View Full Version : Twin powered carbon Rivercat build
kfxguy
07-05-2015, 07:45 PM
I've been putting off building a twin. Why? I dunno. I guess I get bored quick and it it takes too long I'll lose interest. Maybe I'm just in denial? I dunno, but I can't back out now. I've been collecting stuff since my other Rivercat sank to build this. I also have another single I'm building but the motor is being custom made so that's gonna take a while. I've already collected everything I need for this one so I guess I might as well start before I back out again haha. Anyway, here's the plan:
Castle 1415 2400kv motors
Seaking 120's with castle cap banks
Lhs waterproof servo
Ose .187 flexes
Custom built ball bearing drives.
32" carbon hull
Octura stainless collets
Center mount rudder
Carbon motor mounts. These are neat because you put screws in the motor, slide in the big holes, then twist the motor a tad and tighten
Ose cooling jackets
Cnc 442 props to start then abc 1615-17-45 counter rotating beasts after
3s or 4s pack per motor
Dual cooling
http://i218.photobucket.com/albums/cc243/ltzguy/FC5418E0-A87A-4C64-9E3F-253B9C372819.jpg (http://s218.photobucket.com/user/ltzguy/media/FC5418E0-A87A-4C64-9E3F-253B9C372819.jpg.html)
kfxguy
07-05-2015, 07:54 PM
I just got through making the drives. I'm using carbon tubes. One size the 5 ball bearings go into. Then there's a tube epoxied into the larger tube that the bearing back up to and the 1/4" brass slides in. After much research and talking to Rocstar and Keith, I've decided on fixed drives. They will be fixed level. I'll have to make any adjustments with Cg and prop choice/mods.
http://i218.photobucket.com/albums/cc243/ltzguy/F6E1D4E0-C2AF-4949-9C2D-ADC1ED78EB89.jpg (http://s218.photobucket.com/user/ltzguy/media/F6E1D4E0-C2AF-4949-9C2D-ADC1ED78EB89.jpg.html)
http://i218.photobucket.com/albums/cc243/ltzguy/770E5D5B-A9E5-4ECA-B3A0-6069DC13E492.jpg (http://s218.photobucket.com/user/ltzguy/media/770E5D5B-A9E5-4ECA-B3A0-6069DC13E492.jpg.html)
http://i218.photobucket.com/albums/cc243/ltzguy/55766F0E-82D8-4D4A-8A83-301C71A814FC.jpg (http://s218.photobucket.com/user/ltzguy/media/55766F0E-82D8-4D4A-8A83-301C71A814FC.jpg.html)
kfxguy
07-05-2015, 08:31 PM
It's sitting in a bucket of water right now. Poured 20 grams of epoxy and chopped Carbon in each tip and the tunnel. The water helps to keep the heat down in the tips while the epoxy cures
http://i218.photobucket.com/albums/cc243/ltzguy/5DF4D3A3-21EC-43DB-84B9-A064E46F99A5.jpg (http://s218.photobucket.com/user/ltzguy/media/5DF4D3A3-21EC-43DB-84B9-A064E46F99A5.jpg.html)
dmitry100
07-06-2015, 02:52 AM
You sure love those rivercats, man!
What kind of inlay are you going to be doing for it... CF? Wouldn't mind to see how you lay that stuff down on that thing if you are.
kfxguy
07-06-2015, 07:13 AM
Yea I guess so, I had a couple more of these hulls so why not? Lol. I'll be doing a regular weave carbon inlay in it. What did you want me to show?
Apophis
07-06-2015, 12:11 PM
Uh oh, you know what they say, once you have twins you never....
Oh wait that's something else :lol:
Travis building a twin, something must of froze over lol!
Looking forward to the build, curious to see your drives.
kfxguy
07-06-2015, 12:28 PM
Lol. See those two carbon tubes with the bearings? That's the drives, not much to them. They will be braced at the overhang of the transom. I may end up switching motors but these will do for now. I figure it should do 70ish on 4s per motor. Heck, my little mono is doing almost 62 on 4s with one motor so I'm sure it's doable.
dasboata
07-06-2015, 01:05 PM
try 2 part foam Travis I have been using it for 30 years in model boat builds it adds strength and flotation, I also use it around the hull to deck joint to straighten it I do use Aeromarine brand but pretty much all the same, just don't use great stuff home depot stuff,,,,,,,,,,,,, LOL http://www.ebay.com/itm/Two-Part-Liquid-Urethane-Expanding-Foam-2-LB-Density-4-LB-Kit-/111701333600?pt=LH_DefaultDomain_0&hash=item1a01eb1660
kfxguy
07-06-2015, 01:20 PM
That's all I use. I've been using us composites 2lb foam but I had a "foam day" Saturday and ran out so I ordered some from elite motoring on eBay. I had to do 4 boats Saturday so I used up a lot. I did an experiment yesterday.....in one of my boats you can see the foam and the tan color looks bad....so I added some black epoxy dye to it....turned it carbon grey. Worked perfect so I may be doing this for now on....
dmitry100
07-06-2015, 03:13 PM
dasbota: Whats so bad about the Great Stuff foam to fill the void in the tips? ;) Is it too heavy of a foam?
kfxguy
07-06-2015, 03:49 PM
The way it expands is from oxygen getting to it...so what happens is the area exposed expands first, hardens and then the inner part slowly hardens. It takes the path of least resistance, usually busting open the hull. And I speak from experience, I had an extra hull and tried it. Yea, never do that again. The two part works great because it cures from a chemical reaction.
dasboata
07-07-2015, 09:35 AM
Plus the pour in makes for a very nice finish,,, the great stuff will expand more when you bring the boat in the sun !
dmitry100
07-07-2015, 02:13 PM
dasboata: Do you know if they sell any of that Composite foam in smaller amounts? like 2LB worth? or is the 2 part foam from Kintecracing for $10 bucks just as good?
Product description of the one from Kintec:
"Expandable Marine Foam: This expandable 2 part polyurethane water proof flotation boat foam is low density and closed cell. It weighs 2 pounds per cubic foot. Each kit contains 3oz of each part A and B. $10.00 per kit."
kfxguy
07-08-2015, 01:02 AM
Got a little done tonight. Didn't get the inlay done but got the carbon cut out. Then I laid several pieces in the transom area. Hard to get in there so I had to do it in pieces. I also made a thick aluminum plate that reinforces the rudder mount area and I can drill and tap right into it. If you e ever had to get to the nuts in one of these hulls, you know why it's easier this way. I flooded the transom area with epoxy and chopped carbon fiber too. Im going to put epoxy and chopped carbon in the bottom of the sponsons where it recesses. Nothing special but the little plate I made.
http://i218.photobucket.com/albums/cc243/ltzguy/6419C99B-3A64-4B97-99B0-29C5C3950593.jpg (http://s218.photobucket.com/user/ltzguy/media/6419C99B-3A64-4B97-99B0-29C5C3950593.jpg.html)
Fella1340
07-08-2015, 05:25 PM
I can't believe what I'm reading, twins! Look forward to seeing how the drives work out.
dmitry100
07-09-2015, 03:33 PM
Is weight a concern when filling those tips with epoxy/carbon? I'm thinking to fill the tips with epoxy/micro balloons/fiberglass millings and redo the foam on the front of my hull... as I have great stuff foam in there right now lol. Dasboata kind of changed my mind about using it. Thought it'd work just as well and could absorb impacts, etc.... guess not.
I just wouldn't know how much epoxy I should be using in the tips... and don't want to go overboard by putting too much and adding more weight than necessary.
Also, how far into the hull do you lay the carbon cloth... as soon as the foam starts or closer to the tips?
kfxguy
07-09-2015, 05:17 PM
These hulls are light to start with. A little extra weight actually helps to keep it down at high speeds. I actually sand as far up as I can and put carbon as far as I can reach. My inlay piece is 14.5" x 16". I need to show pics on how I'm doing this one but I've used a couple separate pieces in the transom area to get all back there. The foam and the inlay do join. The foam does add some strength to it. I add epoxy and chopped carbon to the whole bottom on the sponsons from front to rear. I'm also trying to come up with a way to make a sanding tool to reach farther up towards the tip so I can sand the seam. I want to add a strip of carbon across the seam. I'm trying not to make this boat too heavy as its already going to have two motors and two escs. I wish I could use one big Esc to drive both motors. That would be awesome.
http://alienpowersystem.com/shop/boat-esc/alien-300a-3-12s-boat-esc-hv-twin/
The owner/builder of these power systems, Bruno, is super nice and very helpful. I have one of his surface controllers running my Losi 5ive T with a Castle 2028 motor on 12s. It is a Beast!
The controller I linked here is not in stock, but shoot him an email, perhaps he would put a custom one together for you!
kfxguy
07-10-2015, 07:05 AM
Finally got the inlay done.
http://i218.photobucket.com/albums/cc243/ltzguy/540030B7-1EEF-4F0F-9417-C2DCB0C3D56B.jpg (http://s218.photobucket.com/user/ltzguy/media/540030B7-1EEF-4F0F-9417-C2DCB0C3D56B.jpg.html)
kfxguy
07-10-2015, 07:57 AM
I wanted to try out a tp motor because I was thinking about changing kv to a little higher if this boat runs right. I ordered a 3040 a few days ago from straight from tp (I checked ose store first and they don't carry them) and it showed up yesterday. They started screwing on the end caps instead of glueing them. Good move. The older tp motors I've run across were glued so I'm not sure how long ago they started screwing them. I've go a boat to try this one out to directly compare with the same case motors I'm running in here. So I should know this weekend how these little motors fair. It's exactly the same size as a 1415.
http://i218.photobucket.com/albums/cc243/ltzguy/8D734C79-C2FB-4AD6-919F-6CAA990321DD.jpg (http://s218.photobucket.com/user/ltzguy/media/8D734C79-C2FB-4AD6-919F-6CAA990321DD.jpg.html)
dmitry100
07-10-2015, 08:09 PM
Why not TP 4050's ? It would probably haul alot of ass on a small hull like that :)
Btw, how short is too short when shortening the motor wires on these TP's ? They shouldn't be like the Neu's where they are soldered onto the winding wires and cause issues if they are too short or overheated when soldering right. I was thinking to leave only like 1-2 inches max... Seemed like the cleaner way to go since the SF motor leads are long enough and would remain untouched.
kfxguy
07-10-2015, 08:19 PM
Yea a 40mm motor don't fit. I've got to squeeze these is as it is. I also have to watch the weight on this thing too.
You can't cut these wires. They are hard ones like the neu motors. These motors are actually built pretty well. I may be switching the castles out. These look better too. Trying to get the drives installed tonight. It'll be downhill shortly.
Brushless55
07-10-2015, 08:47 PM
Really looking forward to what you think of the TP vs the Castle 1415
kfxguy
07-10-2015, 11:27 PM
Well I wanted to take some pics but you won't see much. The drives are being tacked in place and the boat is taped to a glass table with the drive tubes shimmed and clamped in place in a level position. I'll take some pics tomorow and I've also got to make some sort of braces for them. One flip at high speed and they may break off. Stay tuned.
dmitry100
07-11-2015, 12:38 AM
kfxguy: So no point of shortening these motor wires at all then? I'm assuming long battery wires are the most important...
kfxguy
07-11-2015, 07:11 AM
Shorter wires are always better but these are already short somewhat and these are the type you can't shorten because of the coating on the wires.
kfxguy
07-11-2015, 07:14 AM
Here's the drive tubes. I've got to make some supports and support blocks when get home this evening
http://i218.photobucket.com/albums/cc243/ltzguy/DF336B92-1865-4634-8C23-FDFE6A02D972.jpg (http://s218.photobucket.com/user/ltzguy/media/DF336B92-1865-4634-8C23-FDFE6A02D972.jpg.html)
http://i218.photobucket.com/albums/cc243/ltzguy/A1FBCA4F-D73D-4D6F-AD78-29A68C12A433.jpg (http://s218.photobucket.com/user/ltzguy/media/A1FBCA4F-D73D-4D6F-AD78-29A68C12A433.jpg.html)
Fella1340
07-11-2015, 07:07 PM
They sure look cool! You would know much better than most if running a fixed strut will give you what you need. Did you find most boats, singles included end up with the strut or stinger in the neutral position once dialed in? I'm looking forward to seeing this come together and you on the water with a twin, finally!
kfxguy
07-11-2015, 07:35 PM
I'm kinda just winging it lol. I guess I've got a decent knowledge base to get somewhere. Everything I've built fast liked the strut level at high speed for sure. At lower speeds some like a little positive. It's gonna take a couple days to finish these struts. They were just tacked in in the pics. Now I'm epoxying them from the inside. Then an aluminum block for support on the outside along with a 3mm plate from the overhang to the tube.
srislash
07-11-2015, 10:25 PM
I really like the look there Travis. Maybe make sure you have plenty of CG adjustment to deal with that fixed stinger setup.
kfxguy
07-11-2015, 10:44 PM
Yea.....in this little hull I won't have much adjustment. I'm going to mount the motors first because I have no choice where they go, then I will mount the battery trays. Put batteries in. Then start laying out the rest of the stuff to set my Cg where my other rivercats were. I'll probably end up doing the Cg a tad further up because the twin props will likely give me more bow lift than a single prop. Then there is always a little ballast I can add. I'll do my best!
kfxguy
07-12-2015, 09:18 PM
The tp did go a little faster but ran noticeably hotter. The tp went 64.5 and the castle went 61.8
littlepooper206
07-14-2015, 06:07 AM
How much of the carbon drive shaft "tube" is in the hull ? Do you think it would help to have a good amount of the carbon tube in the hull so that you can attach them and get a good bite of support for them?, Well besides the normal support under the rear overhang of the hull where the support point comes down and attaches to the shafts when it comes to the drives ? Im just wondering for myself because when i saw this i really liked the idea and would like to try and implement the idea of your drives "carbon tubes" and i would like to put them on my next build... But if that is alright with you first of all ? If you object i will understand but if your cool with me borrowing your idea that would be great. I look forward for your reply on my many questions i have asked ya lol
kfxguy
07-14-2015, 09:43 AM
I have a little more than 1/2"'coming in the hull. Keep in mind that things are tight with this little hull and I'm running fairly large motors. Your welcome to do this if you like but I must warn you, it's a pita. It's hard keeping them lined up while the epoxy is drying. I had to jb weld the bearings in because the loctite sleeve retainer didn't hold them. Also put the bearings in last because I had to run a drill bit through the tubes because epoxy ran into the tubes (so it's a good thing the loctite didn't hold!!). I tacked one motor in place last night. I have had much time with it as I'm bouncing between 5 builds at once right now. I'll have to set my Cg once the motors are in place.
http://i218.photobucket.com/albums/cc243/ltzguy/74D4E44E-737E-4E32-AEFE-724B380BEBB3.jpg (http://s218.photobucket.com/user/ltzguy/media/74D4E44E-737E-4E32-AEFE-724B380BEBB3.jpg.html)
RCKong
07-14-2015, 04:21 PM
With those stingers you made, looks like moving your packs back and forth will be your only adjustment. Are your motors back far enough ? you might want to get those motors to the back as far as you can if you are putting your packs in the sponsons.
I hear ya about being a PITA... I built one of these out of spare parts and it is VERY useful installing bolts in these things. 134477
kfxguy
07-14-2015, 04:33 PM
Man I have some awesome motor mounts. They are twist slotted. You loosen the screws a touch and twist motor and come right out. Easy.
I could not move the motor any further back because of the motor length and angle. Where it's at is as far back as I can get it. I'll figure it out. I have some ideas and I also know what the Cg needs to be on this hull.
RCKong
07-14-2015, 04:47 PM
I could not move the motor any further back because of the motor length and angle I see what your saying. do you build the motor mounts ? i like the twist out mounts but not confident enough to make the slot and mount hole right.
kfxguy
07-14-2015, 05:19 PM
I had Monojeff make them for me. I'll post a pic of the other. I have a template to trace if I ever need to. Once I get my cnc up and running (yea I still haven't fooled with it, been too busy) then I'll make a file for them.
kfxguy
07-14-2015, 11:41 PM
Here's a short video I made just for you :)
http://youtu.be/b23VStItVss
RCKong
07-14-2015, 11:58 PM
Man I'd get spoiled havin it that easy... LOL
kfxguy
07-15-2015, 12:57 AM
That's how I roll...I'm not fighting with screws in that little space.
kfxguy
07-15-2015, 10:06 AM
Guys, give me some ideas on how to support those drive tubes. I'm not crazy about just gluing some carbon plate to them and calling it a day.....
Brushless55
07-15-2015, 10:34 PM
Thanks for the update :thumbup1:
keithbradley
07-15-2015, 10:38 PM
Are you familiar with "The force"?
kfxguy
07-15-2015, 10:41 PM
Lol
keithbradley
07-15-2015, 10:51 PM
I typically machine mine out of aluminum, with a threaded hole and grub screw at the top, or make a "clamp" from aluminum or carbon fiber. Do you know what I mean?
kfxguy
07-16-2015, 02:18 PM
I'm not very happy how the epoxy came out on the motor mounts. My fault. For one I decided to use west systems with some colloidal silica. Well I must have a bad batch of it because mine has clumps and I've got to mix it forever to get it mixed. But it leaves little air bubbles from the mixing, even if I apply heat to it, the bubbles stay. So luckily I didn't do the whole mount that way, I ended up switching to west systems and some chopped carbon. Those areas look better so I'm going to go over the other areas with it. I also coated the brass tube with 5 minute epoxy dyed black so I don't see an ugly gold tube. It's just for looks an looks pretty good. Had I known I had some carbon sleeve laying around I would have done the tubes in that. But when I found the sleeve I had already glued them in. O well, my next build I'll do that. This thing has no dang room so there not much I can do anyway.
http://i218.photobucket.com/albums/cc243/ltzguy/644134F5-9BB4-4094-A064-EB8888142990.jpg (http://s218.photobucket.com/user/ltzguy/media/644134F5-9BB4-4094-A064-EB8888142990.jpg.html)
Luck as a Constant
07-16-2015, 05:48 PM
An easier way to make your stuffing tubes black is to just put some heat shrink over them
Mxkid261
07-16-2015, 05:50 PM
Man that has to be super tight in there Lol, I thought it was tight working on my single but that looks real fun. Those motor mounts look super trick!!
Mxkid261
07-16-2015, 05:54 PM
Also, Im just curious how far in the sponson your drive tubes go?
kfxguy
07-16-2015, 08:05 PM
I thought about heat shrink but it would be hard to replace it on the other side of the stuffing tube support that I haven't made just yet. The epoxy does look good tho.
kfxguy
07-16-2015, 08:10 PM
Bout little more than 1/2"
keithbradley
07-16-2015, 09:02 PM
Travis, are you mixing with a brush or a tongue depressor (or something else)? A brush will put a lot more air into the mixture.
Also, if you ever do make the bayonet mounts yourself, consider the (counter) rotation of the motors and make them appropriately (left and right versions). Otherwise, with powerful motors, they can spin off the mount over time.
I think you will love the twin. Have you considered what props you will be running yet?
kfxguy
07-16-2015, 10:51 PM
The way the slots are cut, the rotation on the motors force them to stay at the end of the slot instead of twisting it out to the hole on the end. I'm mixing imwith a mixing stick. I may be mixing it too fast. I'll adjust my speed. I'm pretty stressed out at the moment as I put an aluminum backing plate in the transom so I can drill and tap it so I don't have to fight with the nuts down in that tight area and while tapping it, I broke the tap off in it. Let me tell you there was almost a bunch of holes punched in the wall. Luckily I was mounting the rudder up high and I ended up moving it down some and it looks better any way.
Props... Well I've got some cnc 442's to start off with. Then I've got some abc 1615's and 1715's for it.
keithbradley
07-16-2015, 11:19 PM
So they are left and right (the motor mounts)? Are they made to spin the motors so the props rotate in, or out?
Been there with the tap man...What a giant pain that can be. :thumbdown: :sad:
lt130th
07-16-2015, 11:59 PM
Inboard rotation would keep the motors torqued into the slots. The mounts that tiqueman sent with my Shocker share the same direction in the twist slots, but they also have the top and bottom hole for four-bolt config, that will keep it locked in. Looks like Travis' mounts are the same. Is this not common for carbon plate motor mounts, cut to the sponson contour (the twist slots)?
134523
By the way, Travis, you better hurry up and finish this twin build so you can stay caught up with current trends. Keith is about to start building twin turbine HPR's (unless you just bought that bundle 'cause you didn't know what else to spend $15K on, haha). The next thing you know, everyone will be putting JetCat's in their Daytonas and Fantasms.
kfxguy
07-17-2015, 12:42 AM
I just double checked. I have a left and right. Truth: first time building a twin. The motor mount direction is not something I thought about. Until now. I had planned on making the right side prop spin ccw and the left side spin clockwise. I guess this is called spinning inwards? Well just so happens the mounts are setup this way. I guess I had a 50/50 chance and I got lucky.
I got the servo mounted tonight a lot with the steering rod made up and mounted. All I've got left is a pass through fitting I have to machine for the boot to seal to. I'm thinking about a trim cover to cover the escs, bec, receiver and servo. I've got to figure out a shape I guess.
I also mocked most of it up. The Cg seems like it's going to end up exactly where I want it. It was an 1/8" forward of the Cg from my previous rivercats. I keep thinking that two props may create a little more bow lift than a single prop. I could be wrong.
kfxguy
07-17-2015, 07:59 AM
Nothing special, just a couple pics of where I'm at.
http://i218.photobucket.com/albums/cc243/ltzguy/A2006367-3375-45B5-AC0C-41B86841BE4D.jpg (http://s218.photobucket.com/user/ltzguy/media/A2006367-3375-45B5-AC0C-41B86841BE4D.jpg.html)
http://i218.photobucket.com/albums/cc243/ltzguy/88ABA111-21D0-40C8-91B4-C488B628AFF4.jpg (http://s218.photobucket.com/user/ltzguy/media/88ABA111-21D0-40C8-91B4-C488B628AFF4.jpg.html)
I'm really digging all the custom Carbon Fiber on this build! Awesome!!:buttrock:
dmitry100
07-17-2015, 01:24 PM
Btw, wouldn't you have alot more space in the overall motor's length area if the motors mounts were not mounted so much at a downwards angle? Or is that done to keep water from coming out from the stuffing tubes?
Also, are you using any particular kind of servo rod there for the rudder... is it a typical 2mm in thickness rod?
kfxguy
07-17-2015, 01:42 PM
1) the motors are as low as I can fit them. As a matter of fact I had to clearance some epoxy because the cooling jacket was hitting. The motors have to be at an angle, if they weren't, you'd never get the flex lined up unless you did an s bend. I'm not a fan of s bends.
2) for mockup I'm using a 4-40 rod. I'm likely going to be swapping that out for a thicker rod. I do have some carbon rod but I have to have a slight bend in the rod so carbon will not work.
srislash
07-17-2015, 06:32 PM
And on this note, I do have a few prop choices here if you want to try them Travis, 4019/2, 4019/4, 4217/3, 4513/2, 4518/2... May have a few more but I am just throwing them out there buddy. Just letting you know you can try em.
kfxguy
07-17-2015, 08:16 PM
Thanks buddy! I'll let you know if I need anything.
Should I run seperate cooling lines or can I split them? I plan on drilling the fittings for mor flow and using larger line. Thoughts?
kfxguy
07-17-2015, 09:44 PM
Getting it wired up. Checked the Cg again and it's sooooo close to what I want it at. I think once the trim plate and flexes are added, it will be dead on. Hopefully. Lol.
http://i218.photobucket.com/albums/cc243/ltzguy/5D769747-831D-494F-9ED5-DFB618A2FF57.jpg (http://s218.photobucket.com/user/ltzguy/media/5D769747-831D-494F-9ED5-DFB618A2FF57.jpg.html)
Of course the wires will be tidied up but this shows the layout. I wasn't sure how I was doing it until tonight. Winging it I guess on this part.
http://i218.photobucket.com/albums/cc243/ltzguy/24DEBDD8-3FBD-402A-A31C-D95C57254EBA.jpg (http://s218.photobucket.com/user/ltzguy/media/24DEBDD8-3FBD-402A-A31C-D95C57254EBA.jpg.html)
srislash
07-18-2015, 10:28 AM
I would think splitting the cooling lines would be adequate Travis. I usually do thru hull pickups for each side but I am talking larger hulls here. At first look it looks like you would have too much rear CG there but then your packs are going to be hefty for this size hull. I found 32% right on the Fantasm with the ABC's but there is a ton of neg dialed in as well.
dmitry100
07-18-2015, 05:37 PM
kfxguy: How do you check Cg ?
kfxguy
07-18-2015, 05:56 PM
Well I've always been a build it how everything fits kind of guy but when you try to approach high high speeds, little things like this make a difference. So I put it on a 3/4" round rod and measure where it balances.
dmitry100
07-18-2015, 08:47 PM
What kind of water jackets are those? They look like some nice heavy duty ones.
Was actually thinking to upgrade the TP jackets I have for better cooling... I think those 1715 props might be heating things up like the 448's. (Clocked about 87 mph first them with them btw on the short distance run using a 10hz refresh Garmin Glo). :)
kfxguy
07-18-2015, 09:12 PM
I have 36mm motors so keep that in mind. I get those jackets from the ose store. Second page. They are for a fiago motor or something weird but they work perfect.
dmitry100
07-21-2015, 01:50 PM
kfxguy: What are those carbon fiber looking jackets you sometimes use? Do you custom make them yourself?
kfxguy
07-21-2015, 01:59 PM
I made one out of carbon tube once and mostly it's very thin carbon that I epoxy around a cooling jacket. I was thinking about doing it on this boat.
Fella1340
07-21-2015, 03:25 PM
Looking great Travis. How do you like building a twin versus a single? You mentioned the carbon fiber sleeve awhile back. I sent that to you after your second build. I was wondering when it might show up in a boat. I thought they may be more trouble than there worth, make sure the tube is already black before using or you'll be seeing gold through the sleeve fabric.
I'm excited for you on this build, you've pulled almost 100 with a single. Will double the cost and work of twins be worthwhile on this size cat (for sport running). You could do a comparison, say you hit 110 mph, what did each additional mph cost over your previous best as a single. I could see it getting into the $100 plus for each additional mph. I hope you end up liking twins a lot, you can really start pushing the envelope then!! You are a boat building machine, keep it up😀. Sorry for rambling so much, not really.
kfxguy
07-21-2015, 04:26 PM
I'm excited for you on this build, you've pulled almost 100 with a single. Will double the cost and work of twins be worthwhile on this size cat (for sport running). You could do a comparison, say you hit 110 mph, what did each additional mph cost over your previous best as a single. I could see it getting into the $100 plus for each additional mph. I hope you end up liking twins a lot, you can really start pushing the envelope then!! You are a boat building machine, keep it up. Sorry for rambling so much, not really.
Had I remembered I had that sleeve you sent me before I epoxied in the first tube, I would have used it. I tried it an an experiment on a piece of brass and the weave on it is thick enough you don't see brass through it. Honestly this build cost me less that a high end single build. These motors are cheap and so are the escs. It definitely cost me a lot less than my last Rivercat. That motor in there was $450. At this point if it does 75-80 I'd be happy. That's all I expect out of this setup. If the boat is stable then I will move forward with getting more out of it.
keithbradley
07-21-2015, 10:10 PM
Dude, you're going to love this thing. When comparing a single to a twin, don't think in terms of speed. After all, the FASTEST official record by an RC boat is held by a single motor/prop machine. Single prop boats are actually more efficient than twin prop boats, in the same manner that 2 blade props are more efficient than 4 blade props.
However, using two motors helps to unload the boat and make aggressive setups more reliable and "sport" worthy. It also completely changes the way a boat handles and accelerates. Nothing drives like a TWIN!
kfxguy
07-23-2015, 11:42 AM
Wife has been restricting my shop time during the week lol (says I don't spend enough family time and she's right) so I haven't made much progress. I did wore it up really quick last night and run most of the cooling lines. Bonded the receiver and Calibrated escs. Did a bench test and everything is working properly. I really need a set of collets now. My pinion adaptor sleeves I had in the collets allow too much runout and I'm not doing that. Vibrates too much too. Not good. If anyone has any ideas where to get some 1/8 to .187 collets from let me know. Right now the plan is I ordered a set of octura 1/8 to 4mm that I was going to drill in my lathe .030 bigger.
http://i218.photobucket.com/albums/cc243/ltzguy/65522CF9-6887-40F5-8F0B-91A4BF2541DC.jpg (http://s218.photobucket.com/user/ltzguy/media/65522CF9-6887-40F5-8F0B-91A4BF2541DC.jpg.html)
http://i218.photobucket.com/albums/cc243/ltzguy/988787C7-DAD0-4E17-A012-ECFB13B16627.jpg (http://s218.photobucket.com/user/ltzguy/media/988787C7-DAD0-4E17-A012-ECFB13B16627.jpg.html)
What can I put up front? It looks so empty! Lol
dmitry100
07-23-2015, 12:02 PM
You should throw in 2 of these >> http://www.rc-raceboats.de/shop/lng/en/lmt-basic-xxl.html
kfxguy
07-23-2015, 01:02 PM
Yea I have no idea how this boat is even going to run so I hate to spend that much money on it. Im probably going to buy a set of tp motors if I can't find collets. I could make my own but at this point time is money and I don't have the time, I'd rather buy them or buy new motors to save time. No to mention I don't have ac in the shop that my lathe is in and it's been in the high 90's here lately. Yea, I'd rather buy new motors lol.
kfxguy
07-23-2015, 01:59 PM
O well. I ordered a pair of tp 3640 motors and had them 2 day shipped. Don't like waiting and I don't like rigging something up that needs to be perfectly centered.
dmitry100
07-23-2015, 07:57 PM
Btw, any ideas where I can buy a double sided carbon fiber servo horn? I'm sure I seen you use some in the past... but This is the closest thing I found >> http://www.hobbyking.com/hobbyking/store/__10072__Carbon_Fiber_servo_arm_58mm_2pcs_bag_.htm l
Just not sure how I would mount it. I think it'd make things look nice...
readyfireaim
07-24-2015, 12:12 AM
What KV are those 3640?
kfxguy
07-24-2015, 08:53 AM
2540kv I'll be running 3s for sport and 4s for speed. I'm not dead set on these, I may get a set of neu 1415's if the boat runs good
kfxguy
You screw it to a round servo horn.
dmitry100
07-25-2015, 02:01 AM
Have you considered maybe running some Wolt's wire drives for this? I think it would work perfect since you have fixed angle drives..
kfxguy
07-25-2015, 03:03 AM
I have too much of an angle.
readyfireaim
07-25-2015, 01:05 PM
Are you gonna be able to get her in the water this weekend?
kfxguy
07-25-2015, 01:19 PM
Not unless my collets make it here. I paid for two day shipping from tp and bought them in the morning but for some reason they shipped yesterday instead of Thursday.
dmitry100
07-25-2015, 03:19 PM
Yea. TP has a bit of a shipping delay. Maybe I'm just spoiled by Amazon's same day processing + 2 day free shipping.
kfxguy
07-25-2015, 04:22 PM
Yea. I left them a note in the note section. They apologized and said it won't be here till Monday. Collets didn't come either. On a positive note my replacement screen for my iPhone 6 I shattered the other day, showed up and some really nice battery straps I'm trying out showed up too.
dmitry100
07-25-2015, 06:19 PM
I really don't like velcro straps... mostly because they almost always tear in a flip, etc.
Unless you're using some sort of industrial velcro. But you can also stick some of this on the bottom of the batteries so that they don't move around:
http://www.amazon.com/VELCRO-Industrial-Strength-Wide-Black/dp/B00006RSP1/ref=sr_1_1?ie=UTF8&qid=1437862494&sr=8-1&keywords=velcro+heavy+duty
http://www.amazon.com/VELCRO-Industrial-Strength-Extreme-Titanium/dp/B005756516/ref=sr_1_2?ie=UTF8&qid=1437862495&sr=8-2&keywords=velcro+industrial+strength
You can prob use the Extreme one w/o straps (sticking them on the batteries) and it would prob hold just fine since its super strong.
Regular velcro tears off really easily... so I bought myself some reusable/releaseable cable ties: http://www.amazon.com/Monoprice-105801-12-Inch50LBS-Discontinued-Manufacturer/dp/B004C4U3KM/ref=sr_1_3?ie=UTF8&qid=1437862712&sr=8-3&keywords=cable+ties+reusable+12+inch
BTW ... What are you using for the weather seal on your hatches? You mentioned it somewhere just don't remember where...
kfxguy
07-25-2015, 07:10 PM
I use straps with a buckle on it. I've never had one let go. I use Velcro on the battery and battery tray to keep it from sliding out the straps. I've crashed many times over 90mph and never had them let go. I use only the industrial Velcro. I would trust just Velcro with no straps at the speeds I'm doing. The battery would most definitely come loose then it may hit something in the inside of the boat and get punctured.
I use a thin narrow foam seal on my hatches. I got most of it from Keith Bradly but I found an alternate source in Florida to get some stuff almost as good. I need to post more details during this build I see. I'll try to find time.
kfxguy
07-29-2015, 10:36 AM
I got the tp motors in last night. They fit much better. I forgot to take a pic. Get to it tonight.
larryrose11
07-29-2015, 01:20 PM
Subscribed
kfxguy
07-29-2015, 03:06 PM
Any ideas to dress up the plainness of it? The front part is just too empty. What about a pair of voltage gauges for each power system?
readyfireaim
07-31-2015, 01:22 AM
How did you end up supporting those drive tubes?
kfxguy
07-31-2015, 09:00 AM
I haven't yet. I was going to run it on 3s and small props first to see how the ride attitude is. Then I'm going to epoxy 3mm carbon plate to lock them in place.
kfxguy
08-01-2015, 09:29 PM
Nothing special but a crucial part of the build. The linkage boot fitting. I always make my own for several reasons. One is because the diameter is smaller allowing the small boot I use to fit better. Then I make a smaller hole in it where the rod passes through. I find this stops a lot of bending and deflection the rod could have. This linkage is pretty much a straight shot and I want it tight as can be. I also make my own because I reinforce the transom with epoxy and chopped carbon so it has to be able to pass all the way through it of course.
http://i218.photobucket.com/albums/cc243/ltzguy/BF5945B7-488C-422B-8381-CAAC0B5F7127.jpg (http://s218.photobucket.com/user/ltzguy/media/BF5945B7-488C-422B-8381-CAAC0B5F7127.jpg.html)
I also got these little things in. I'm making som trim plates to flush mount them in to give me the voltage of each individual battery. They are able to be calibrated so I calibrated them exactly the same with my multi meter. They are perfect size with a number display at .300" tall.
http://i218.photobucket.com/albums/cc243/ltzguy/6BE85FE7-047D-4B03-964A-AC46849BA4AA.jpg (http://s218.photobucket.com/user/ltzguy/media/6BE85FE7-047D-4B03-964A-AC46849BA4AA.jpg.html)
kfxguy
08-01-2015, 09:50 PM
And how it looks. It's jb welded in. Perfect spacing.
http://i218.photobucket.com/albums/cc243/ltzguy/3E3CC828-AB8D-4466-88AF-D1DEEAE5DA3E.jpg (http://s218.photobucket.com/user/ltzguy/media/3E3CC828-AB8D-4466-88AF-D1DEEAE5DA3E.jpg.html)
kfxguy
08-05-2015, 04:14 PM
So the hold up is I'm having custom battery trays made and some trim plates made. Monojeff is cutting all of it out for me. Sent me some pics last night and I'm excited. I drew up the trim plates the other day and he's gonna do them this week too. The battery gauges will be flush mounted in a lower tier plate. The trim plates are going to be overlapping and two levels. Then there will be a spot for a gps. Should turn out pretty nice! I can't wait!
Fella1340
08-05-2015, 10:56 PM
Sweet looking boat man! I'm digging your doing a twin and your going all out on it. Just finish it and get it in the water!!
kfxguy
08-05-2015, 11:25 PM
Thanks! I'm thinking about painting something on it while I wait for parts. Or I can have the wife cut me some vinyl out. Honestly I could run it the way it is without battery trays but there's no need to rush it. I am anxious to see how it's gonna run.
kfxguy
08-07-2015, 09:10 PM
Monojeff just cut out my trim plates. Awesome!!! I can't wait. He also cut my battery trays. Should have it all mid week and finish this thing up. I think it's gonna turn out nice. He didn't have time to deburr the plates if he was shipping them today. I was plenty on with that. I can sure sand the edges myself if I get them quicker! Excited!
http://i218.photobucket.com/albums/cc243/ltzguy/DF8BF6C9-76CF-41B9-915E-FC91497DFCA2.jpg (http://s218.photobucket.com/user/ltzguy/media/DF8BF6C9-76CF-41B9-915E-FC91497DFCA2.jpg.html)
http://i218.photobucket.com/albums/cc243/ltzguy/10339DBA-DD09-4379-9F66-D4A6518719C3.jpg (http://s218.photobucket.com/user/ltzguy/media/10339DBA-DD09-4379-9F66-D4A6518719C3.jpg.html)
The voltage gauge plate is going to look sweet! Can't wait to see that completed!
monojeff
08-07-2015, 09:49 PM
Here is a photo of one of the plates that is all clean and pretty.
The one with the ragged edges was when the bit started to get dull but easily sanded/filed smooth.
kfxguy
08-07-2015, 10:32 PM
I can't wait either. Gonna have the wife cut a decal out or something so it's not so plain. Maybe say "Rivercat twin" or something. In green of course.
monojeff
08-07-2015, 10:46 PM
Funny it would have use to been ill have Jeff cut me a decal for the plate.
I been replaced. :(
Glad your having success in house and she is enjoying it and making things work!
I've got bigger fish to fry and carbon dust to make!
kfxguy
08-07-2015, 11:05 PM
I been replaced. :(
Lol, if you insist! I was almost going to have you engrave something but I wasn't sure what.
monojeff
08-08-2015, 12:37 AM
I was thinking the same thing on the engraving!
You could even paint fill it for a neat new look.
kfxguy
08-10-2015, 10:16 PM
Here's the plate with the voltage gauges. Turned out nice I think.
http://i218.photobucket.com/albums/cc243/ltzguy/188FA9ED-9F4B-4A20-8F54-4BAD699E35E7.jpg (http://s218.photobucket.com/user/ltzguy/media/188FA9ED-9F4B-4A20-8F54-4BAD699E35E7.jpg.html)
Mxkid261
08-10-2015, 10:55 PM
Very cool those look handy, are those just tied into each of your batteries?
kfxguy
08-11-2015, 12:24 AM
Yes that's how they will be hooked up, individual to each battery.
readyfireaim
08-11-2015, 02:17 PM
Lookin good. I'm really looking forward to seeing this baby hit the water!
Mxkid261
08-11-2015, 03:03 PM
Is the plate with the volt gauges your ESC top plate also?
Fella1340
08-11-2015, 05:09 PM
I'm liking the gauges, they look sharp and are good insurance as a last check before the deck goes on. I may use them in one of my boats if I ever get one in the water:-/ How many boats do you have in progress right now?
kfxguy
08-11-2015, 05:18 PM
No, it's going to baca two layer trim plate assy. I'll get it done soon and post some pics.
kfxguy
08-11-2015, 05:22 PM
Thx. It took a while to find these things. They are two wire and very small and adjustable.
O man. I got quite a list. I've been turning people down. I don't even have a running boat for myself right now except my mini Rivercat. The mono is pretty much done but I haven't bent tested it yet and programmed the Esc. Maybe tonight. I've had to turn people down lately. Getting too backed up. I had someone try to buy my mono and I haven't even run it yet. Same thing for this boat. Lol. I've had a few people try to buy this Rivercat. I'm anxious to see how it runs.
boilo56
08-16-2015, 08:30 PM
kfxguy, is there any benefit running the strut tubes that close and down the center of the boat?
readyfireaim
08-21-2015, 02:15 PM
Gonna get her in the water this weekend?
kfxguy
08-21-2015, 02:47 PM
Not that I know of. Just did it the way most twins I've seen are done.
kfxguy
08-21-2015, 02:49 PM
I doubt it. I've been preoccupied with other things and haven't quite finished it yet. I still have the hatch bolts and seal to do, work props, put battery trays in, cut flexes
Rocstar
08-21-2015, 03:26 PM
Yes, we usually try to keep the drives as close to the tunnel as possible. Helps with steering and handling. How crucial it is to do so is debatable, but it doesn't hurt.
kfxguy
08-21-2015, 03:56 PM
There you go! I would take what Joel says to the bank. He's done quite a few more twins than me! I think one of the boats I looked at when positioning the drives was a Rivercat he built.
Rocstar
08-21-2015, 04:04 PM
Looking good by the way, but be careful.....Once you do twins, one motor just isn't as satisfying.
kfxguy
08-21-2015, 04:17 PM
Yea...I haven't even run this one and I've got something else in the works :)
readyfireaim
08-31-2015, 12:11 PM
How's she coming along?
kfxguy
08-31-2015, 12:32 PM
I kinda dropped the ball on it. Trying to get other people's stuff done. I ordered the last pieces to the puzzle today....the smaller diameter rivet nuts. The hatch bolts should be getting here any day. I'm going to untape the whole boat tonight and put battery trays in and clearance the side rails for the 4s packs to fit better. I may end up making a quick harness to change up how I'm running the batteries, whether in series or parallel.
kfxguy
10-06-2015, 12:31 PM
Finished this last weekend and went ran it. Loads of fun. Love the sound and stability. Noting got even warm. I ran 56 on 3s and 67.8 on 4s. Not even the props I was going to end up with. It kept pushing the rudder back and the bow was lifting wanting to flip. That cheesy plastic breakaway screw isn't good enough at this speed. I have some brass ones coming. That was also with 40mm props. Real mild setup. Here's a video even tho I rolled it over in it own wake
http://youtu.be/Jf0HcnvPviM
srislash
10-06-2015, 01:34 PM
Ahh, now the twin bug has bitten!
kfxguy
10-06-2015, 01:58 PM
Yes I can't deny it. I like it but I still don't like the extra cost, complexity and extra build time. This boat was actually sold a couple days ago which is what prompted me to finish it. Too many irons in the fire do I had dropped the ball on it. Now that I finished it I'm sorry I sold it but I'm planning another build like it with a few changes. This was more or less practice and to see if I'd like it so I didn't put a ton of time or money in it. Here's some pics
http://i218.photobucket.com/albums/cc243/ltzguy/B8539632-1E92-4874-933E-628FA0B19F0C.jpg (http://s218.photobucket.com/user/ltzguy/media/B8539632-1E92-4874-933E-628FA0B19F0C.jpg.html)
This was on 4s (2 2s packs in series) with cnc x442 un modded props) you can see my esc connector configuration. One way I can run an individual battery to each esc and the other for higher voltage (up to 5s) I can run two smaller packs in series.
http://i218.photobucket.com/albums/cc243/ltzguy/08DD0967-8417-4414-A143-A6F79849B272.jpg (http://s218.photobucket.com/user/ltzguy/media/08DD0967-8417-4414-A143-A6F79849B272.jpg.html)
http://i218.photobucket.com/albums/cc243/ltzguy/104E0E0D-AC6B-4569-9CDF-5EF255F6891C.jpg (http://s218.photobucket.com/user/ltzguy/media/104E0E0D-AC6B-4569-9CDF-5EF255F6891C.jpg.html)
srislash
10-06-2015, 03:35 PM
So that was 4s1p on twin motors?
kfxguy
10-06-2015, 03:56 PM
Yes. I'm not up to speed on the 4s1p thing but it was a 2s pack on each side run in series to make 4s and then feeding both motors. Had good runtime too that way. The 3s setup (seperate 3s pack per motor) should be well over 5 minutes. I ran it for about 4 minutes and packs were at 4.0v per cell. I'm mapping out my next twin build...
Rafael_Lopez
10-06-2015, 11:19 PM
Looking good Travis. What KV are your motors?
srislash
10-07-2015, 12:02 AM
Amazing, I guess it is uber light so it does not take much oomph to get it going and keep it there.
kfxguy
10-07-2015, 07:58 AM
Little 36mm 2550kv tp motors
kfxguy
10-07-2015, 07:59 AM
Weighs 8.172lbs with batteries
readyfireaim
10-31-2015, 04:15 PM
It came out great!
