View Full Version : HK Relentless V2 Prop
Xcessive Carts
12-25-2015, 06:24 AM
One of my boats is a HobbyKing Relentless V1, they have released V2 and it now has a 3 blade metal prop. I have searched and cant find the specs for this 3 blade. Really want to try it on my V1. Any help with this question would be appreciated.
martin
12-25-2015, 12:38 PM
Hobbyking stocks this prop, go to Hobbyking & put in 215000032-0 & you will find it @ $9.02.
martin
12-25-2015, 12:49 PM
By the way this v2 prop is 5mm bore so will be loose on the v1 shaft as its 3/16", just get an Octura 3 blade 37mm diameter x 1.4 prop with 3/16" bore. Which will go straight on the v1 shaft, or you can sleeve the Hobbyking prop to fit.
Xcessive Carts
12-25-2015, 01:53 PM
Thanks for all the info, I found the prop you recommended at OSE.
Xcessive Carts
12-26-2015, 07:05 AM
The Hobbyking prop is only $9.00, would like to try it and see how the boat runs, before I spend $50 at OSE on a much better version. Now I just have to figure out how to adapt it due to the size difference of the shafts. How do you recommend I sleeve it?
martin
12-26-2015, 09:52 AM
To get by using the Hobbyking 5mm bore prop you can wrap the stock shaft with plumbers tape & then fit the prop.
