Airedout29
08-23-2015, 07:56 PM
Guys my BJ29 was running hot on 6s.... i built this boat up to run 6s.. yes im only running a 120 esc but until i have issues ill keep it.
im running duel rudder cooling with opened up rudder water holes and bigger lines.
the lower KV has helped huge and prolongs run time
Leopard 4074 1400 kv
Seaking 120
Octura X 442 S&B
blue printed on 6s on a HEAVY slug of a reinforced boat. I bet the boat weights 5-6 lbs maybe slightly more with the 3s packs in it
temps after a timed 7 min run arnt even 80-90 F BUT the batterys are in the 120 range. just curious if i can run another prop or not. i have run a x 440 and now the x 442 the boat likes this prop. Currently the boat runs 50 mph as it sits so im unsure if i should keep this setup or get into a 1600 kv motor. after many issues with this boat im glad it finally runs very well... but i feel it has more in it
135960135961
Seaking 120
Octura X 442 S&B
135960135961
