskxw5tn0x.jpg (http://s1128.photobucket.com/user/SRIslash/media/Daytona/Daytona2%20003_zpskxw5tn0x.jpg.html)http://i1128.photobucket.com/albums/m488/SRIslash/Daytona/Daytona2%20001_zpseimhdwli.jpg (http://s1128.photobucket.com/user/SRIslash/media/Daytona/Daytona2%20001_zpseimhdwli.jpg.html)
srislash
01-04-2016, 09:06 AM
And here are the mounts setting up and after.
http://i1128.photobucket.com/albums/m488/SRIslash/Daytona/Daytona2%20004_zpsuqdcwnch.jpg (http://s1128.photobucket.com/user/SRIslash/media/Daytona/Daytona2%20004_zpsuqdcwnch.jpg.html)http://i1128.photobucket.com/albums/m488/SRIslash/Daytona/Daytona2%20008_zps3tnd1o0l.jpg (http://s1128.photobucket.com/user/SRIslash/media/Daytona/Daytona2%20008_zps3tnd1o0l.jpg.html)
I am going with .150 flexes on this one so I installed a 3/16 flex thru the stinger and into a collett attached to the motor to maintain a good natural bend.
srislash
01-04-2016, 09:13 AM
So this is my rudder which has been made from two OSE rudders. It is as close to 'scale' as I could come up with. I will most likely powder coat it later before final assembly.
http://i1128.photobucket.com/albums/m488/SRIslash/Daytona/Daytona2%20007_zpsne6g8dis.jpg (http://s1128.photobucket.com/user/SRIslash/media/Daytona/Daytona2%20007_zpsne6g8dis.jpg.html)
Now for some thoughts from you guys perhaps; when I had these stingers on my Shocker I found they would get tweaked easily. So I have been thinking if I shorten them it would lessen the torsional side forces that tweaked them before. Does anyone know if the bushings just push through the tube wherever or is there a set ridge within? I seem to have up to 20mm or 5/8" to cut off of them
http://i1128.photobucket.com/albums/m488/SRIslash/Daytona/Daytona2%20006_zpsvqirn3z0.jpg (http://s1128.photobucket.com/user/SRIslash/media/Daytona/Daytona2%20006_zpsvqirn3z0.jpg.html)
kfxguy
01-04-2016, 11:45 AM
Looking good! I need some schooling on how to get my epoxy to lay correctly and not run. What epoxy are you using?
iridebikes247
01-04-2016, 11:53 AM
I run the tfl stingers on my explorer I believe 108mm long. My boat was riding pretty wet so I cut off 18mm of stinger.
I ordered a bunch of bushings from OSE but after cutting it off I found I left the bushings intact, so just popped them out of the piece I cut off and pressed them into the drive tube. To answer your question I don't think they have a ring or at least the ones I cut down didn't, I cracked two drive posts from driving hard in choppy water since cutting down, much more durable.
The daytona will likely air out better with short drives
ls1fst98
01-04-2016, 02:15 PM
looking good man. makes me want to finish my daytona soon. interested to see how those trackstars do under 5s! should sound wicked. and here i thought i was nuts for running 2200kv on 5s!!!
Tamelesstgr
01-04-2016, 03:05 PM
Really like this idea, have not seen these pieces beefed up before. Are you going to fill with expanding foam as well?
srislash
01-04-2016, 08:16 PM
I do have some in the tips and a small way up the sponsons. I have been doing these stringers for awhile now. Geico twin, and my Fantasm which is coming up on its third year running(half that time over 100) and I feel it totally helps keep her SOLID.
srislash
01-04-2016, 08:17 PM
Thanks Mike, just the info I was looking for
SystemTree Silvertip Laminating epoxy Trav. It has not failed me yet. I use this $hxx for everything, my runners, my CF repairs, my own sheets, everything.
srislash
02-01-2016, 09:46 PM
Wow, second page back already! I have been busy but have been working on something along the way, bit by bit.
I wanted something different in this one and in my future builds so I have made my own servo mount mould.
http://i1128.photobucket.com/albums/m488/SRIslash/Daytona/servo%20002_zps3hq2pqxa.jpg (http://s1128.photobucket.com/user/SRIslash/media/Daytona/servo%20002_zps3hq2pqxa.jpg.html)
I need to cut the hole for the servo yet and tap screw holes but with this I should be able to keep wire extensions and RX connections tucked under in the empty space beside the servo within the mount. Once again as many of my builds, just different.
kfxguy
02-01-2016, 10:46 PM
Looks cool. It doesn't look very deep, but I'm sure you made sure the servo fits. I've been tryin to dream up some different stuff to do to my future builds here lately. This gets the thoughts pumping!
srislash
02-01-2016, 10:55 PM
Thanks Travis,
It took me a bit to come up with. It is a hard area to get original on. My others I went functional on and tied the side rails into the the rear deck. This one needs a little more work but I like it.
iridebikes247
02-01-2016, 11:30 PM
That looks good, its really cool making custom servo mounts you'll never have on break free with the contact area, motor mounts are looking good too! BTW do you add 2 part foam to the front of your boats?
dmitry100
02-01-2016, 11:48 PM
How do you make your own CF sheet, shawn? Just slapping a few layers wetted in epoxy and clamping it together with like 2 very even metal plates or something like that ?
srislash
02-02-2016, 12:36 AM
Something like that buddy, sheets are done with glass and a ton of weight. This one was made with a foam backed female mould and a male 'plug'.
I did put some in the Fantasm and a bit in this one too Mike. I have been using it to force the wetted CF to the hull sides way up front on the seams.
srislash
03-25-2016, 10:08 AM
I finally got some progress to report.
DRIVE TUBES ARE IN
http://i1128.photobucket.com/albums/m488/SRIslash/Mobile%20Uploads/image_zpse3s2tich.jpg (http://s1128.photobucket.com/user/SRIslash/media/Mobile%20Uploads/image_zpse3s2tich.jpg.html)http://i1128.photobucket.com/albums/m488/SRIslash/Mobile%20Uploads/image_zpsxxrnqmhg.jpg (http://s1128.photobucket.com/user/SRIslash/media/Mobile%20Uploads/image_zpsxxrnqmhg.jpg.html)
It is all down hill from here. Some pretty'ing up, ESC's, cut foam and run.
Oh yeah my rudder cabling is all figured out as well. I'll get a pic later
boredom.is.me
06-19-2016, 05:52 PM
Any update on this build?
srislash
06-19-2016, 06:35 PM
Nope, she pretty much sits like this. It has made it back onto the build table twice but I keep hurting one of the other boats and a runner seems to take precedence.
I was stuck trying to figure some ingenious ESC mounting but I do think I'll just mount them in the middle and get this one going.
Hopefully on it right quick here.
boredom.is.me
06-20-2016, 05:16 PM
A middle mount would probably be the cleanest if you shorten the wires between the ESC and motors. Are you still planning on running the 120A's? I'm on the fence myself.
TheShaddix
06-20-2016, 05:43 PM
For that loose carbon fiber stuck to your hull you could try removing it by gently prying a few fibers off of the surface and then just peel them off. Since it wasn't sanded, it should come right off with little effort.
srislash
06-20-2016, 06:42 PM
I'll be sanding the sucker for some sort of paint job. Likely not too serious of one mind you. The mess will likely 'chip' off like you said though. That would be easier than sanding. Thanks Shaddix.:tiphat:
srislash
06-20-2016, 06:46 PM
Yeah I think I'll run them. I'll be careful though. I really would like a bit more headroom, say 150 amp. If I keep to 42mm props it should be ok. I find it takes a lot to generate the need for 120 amps continuous.
srislash
11-05-2016, 01:05 PM
147428
Well she is back on the bench, actually as of last weekend. This is when I got my little rudder wire tube supports in as well as my water inlets and tubes
147429
srislash
11-06-2016, 01:32 PM
Got some more work done on it while I wait on other parts, the hatch bolts and pins are done
http://i1128.photobucket.com/albums/m488/SRIslash/Daytona/Daytona%20hatch%20006_zpsyp46b321.jpg (http://s1128.photobucket.com/user/SRIslash/media/Daytona/Daytona%20hatch%20006_zpsyp46b321.jpg.html)http://i1128.photobucket.com/albums/m488/SRIslash/Daytona/Daytona%20hatch%20007_zps7qsjxd6b.jpg (http://s1128.photobucket.com/user/SRIslash/media/Daytona/Daytona%20hatch%20007_zps7qsjxd6b.jpg.html)http://i1128.photobucket.com/albums/m488/SRIslash/Daytona/Daytona%20hatch%20005_zpsrtfwx6kv.jpg (http://s1128.photobucket.com/user/SRIslash/media/Daytona/Daytona%20hatch%20005_zpsrtfwx6kv.jpg.html)
srislash
11-06-2016, 01:35 PM
This is how it looks with lid off
http://i1128.photobucket.com/albums/m488/SRIslash/Daytona/Daytona%20hatch%20004_zpsaqzamfli.jpg (http://s1128.photobucket.com/user/SRIslash/media/Daytona/Daytona%20hatch%20004_zpsaqzamfli.jpg.html)
I put extensions on the mid hatch blind buts out of CF and carried them thru to the hull body
http://i1128.photobucket.com/albums/m488/SRIslash/Daytona/Daytona%20hatch%20003_zps9ktip1ny.jpg (http://s1128.photobucket.com/user/SRIslash/media/Daytona/Daytona%20hatch%20003_zps9ktip1ny.jpg.html)
fweasel
11-06-2016, 07:46 PM
Forget the boat, great :censored: use of an inspection mirror in a picture!
srislash
11-06-2016, 09:10 PM
Haha thanks
srislash
12-04-2016, 03:37 PM
So an update is in order. I have it all together now, cooling lines and ESC's wires and installed
http://i1128.photobucket.com/albums/m488/SRIslash/Daytona/Daytona%20maiden%20006_zpsrbhba7zo.jpg (http://s1128.photobucket.com/user/SRIslash/media/Daytona/Daytona%20maiden%20006_zpsrbhba7zo.jpg.html)http://i1128.photobucket.com/albums/m488/SRIslash/Daytona/Daytona%20maiden%20007_zpsjtyvs7qo.jpg (http://s1128.photobucket.com/user/SRIslash/media/Daytona/Daytona%20maiden%20007_zpsjtyvs7qo.jpg.html)
srislash
12-04-2016, 03:42 PM
At this point I decided to run it as this is.
I am real used to flat ride pad boats so this is a new game for me
https://youtu.be/cwQJx6KXBsc
boredom.is.me
12-05-2016, 10:44 AM
Good to see this beast running. I've thought about nine a bit more since then. When the time ever comes around, I'll shove two 3674 2200kv motors with 120a speedies just to keep it light.
kfxguy
12-05-2016, 11:45 AM
Nic. Couple things I noticed. Looks like it's pulling to the left? Could be a number of things and I'm sure you know what to check (flex dragging, throttle calibration, motor kv may be to far off). The main thing I noticed is your servo arm is waaaaaay too long. That's what will cause your erratic steering. It makes the rudder move too fast per servo input, and it kills the tq of your servo. Move the rod ends all the way inwards. I'd just get a shorter one honestly.
srislash
12-05-2016, 01:55 PM
Yeah that was an experiment. It's getting better thru adjustments.
srislash
12-05-2016, 02:02 PM
So I had water infiltration on the first outing, lots of it. So I got my seals on and epoxied some foam to the hatch. This will hold the batteries in place in the inevititable crashes. LOL, I also installed the third screw from the inside of the hull, oops.
http://i1128.photobucket.com/albums/m488/SRIslash/Daytona/Daytona%20runs3%20001_zpsstde89xu.jpg (http://s1128.photobucket.com/user/SRIslash/media/Daytona/Daytona%20runs3%20001_zpsstde89xu.jpg.html)http://i1128.photobucket.com/albums/m488/SRIslash/Daytona/Daytona%20runs3%20002_zpsi1qvy6b0.jpg (http://s1128.photobucket.com/user/SRIslash/media/Daytona/Daytona%20runs3%20002_zpsi1qvy6b0.jpg.html)
Mm, no seals on those pics. But they are on. I have vid from the next outing but I have to put it together.
srislash
12-05-2016, 02:06 PM
I actually have the Flycolor 150's in there. Last run with 447's cut down to 42mm it pulled 114amps peak and settled down to 80. She was at 70mph and that was with my old 4s Revo's.
kfxguy
12-05-2016, 02:37 PM
Do change your steering geometry tho instead of crutching it with expo. It will be strong, more precise and be much easier on your servo.
srislash
02-24-2017, 09:50 PM
Ok well I am off to a rippin start of 2017. Took her off the shelf and tossed her in with the 447's cut to 42mm. Only change is my new Revo 4400's.
https://youtu.be/FaM_y-nbQbk
iridebikes247
02-24-2017, 10:43 PM
Really nice Shawn that boat looks and sounds great. Since the picture on fb of the lake thawed was wondering how long it would be till you got a boat out there lol.
srislash
02-25-2017, 01:09 AM
That lake was froze over this morning. Just a skim I guess!
srislash
03-11-2018, 10:37 AM
Well OMG! Look what is finally getting finished up!!
http://i1128.photobucket.com/albums/m488/SRIslash/Daytona/3F44D549-A182-4312-8B38-BB51ACFF7A6B_zpssvok65mh.jpeg (http://s1128.photobucket.com/user/SRIslash/media/Daytona/3F44D549-A182-4312-8B38-BB51ACFF7A6B_zpssvok65mh.jpeg.html)
I have been dying to run this but it was sitting with just the silver/Chrome.
Yesterday I figured the masking and got the black done
http://i1128.photobucket.com/albums/m488/SRIslash/Daytona/AC9569E6-D7A8-447E-8B29-7FCF4905415B_zpslww17qru.jpeg (http://s1128.photobucket.com/user/SRIslash/media/Daytona/AC9569E6-D7A8-447E-8B29-7FCF4905415B_zpslww17qru.jpeg.html)
fweasel
03-11-2018, 03:39 PM
Dead sexy. Even the straight on Aqua Mania livery is cool, better than my HK Genesis knockoff
srislash
03-11-2018, 04:27 PM
Yup full on Aquamania Ryan. Jeff has the decal set for the Daytona. So I had him do it up for me. This is my first shot at the decal/wrap thing so not perfect but it’s pretty good and the vinyl is forgiving with a hair dryer in hand.
