okieman98
09-15-2015, 11:30 PM
been building a rescue boat for some time, down to the final pieces , but when i order a drive dog for the 4 mm shaft it came in and said 4 mm on packet but would not fit. need the rite drive dog for this shaft and a prop that will work also. need one with a good pitch to push this boat , the shaft measures137037 3.84 mm. and the part where the prop goes on measures 137038, just below the prop nut . 3,76 mm with my Gauge. pls send a link for both so i will not order the wrong thing again.
also i am using left over parts to make the motor and esc came out of a shock wave 26 . 1500 kv motor and 60 amp esc will use 2s are three s which ever i not running that day.
thanks
thanks
