got to thinking and was wondering if anyone here has used RTV silicone on your boats, if you have where did you use it and how did it hold up against the water?
Rtv silicone???
Tags: None
i use the black silicone for holding battery trays in, and for sealing between through hull fitting like the water outlets, strut mount, rudder mount, etc.HPR 135 redemption, HPR C5009, modded zelos 36, 32 boats and counting.
https://www.facebook.com/groups/EliteRCBoats/ -
I've used it to hold my battery tray in a P mono. It's been in there for a good 6 years. Same with the servo tray.Nortavlag Bulc
I've been using Goop as a sealant/adhesive and it works great. Cures faster than silicon.Mike Chirillo
www.capitolrcmodelboats.com
Just remember to scuff and clean with a solvent that will not hurt your hull before using either silicone or Goop.Nortavlag Bulc
