View Full Version : Need help to compare two props!!!
boilo56
07-10-2015, 08:31 PM
Hi everyone!
I have some difficulties understanding the coding on these props:http://www.hobbyking.com/hobbyking/store/__61600__Turnigy_3_Blade_Boat_Prop_R3P_x_36_x_13_1 pc_.html
Are the the same pich as the stock ones on the Hk C1 Flowmaster?
Thank you for your help!!!
dan pralle
07-10-2015, 09:27 PM
If I had to guess it would be 36mm diameter and a 1.3 pitch ratio
dan pralle
07-10-2015, 09:41 PM
If it was me I would order those and also the 38x14 just check your temps with the bigger props. Does that boat have counter rotating motors ?
boilo56
07-10-2015, 09:49 PM
Yes it does have counter rotating motors. I also ordered the reversed one.
boilo56
07-11-2015, 04:09 PM
Can a lower pitch prop be faster than a higher one? If the Turnigy are really 36 mm/1.3 pitch, and the stock ones are 36 mm/1.4pitch, my boat was 13km/h faster than the stock props. I'm kind of lost here... Can somebody explain to me, please?
kfxguy
07-11-2015, 05:16 PM
If your higher pitch prop is a tad much for your motor to turn it, yes a lower pitch or smaller prop can be faster by letting the motor spin more freely. I've experienced this myself a few times.
boilo56
07-11-2015, 05:26 PM
It can make such a difference? I was at 66.2 and then 77.8 km/h with the 13. This is a huge speed increase for only changing pitch on the prop! I think i'll like those cheap props!
Thanks kfxguy!
kfxguy
07-11-2015, 07:47 PM
Thanks kfxguy!
Yes. Example. My 32" cat went 90 with a 45mm 1.6 pitch on 6s. Then went 95.6 on 7s with the same prop. Then I changed to a 45mm 1.5 pitch prop (which it is a better shape which may be your case too) and ran it again in 6s. It went from 90 to 96 mph with less pitch
boilo56
07-11-2015, 07:55 PM
Ok, now it just jumped into my face!!! Sure, more pitch can result in lower rev/ lower speed with the given pitch. So less pitch allows more revs, meaning the same distance is traveled faster due to more revs!!! Man that is soo cool to understand!!! thanks a lot!!!
kfxguy
07-11-2015, 08:06 PM
I found this out the hard way with my mono.
boilo56
07-11-2015, 08:15 PM
Why? Exploded electronics? Motor? I need to learn!!!! I want knowledge!!!:stupid: me! So seriously, how did you learned it?
kfxguy
07-11-2015, 09:39 PM
Yes the Esc exploded. It did go faster with less pitch. I can't remember speed numbers but i was in the low 80's I think with my 34" mono with an x648 detounged and then switched to a m447 and got into the 90's pulling less amps.
