View Full Version : HK Apparition Flexshaft
dlewis0831
08-22-2015, 11:06 PM
Started to order parts while waiting for my boat and I'm stuck on the drive line. Will a .15 flex shaft fit in the stock stuffing tube? And if so with what size Teflon. I have searched the forums with no luck. Thanks guys.
high-tech
08-23-2015, 09:59 AM
I'm sure this will fit your boat and you should buy a brass bullet nut as well as a flex coupler for your motor that matches your new cable size...
http://www.offshoreelectrics.com/proddetail.php?prod=oct-oc150L-24c
http://www.offshoreelectrics.com/proddetail.php?prod=oct-oc6pnmm
http://www.offshoreelectrics.com/proddetail.php?prod=oct-ocfhe5mm15S
dlewis0831
08-23-2015, 01:44 PM
Thanks for info High-tech! HK doesn't list any specs that are useful on this boat. Thanks again : )
