View Full Version : Painted my Voracity
Crash
12-06-2015, 10:29 PM
Still in work, getting its clear applied then wet sand and polish
139339
139340
139341
Also, reinforced hull and canopy with FG
Turbo Dan-O
12-06-2015, 10:54 PM
Very nice!!!
Crash
12-07-2015, 08:07 AM
Thanks Dan
Its been nice whipping this hull into shape
only had 2 real issues that I didn't like, the hull would of been fine as is.
I found the seam between the top of hull and bottom of hull had some hollows and very thin where the 2 pcs meet.
I added 1 layer of FG to the hull seam on sides and rear of boat at seam.
Then I added 1 layer FG on the bottom inside boat on sides, center and rear area .
I also added a layer around inside the canopy .
It made a dramatic difference in overall stiffness in the flat areas
I am very pleased with the FG work
The paint is a lacquer
I am considering vinyl wrap from Darkside Studios on ebay but, they don't have a Voracity hull to digitize from yet. Id have to send them a hull to digitize a pattern
Very nice!!!
139369139370139371
kfxguy
12-07-2015, 08:23 AM
Dang that thing looks sexy in white. Mine needs repaint one so I was gonna do it in a house of color blue that looks close to factory but seeing the shape of the hull in a different color, I might just change it to something else. Looks good!
Crash
12-07-2015, 08:54 AM
Thank you
The white does show off the shape of the hull.
I post a video of the boat after wet sanding and buffing to show off all the hours I have in the prep work.
arrover
12-07-2015, 09:18 AM
That looks really great!
Crash
12-08-2015, 02:30 PM
Thanks
here is the wrap I like
139404
Crash
12-17-2015, 11:02 PM
https://drive.google.com/file/d/0B5R4bET1OwRydnYtYVlZMW5HRDA/view?usp=docslist_api
Tamelesstgr
12-17-2015, 11:09 PM
Nice to see someone getting creative with the hull. I for one can't leave anything stock! :beerchug:
Crash
03-10-2016, 06:32 AM
DubliColor Deep Blue Metallic
141461141462141463141464141465
kfxguy
03-10-2016, 07:09 AM
Beautiful!
Tamelesstgr
03-20-2016, 09:33 PM
Dam, that's too nice to put in the water.
Crash
03-21-2016, 08:01 AM
Thanks GUys
I am waiting for it to cure before handing it too much.
The weather is getting warmer here so, probably about 2 to 3 weeks the clear will be good and hard.
then I can wet sand and buff before assembly.
all I need is a prop for it.
Dan
Crash
05-04-2016, 05:32 PM
142863142864142865
kfxguy
05-04-2016, 09:52 PM
The minimal amount of decals looks good
Crash
05-11-2016, 07:23 AM
Thanks, it was a challenge cutting out the gold from the decals but, was worth the effort.
on a different subject, I purchased a couple of balanced props off the web and thought I had a grasp on the size and pitch idea.
Now that the props are here I'm not sure I made the rite choices, what do you think of the Octura x548
and the x643 for the Voracity on stock set up?
Dan
arrover
05-11-2016, 09:06 AM
I think the x548 may run similar to the stock prop but I haven't tried it on a stock boat. I don't think Octura makes a x643. Are you sure that's the correct number?
Crash
05-11-2016, 10:15 AM
thanks
here is the x643 listed on ebay I bought.
http://www.ebay.com/itm/322057508419
arrover
05-11-2016, 10:49 AM
I don't believe that is an Octura prop. I think they use the name Octura in the add to get in the search results. Besides that, it looks like it should be a nice prop. It's less aggressive than the stock prop so it may be slower. It's always tough to tell though before you try it!
Crash
05-11-2016, 02:21 PM
just got back from maiden voyage for the season and after assembly from paint job.
Boat ran perfect, no issues.
after the lvc kicked in I brought it in and the motor and ESC were cool battery wires were hot, battery was warm .
Is there a way to ease the stress on the battery? will timing change help?
Dan
Crash
05-11-2016, 05:56 PM
I ran this prop today
its just not enough prop for this boat, I was on full throttle a lot more.
Now I have a prop for sale
LuckY07
08-03-2016, 10:42 AM
Thanks Dan
139369139370139371
Looks really good. I just bought a Voracity (stock for now) and was considering doing the fiberglass/epoxy before I use it, to prevent cracks.
What size/type of fiberglass did you buy? What epoxy did you go with? Any big difference after adding the added weight?
I also noticed you didn't fg the bottom section of the transom, where the prop goes. Is it best to leave that area alone? Thanks!
Crash
09-06-2018, 11:03 AM
I am still running this rig.
It recently got some new parts:
TP 4060 1750kv. on 5s 4000mah 60c x two running parallel
300 amp SF
652 OSE CNC prop
68mph
