View Full Version : What motor and prop on blackjack 29 v3 to reach 60mph? Stock flex?
waterproof
08-14-2015, 03:31 PM
Hello.
I would like to get 60mph with my blackjack 29 v3.
Now it run in 50mph all stock on 6s with stock s/b prop with timing 7.5
A few users have change to a Leopard 3674 1900kv and a 442 prop with the 180A esc to reach 60-65mph, will the stock flex keep up on this setup?
I want a setup that works with the stock flex shaft.
My stock motor have 2000kv and its not possible to prop up more? Stock prop is a 1.4 pitch 41.5 mm i think..
Have read that if the timing is set to 7.5 i could try out other prop but would it even be safe to test out a octura 442 on stock motor/esc?
The esc in the voracity 36 inch v hull is the same, and that boat spinning a 45 prop around on a 4082 1650kv motor, could i keep my esc and find a motor with less kv to reach 10 more mph with a bigger prop or do i also need a 180A esc?
