View Full Version : Rigger 3S
grsboats
07-24-2015, 08:05 PM
Hi guys
this is my last project: a 3S rigger with low cost electronic's using a 540 car motor,120A esc and 3S 5.0A 45C batteries...you can see the building of the prototype on my page at :http://grsboats.com.br/novosite/?portfolio=grx-fe-3-s .....a fiber version will be availabe soon using a Leopard 3650.
Its maiden voyage at :https://youtu.be/OBev3abCa44 ....she will be our beginners class .
Thanks
Gill
grsboats
07-24-2015, 08:21 PM
another video : https://youtu.be/PED9uVn_JKM
capnswanny
07-24-2015, 10:41 PM
Nice craftsmanship Gill, great to see a FAST affordable power system on the water!
Thanks for sharing!!
grsboats
07-25-2015, 12:22 PM
Capnswanny...this will be our entry level boat face turmoil we are facing here downsouth(Brazil).....I only built the hull...electronics was borrowed from fast friends as an attemp to keep r/c boating activities alive as for us with the change in the clouds.i.e. dollar versus real....even cheap hardware can be a problem for many interested guys....hope everything goes true for this part of the world.
Thanks for the kind words.
Gill
ls1fst98
07-26-2015, 01:24 PM
I want one! I have a castle 3800kv motor sitting here
grsboats
07-26-2015, 06:13 PM
with the release of the fiber version...quite different than this one....I will post it.The Leopard we will use is a 3900kv so your motor will be good too. Thanks Gill
grsboats
09-05-2015, 04:59 PM
Ok some time went by but I'm back to this project now with a Leo motor......an important upgrade over the car motor even on 3S.
video shows speed improvement: https://youtu.be/iyiz26D0L_A
704Authentic
09-06-2015, 07:30 AM
...following.
high-tech
09-06-2015, 08:36 PM
Hey Gill check out that little red rigger with a little 28mm turnigy motor
grsboats
09-07-2015, 09:43 PM
Nice red rigger. in my case the club decided for an entry level boat for novices/beginners to only run 3S boats so the top speed for a heat boat is adequate for these guys.
grsboats
04-19-2016, 04:43 PM
New motor Leo 3660 2600KV on 3S.....great handling and speed:https://youtu.be/jTP_fcYAjh0
Mxkid261
04-19-2016, 04:54 PM
Wow that thing is a rocket and glued to the water! What does a rigger like this weigh roughly?
grsboats
04-19-2016, 05:46 PM
Thanks Mxkid...ready to run about 1,3 kg with a 5.0A bat.In this case I also swapt the previous 120Aesc to a T-180V3....prop is a stock X438!
Gill
kfxguy
04-19-2016, 06:22 PM
Nice. Runs very smooth and fast in the last video!
grsboats
04-20-2016, 11:12 AM
Thanks guys ...takes some time to get things correctly dialed...now its time for the glass molded version.Gill
grsboats
05-21-2016, 08:03 PM
After a year testing this boat I decided to go ahead with the fiber version and here is the new look....will be posting pics along the making of the molds.Thanks Gill
grsboats
05-22-2016, 08:16 PM
More work done this weekend.
srislash
05-23-2016, 02:15 AM
Nice Gill. Keep up the good work.
Tamelesstgr
05-23-2016, 03:21 PM
Subscribed!
grsboats
05-24-2016, 06:48 PM
Thanks guys from now on things will go quick.Half of the molds ready...tomorrow the schedule is to start the other side if mother nature helps...epoxy really dislikes temps below 17C so I have a heater in the workshop to keep temp controlled.
kfxguy
05-24-2016, 09:33 PM
Nice!
Tamelesstgr
05-25-2016, 10:58 AM
Gill,
So right now you are making the mold which you will lay the fiberglass in to create the sponsons and main body correct? With those molds you can make as many parts as you want to layup correct?
Ken
grsboats
05-25-2016, 06:51 PM
Thanks Travis...this is the only way I,ve learned to make trusty molds...takes time but really pays off.Ken you are correct these molds are for high production,,even not being my case...but I have a dozen hulls to build as we will start this class in our club.actually this boat will be a 4S P limited rigger.here some more progress.
grsboats
05-31-2016, 06:12 PM
Molds almost done..need to make another one for the sponsons......
grsboats
06-06-2016, 04:54 PM
I'm finally get ready to start some boats...tomorrow will lay up the first one.
Tamelesstgr
06-06-2016, 05:06 PM
Gill,
I'm curious, how you assemble the two parts of the boom and the main tub?
Ken
grsboats
06-06-2016, 05:42 PM
Ken here's how in all my FE boats: http://grsboats.com.br/novosite/?portfolio=outrigger-grx-fe-2
tryinotocrash
06-06-2016, 08:25 PM
Wow thanks for sharing your hard work. That is an outstanding project .
What is the material you poured in the mold as filler??
grsboats
06-07-2016, 02:56 PM
Thanks guys yes it is a hard work but pays off....quality in first place to me! Today first boat laid up..Thanks for watching.Gill
grsboats
06-08-2016, 05:46 PM
One more step...probably will open the molds tomorrow.
grsboats
06-09-2016, 07:04 PM
Parts joined and reinforced with fiberglass ribbon..will pull them out tomorrow.
grsboats
06-10-2016, 05:09 PM
Tub is good and strong..sponsons will stay till tomorrow in the molds as they were laid up later and temp here is low (7C)
grsboats
06-10-2016, 05:14 PM
Forgot to post the fiber reinforcement in the tub and sponsons.Two 1" fiberribbons plus one 1/2" in the tub and two 1/2"in the sponsons.
grsboats
06-15-2016, 06:28 PM
Some work at the shop...need to make six before start building them.We decided to use colored resin to avoid painting but honestly I will paint mine(yellow)..kkk
grsboats
06-23-2016, 05:41 PM
Ok boats were laid up and from now on I will post pics of the building process of the yellow boat(mine)...this pic shows two boats ready to be shipped to customers and they will be painted .Gill
bob horowitz
06-23-2016, 06:37 PM
Nice work Gill. They look beautiful.
grsboats
06-23-2016, 06:51 PM
Thanks Bob..the idea was to produce boats without the need of painting but at the end everyone will paint their boats accordingly to the fiber color..LOL Gill
grsboats
07-07-2016, 07:09 PM
Pics of the progress.as this boat uses the same hardware of the proto I will save some snaps of the building.
grsboats
07-07-2016, 07:14 PM
some more....Actually this boat is ready to be painted.
Tamelesstgr
07-08-2016, 10:36 PM
Top notch Gill! :bowdown:
grsboats
07-09-2016, 06:34 PM
Thanks hope to be able to post more progress in a few days as I need to ship some boats to customers.Gill
grsboats
07-13-2016, 07:03 PM
Boat is painted and ready to be reassembled....white pearl with blue just to get some contrast.Motor is a Leo X2 3660 2380kv with a T180 V3 esc.
grsboats
07-13-2016, 07:09 PM
more pics....carbon fiber turn fin was made in closed molds via resin transfer molds (RTM) and weights only 9 grams.
grsboats
07-13-2016, 07:15 PM
The interior of the hull was sanded and received a very thin coat of epoxy resin for finishing.We have four boats ready for some action this weekend so I hope have videos too to be posted.Thanks Gill
kfxguy
07-13-2016, 11:55 PM
Very nice!
Dirk Jan
07-14-2016, 07:06 AM
Great job on those molds, the rigger looks very neat! Let us know how it performs :)
grsboats
07-14-2016, 06:17 PM
Thanks guys...tomorrow is its maiden voyage...will post a video for sure.some more pics showing that using the T180 V3 there's no left room but everything is in place.
grsboats
07-15-2016, 08:35 PM
Ok boat went to water with good performance and handling...need some strut adjustments and I'm waiting for my Revo's for more tests.Thanks Gill
https://youtu.be/l9NffbfuzX0
https://youtu.be/N972jVQ_zYw
grsboats
09-30-2016, 10:19 PM
Today we made some good runs just to check up boats.... ready for our annual event....with new sponsons this rigger went fast and predictable.
https://youtu.be/N6z9lneeISo
https://youtu.be/ek4bQNgoeug
Mike Caruso
09-30-2016, 10:56 PM
Great work as always and best of luck Gil.
grsboats
10-01-2016, 12:59 PM
Thanks Mike.
grsboats
10-01-2016, 01:01 PM
mods.
bob horowitz
10-01-2016, 01:08 PM
Hi Gil,
Have you given any thought to selling these boats. You've made such beautiful molds, it seems a shame not to share them with your fellow boaters.
Regards,
Bob
grsboats
10-01-2016, 05:57 PM
Hi Bob all my models are sold locally not outside due to our very high rated shipping cost but once in a while if a foreign fellow agrees with the shipping cost boats are sent to their destiny....anyway thanks for your compliment.
Cheers
Gill
bob horowitz
10-02-2016, 08:27 AM
Gil,
That's too bad. Your boats are really well built and beautiful.
Regards,
Bob
grsboats
10-02-2016, 09:06 PM
Thanks fellows.
martin
10-13-2016, 11:48 AM
Gill do you find that on riggers in general their is any advantage in speeds with a thinner wedge rudder over a thicker wedge rudder ? . Thinner rudder made from steel to stop it bending, or does a thicker wedge have less drag than a thinner wedge. Thanks Martin.
SweetAccord
10-13-2016, 12:05 PM
Your rigger reminds me of the Keps rigger. Small and thin. Love it! I love your builds Gil. I would buy your builds if you offered them like Bob mentioned.
boredom.is.me
10-13-2016, 12:43 PM
This is awesome! The glass work is really clean and thorough. I hope I can acquire this level of skill in the future.
SweetAccord
10-13-2016, 01:00 PM
It looks like a JAE on steroids! If you made this a kit with hardware, it would sell like hotcakes.
grsboats
10-13-2016, 01:10 PM
Thanks a lot fellas..what I would do is move to the north hemisphere where most of my family lives..who knows....Martin I 've been trying all sort of rudder blades for oval and sincerely the difference is not measurable at least on my boats....speedmaster rudders are my first option cause they are thinner than the china ones but again I can't say too much about difference on speeds.About steel blades I tried years ago on my very first Jae and speed was almost the same than with a TFL rudder....in the other hand you will find out a big difference on SAW (+5 mph) with the same set up.Gill
grsboats
10-13-2016, 01:13 PM
We are working with our post office to reduce shipping cost for years.......I've heard that with the new politics it can be some light at the end of the tunnel.
martin
10-13-2016, 01:43 PM
Gill I assume the +5mph on the saw rigger was with the thinner wedge rudder.
grsboats
10-13-2016, 03:04 PM
Martin correct...years ago I used to call Speedmaster to get customized rudder blades for SAW.....thinner but high quality....still have some ones.
SweetAccord
10-13-2016, 03:47 PM
What is it that you are doing? What are you selling/offering? What am I missing here?
grsboats
10-13-2016, 04:19 PM
We are talking about all models made by me that are sold locally not for the outside due to our high rated shipping taxes.
SweetAccord
10-13-2016, 05:23 PM
Ok awesome. What would be the price for example? Do you have a price list just the kit?
grsboats
10-13-2016, 05:49 PM
Sweetaccord PM sent.
Mxkid261
11-14-2016, 09:16 PM
What's the length? These look so awesome.. I too would be very interested in one I'm dying for a rigger to run 2s and 3s. I'd rather have something like this over a wood kit.
grsboats
11-15-2016, 11:19 AM
Mxkid the lenght is 26".......thanks Gill
ray schrauwen
11-15-2016, 01:12 PM
Beautiful Gill!
grsboats
11-15-2016, 06:42 PM
Thanks Ray!
