View Full Version : geico 29 v3
4343
07-24-2015, 06:10 PM
can someone let me know if the new geico 29 v3 bounces like old ones? is the blackjack v3 29 the same hull design?? need to know before buying?
waterproof
07-25-2015, 02:42 PM
Blackjack and geico is the same boat.
It do not have the bounce issue like the v2.
V3 hull its mutch more stabile. Have run mutch on 6s and it have never blow over.
You must adjust your cog and if you get your prop sharp and balanced it would run better, less bounce and better handling. V2 needs blueprinting but v3 have mutch flatter sponsons so you dont need to do that.
Big Bill
11-26-2015, 09:26 PM
How can you tell if the boat is a V3? iIam thinking you cant tell by just looking at the box itself.
JimClark
11-26-2015, 11:08 PM
You could buy a new one from proboat I bet there will be Christmas sales
Sent from my SM-G900T using Tapatalk
rayzerdesigns
11-27-2015, 01:58 AM
Look at insides.. No more wood
cmscat
12-08-2015, 11:38 AM
Square hatch opening .
Fixitguy1
01-06-2017, 06:52 PM
I just purchased a new Miss Geico V3 and would like to know what prop should I run thinking of a x440/3 but heard I would have to reset the timing on the ESC also not sure about the water line going to the top of the motor first. motor is a Dynamite 2000kv and plan on running on 6s
fweasel
01-06-2017, 06:57 PM
Thought my last reply (http://forums.offshoreelectrics.com/showthread.php?55371-29-V3-best-stock-prop&p=681019#post681019)was pretty spot on, seeing as I ran that exact same boat/setup all summer.
Fixitguy1
01-06-2017, 09:43 PM
Measure Twice Cut once. It's hard to figure out who is giving the best advice
Thanks I found one.
TrashBoat
03-30-2017, 08:20 PM
throw the 2000kv motor in the lake.put in a 1650 or a Castle with a water jacket and let it eat
