View Full Version : Radtek 233 flexi drives.
mdonni
12-24-2015, 05:32 PM
Hi guys,
Happy Christmas to you all.
I have a question maybe someone can help me with. I have some new drives for my 233 cat build. How do I connect the flexi drive to the drive shaft. Cheers.
139681
Xcesive8
12-26-2015, 04:13 AM
http://www.mhz-powerboats.com/Miscellaneous/Loctite-648---10g.html
Give the end of shafts you intend to glue in a sand, thouroghly clean with metho
Apply glue on shafts and smear around, slide in and twist as you go in. Leave upside down for a little, I then put in oven for a little
mdonni
12-26-2015, 06:36 AM
Hi thanks for the reply. What glue would you recommend. Thanks Martin.
Xcesive8
12-29-2015, 08:05 AM
Did the link I put up not work ?
If you go on there site you will see it.
I forget what number it is
jj2003
12-29-2015, 08:12 AM
Pretty sure this is the same stuff;
http://www.amazon.com/Loctite-442-21443-Retaining-Compound-Strength/dp/B000O01EU6
TRUCKPULL
12-29-2015, 03:52 PM
Here is the best glue for flex shafts;
http://www.offshoreelectrics.com/proddetail.php?prod=mc-loc603
Larry
