View Full Version : Who sells Hyperion charger's in Toronto Ontario?
Andris Golts
12-11-2015, 12:17 AM
Hi all i have a Hyperion EOSO606i charger that requires the cord between the charger to the balancing board. Regards Andris Golts.
ray schrauwen
12-11-2015, 01:09 PM
Nobody in TORONTO. I Care sells this charger. They are in Canada however what you require is most likely available locally fron Great hobbies or from OSE or lastly from Hobbyking. Skycraft usually doesn't have these things or doesn't understand what is compatible that hangs on their shelf. The reason Hyperion is not that popular in our LHS is most likely a lower profit margin to other brands.
Are we to assume you need the 6 wire cable that goes between the balance output on the charger to the balance board or something else?
ray schrauwen
12-11-2015, 01:11 PM
I might have this cable for you. I will be back in Milton hopefully Monday or Tuesday next week. I'm in Norwich this weekend.
JimClark
12-13-2015, 01:38 AM
I will have to look I mah have an extra one also
Sent from my SM-G900T using Tapatalk
