View Full Version : Dumas Hawk 3.5 new build FE Conversion
high-tech
07-22-2015, 10:52 PM
Hi Guys, :help:
I'm gonna build this Dumas Hawk Brushless Conversion and I know its been done before... And I cant find any Info on past builds so I'm not really sure about motor placement... Anybody know who I could get ahold of to get me started of right? I would appreciate some help Thanks...
I'm thinking Nue 1415 or 1515 1y 2200kv 4s P Spec and play with 6s for fun... I would appreciate the feedback thanks
134833
high-tech
07-28-2015, 08:03 PM
Well I got a little bit done, I may be a little slow but what's done is right! I borrowed a tub jig from a club member and got it straight!!! I feel good about it everything lined up and it's ready for the boom tube inserts that go in the tub... I'll Update when I get more, I'm waiting for hardware from zippkits.
high-tech
08-07-2015, 03:38 PM
Most of the hardware showed up today and I got the Sponsons almost done... I didn't like the dumas design for the right sponson so I made a mirror copy of the left sponson and used a foam core instead of balsa wood. I still need to come up with a turn fin and a few other things like speed controller and rudder servo and some carbon fiber for the battery / motor compartment.
high-tech
08-08-2015, 07:49 PM
Some more Pictures
grsboats
08-09-2015, 09:13 PM
In the 90's I used to run 3,5 and 7,5 nitro Hawks.....great boats for that time......it would be nice see a brushless version...hope you have enough height to place everything.Thanks for sharing Gill
high-tech
08-12-2015, 08:55 PM
Hey Gill I raised up the boom tubes so I would have room for the batteries and the motor is gonna stick up up so I'm gonna make a bump in the hatch. Nothing to radical its a 4s heat racer... Here in Tucson We have a class called open Electric, its crazy but there aint very many people here in Tucson who know how to build Fast Electrics... Our Club President has a 7.5 Hawk kit unopened and I'm gonna do that one for gas motor Zenoah G260PUM and It will be fun and competitive...
high-tech
08-12-2015, 08:58 PM
I got the Carbon Fiber done and it came out good I'm happy
grsboats
08-12-2015, 09:33 PM
Looking good...I'm looking forward to this project ...your motor choice is right.Gill
high-tech
08-19-2015, 10:23 PM
I fabbed a servo mount and located and drilled the rudder control rod hole. The Motor mount showed up today and I think its good to go for initial testing I'm using the 2030kv ammo motor... Now I can start on the stuffing tube.
high-tech
08-19-2015, 10:52 PM
Starting to look like a rigger
high-tech
08-23-2015, 02:32 PM
Well I started making the hatch that covers the motor compartment... I took the original plywood hatch and glued a block of Styrofoam to it and shaped it with sandpaper and then fiber glassed over it for a parting surface and then prepped it with PVA and a couple coats of partall wax, then I wet out another piece of cloth for the hatch now in 3 hours I'll part it off the mold and trim up and its done!:biggrin:
high-tech
08-23-2015, 07:17 PM
Well I got it parted trimmed up and it tapes up good I may do one in carbon too
high-tech
08-25-2015, 11:25 PM
I got the stuffing tube and the motor mount glued in for good... I went to my local fiberglass supply store here in Tucson and got some fillers and some black die and that stuff turned my epoxy resin into JB Weld really cool stuff...
Fillers are Milled fiberglass Cab-o-sill and Basically talc powder, really strong stuff... I may never buy epoxy glue again
high-tech
09-01-2015, 04:28 PM
I made a carbon fiber cowling and painted some accent color on the tub sides and sponson sides, I bought some automotive urethane clear and I'll give it three coats
capnswanny
09-01-2015, 09:12 PM
Man, that's looking great!
I like how far forward you mounted your motor, I think that will get the cog where it should be.
I picked one up at a hobby show and converted from nitro to FE. This was my first "real" FE boat and I struggled a bit too get it to run well. My cog is still father aft than I would like and there's a lot of extra weight from the original build. I managed to squeeze out 38 mph with a AQ2030, AQ60A ESC on 4S. Got 43mph with the AQ1800, Seaking 120 on 5S. Here are some pictures I snapped for you tonight with a 5S 4000 battery in the hole:
capnswanny
09-01-2015, 09:28 PM
Here's a cruddy video of my second "first" run a couple years back, with commentary provided by my son and the rest of the crew on the lake. I never fixed the hopping problem, and I took on some water knocking out the RX, but you get the idea ;)
http://www.youtube.com/watch?v=DHlEhjrHy3w
high-tech
09-06-2015, 07:42 PM
I thought I was gonna have to cut that bulkhead and mount the motor like you did. I waited till I had all the hardware mounted and batteries in it and found CoG just slightly behind sponsons and that's it...
high-tech
09-06-2015, 07:44 PM
what size prop did you run
high-tech
09-06-2015, 08:02 PM
I splurged and bought a quart of automotive urethane clear and I'll never point a rattle can at a boat ever again... This Urethane is amazing stuff I used three ounces of clear and reduced by 40% and it was perfect consistency for my airbrush came out cherry still looks wet and its been dry for a day now
capnswanny
09-07-2015, 04:42 AM
This run was a m447.
longballlumber
09-07-2015, 05:52 AM
That boat should run well with starting off with an H4, H5, and if temps OK H7. All in that order. With a high RPM .21 sized motor it will push that hull into the high 60's They are sweet driving hull once set up correctly. Mine is 8 years old and can still hold its own, but I run it with nitro power.
Later,
Ball
high-tech
09-08-2015, 07:39 PM
Right now for starters I'm gonna run an AQ 2030KV motor and I'm starting with a Graupner K Series 42mm and I also have what is equivalent to an Andy Brown 1450 and a m445 and I can tune a prop to the boat... So I'll get up there eventually. I have plenty of room for Lipos and the next size up in motors but I think this will make a good PLtd hull.
Later,
Ball
I got the Turnfin Bracket done today... This boat is real close to getting wet!!!
high-tech
09-15-2015, 11:50 AM
Putting the finishing touches on this project... I need to fasten the receiver battery in position and build the flex and stub shaft assembly
ray schrauwen
09-15-2015, 04:12 PM
Very nice build!
high-tech
09-16-2015, 07:32 PM
Thanks Ray, I can't wait to get it wet...
Very nice build!
capnswanny
09-16-2015, 08:12 PM
I hope you can post up a video....I would like to see how she does!
high-tech
09-16-2015, 10:04 PM
I've got a decent phone I'll get some video up for sure
high-tech
09-23-2015, 02:52 PM
Well I finally got to the lake this morning and I recorded the Maiden Voyage and she ran pretty good and the temps were cold so I have room for more prop!!! I was running a Graupner K Series 42mm prop 2 2S 5000mah dinogys. I'm gonna order some more Lipos I only have one pair. I'm thinking about the 6000mah 2s dinogys.
https://youtu.be/ZHi7vnCu9_s
tlandauer
09-23-2015, 08:43 PM
:tiphat:
Maiden looks great! It is a wonderful build, thanks for sharing, I love everything you did, don't know how i missed this thread.:doh:
capnswanny
09-23-2015, 10:41 PM
Looking good!! Thanks!!
Makes me want to break mine out :)
high-tech
09-25-2015, 01:13 PM
:tiphat:
We have a retired police officer in our club and he says my dumas was doing about 52mph:banana:
Thanks tlandauer I'm getting ready to put my twist on a JAE 21 FE Kit I just bought from a fellow OSE member, he just couldn't get around to building it and he bought everything so I really got hooked up big time and of course I'll share.
