View Full Version : TT Outlaw Obl JR - Rebuilding
Giacomo De Rosa
10-13-2015, 07:33 PM
Hi everyone , i'm going to share with you my first tt outlaw obl jr rebuilding project :biggrin:
http://i59.tinypic.com/33z4l10.jpg
removing the old motor mount
http://i61.tinypic.com/2ed8i2s.jpg
3674 goliton 2250 kv (up to 6s 90A) and carbon fiber motor mount
http://i59.tinypic.com/10h3yfa.jpg
Stock motor compared to 3674 :lol:
http://i61.tinypic.com/28mjqcp.jpg
new prop shaft , flex shaft and strut. Yes i know , this strut is for cat but I had already had this at home , can I use it or i should buy a deep-v strut ?
capnswanny
10-15-2015, 11:23 PM
Looks nice and clean! I say run the strut, it's a fiberglass boat... if you want to change it it's very easy.
Do a search for flooded tubes on OSE, it will help you take advantage of that strut adjustability!
Nice work!
Corey
iop65
10-16-2015, 03:02 AM
this is an abs boat , not fiberglass
hope you didn't use epoxy to get that motormount in :epoxy -abs :doens't make a very good bond
wouldn't use that strut ; prop needs to be about 10% hull lenght behind the transom ,you can't do that with this strut so boat will run very wet
had one for the kids , did some mayor rebuilding on it like you are doing but used a solid 4mm axle
mine had a hooked hull and could not get it to run like i wanted ,but after i solved that it ran great
Tamelesstgr
10-16-2015, 01:53 PM
I had good experience with BSI epoxy Mid-Cure on my abs ProBoat Shockwave 26 hull. USed it for laying fiberglass strips on the transom and throughout the hull. Heavy scuffing was required, but all season it has held up.
Giacomo De Rosa
10-19-2015, 03:05 PM
yes I used epoxy to stick the motor mount..
I checked the lenght of my strut and it is as long as the stock one!
iop65
10-20-2015, 06:19 AM
stock boat : about 40 km/h?
if you want it to go faster and not running very wet : prop needs to be further behind the transom
l
10-20-2015, 07:20 AM
stock boat : about 40 km/h? if you want it to go faster and not running very wet : prop needs to be further behind the transom
The strut the OP is using has vertical adjustment. He can loosen up the boat plenty just by lowering the strut - does the same thing as a longer stinger does. His boat will be fine with the strut he wants to use.
As you gain experience with different hulls you will learn that there is usually more than one way to accomplish most things.
iop65
10-21-2015, 05:59 AM
using this strut he's got to be spot on or use a wet well to have that vertical adjustment
Giacomo De Rosa
11-07-2015, 08:10 PM
Prop shaft and strut mounted
http://i67.tinypic.com/23mlv5y.jpg
Giacomo De Rosa
11-10-2015, 02:38 PM
http://i67.tinypic.com/2vkds90.jpg
waiting for a 60mm watercooling jacket
Giacomo De Rosa
11-13-2015, 10:43 AM
Finished!
http://i67.tinypic.com/al6td0.jpg
Watercooling jacket
http://i64.tinypic.com/96hlqe.jpg
SweetAccord
11-13-2015, 11:01 AM
You should use a solid one piece servo horn on the servo, that one is kinda flimsy. I have seen and have had those pop out. All else looks good.
Giacomo De Rosa
01-07-2016, 04:38 PM
Hey guys, here some news!
I removed the waterproof Box, I installed a new rudder (Longer arm) and a "home made" servo mount
some pics
http://i64.tinypic.com/ffaioz.jpg
http://i63.tinypic.com/i6wc5i.jpg
http://i66.tinypic.com/14vqm9w.jpg
http://i66.tinypic.com/108ifsx.jpg
A short video https://www.youtube.com/watch?v=9Kw8ZO1ApxE , the boat was running at 3/4 of full throttle due to the waves
