View Full Version : Formuala Fastech Brushless 26..
Locktite
09-30-2008, 12:07 AM
Hello, I am new here and recently picked up my first brushless electric boat..I picked up a Pro-Boat Formula fastech brushless..The stock motor esc setup has been real nice..I am running 2 7.4 lipos in it and it rips..I just picked up a 7XL Brushless 2370KV Marine motor and Castle HYDRA24 Watercooled 240 ESC.. I plan on using these electronics in my fastech for now..I plan on running 4s or 5s..What would be the best prop for me to run. I was also considering wiring the stock esc for now in series...What are your opinions on this setup as well..Any information would be great. Below are some pics of my boat and a video of the boat with the stock ESC?motor on some 7.4 lipos.....Thanks..
Justin
Video's.
http://www.youtube.com/watch?v=cyKweLOnjgQ
http://www.youtube.com/watch?v=rg1FAYsozC8
http://crispycrittershobbyshop.com/photo/DSC_0390.JPG
http://crispycrittershobbyshop.com/photo/DSC_0393.JPG
http://crispycrittershobbyshop.com/photo/DSC_0396.JPG
http://crispycrittershobbyshop.com/photo/DSC_0397.JPG
http://crispycrittershobbyshop.com/photo/DSC_0212.JPG
http://crispycrittershobbyshop.com/photo/DSC_0224.JPG
09-30-2008, 06:46 AM
Very nice pictures! I would start with a octura x440 or graupner 2317.40 and work upwards from there with testing.
Darin Jordan
09-30-2008, 07:13 AM
Is this hull made of ABS or Plastic, or is it a glass hull?? Might be interesting to see how this would do in an LSO class... Sure looks pretty on the water. Looks like it scoots...
Locktite
09-30-2008, 09:12 AM
Thanks for the info..The hull is made of Fiberglass composite..
I have a change of plans..I am going to keep this boat stock and instead I picked up Avanti27offshore's 33" DF type mono hull..http://forums.offshoreelectrics.com/showthread.php?t=5117 What do you guys think...Thanks
Justin
09-30-2008, 09:32 AM
Sounds like a plan. But I wouldn't run the 7xl in that size boat. Depending on the battery power I would run between a 9xl and 12xl.
Locktite
09-30-2008, 09:36 AM
Right now since i have the motor I plan on running it.. I plan on using one 4s at first and then dropping my 2 4s 5000mah wired in Parrnell into it. OZf course i will be checking the temps....What are your thoughts..
Spot Me 2
09-30-2008, 10:10 AM
From watching the vids, you are running backwards. Races run clockwise.
The FASTech turns better to the right at full speed anyway. I'm sure you have figured that out already.
09-30-2008, 10:11 AM
I'm a pretty conservative guy, I wouldn't attempt that unless I had plenty of money to buy a new esc. If the esc does hold out, you will most likely burn up the motor. The only way I would consider it, was if I was just going to run a quick short pass for a speed record.
Locktite
09-30-2008, 11:57 AM
You are exactly right..I learned that later in the day..It is a pretty noticeable difference as well..:rockon2:
Darin Jordan
09-30-2008, 12:16 PM
Are you running the stock prop, etc., in those videos??
Spot Me 2
09-30-2008, 12:43 PM
Looks like it. Thats what mine looks like on the stock prop.
Darin Jordan
09-30-2008, 12:52 PM
So... what's the overall impression of this boat... Does it handle well? Would it hold up to racing use?? How does it perform compared to an SV27??
It would appear that it might handle better than an SV, and should be capable of simliar speeds with that motor package... maybe even a tad faster...
Would be interested to know this info...
Spot Me 2
09-30-2008, 01:16 PM
I don't think if it would make a good race boat. It handles well in calm water, but is a handful to turn in chop at full speed. I think it handles a lot better than the sv and doesn't flip nearly as easy. My buddy has the sv and it flips in the straights sometimes.
The hull is kinda strange. It has a flat ride pad from about half way to the back of the hull. It might make an ok first race boat, but I don't think thats what your looking for Darin.
Darin Jordan
09-30-2008, 01:23 PM
If anyone has any good pics of the bottom and some of the details of this hull, I'd love to see them...
Not looking for me... I'm considering whether or not this would be something to recommend to someone new who wants to get involved in Racing as a starter package...
Being composite, that's a good start...
Spot Me 2
09-30-2008, 01:28 PM
I think it would be a great starter package. Hang on and I'll get some pics.
Locktite
09-30-2008, 01:30 PM
I will get some pictures up soon..I am loving the boat..I run it in a very calm pond which you can see in the vids..It is a great club spec class race boat...:iagree::rockon2:
Spot Me 2
09-30-2008, 01:33 PM
Here some pics of the bottom for you.
http://i60.photobucket.com/albums/h9/spotme2/100_8338.jpg
http://i60.photobucket.com/albums/h9/spotme2/100_8339.jpg
http://i60.photobucket.com/albums/h9/spotme2/100_8340.jpg
Darin Jordan
09-30-2008, 01:54 PM
Thanks... I'm not sure it's even considered a NAMBA legal Mono hull... that big wide flat section in the back would be considered a 'strake' at it looks like it exceeds the limits for this...
HOWEVER, for LSO, it doesn't HAVE to be a legal "Mono"... Cats and Stepped hulls are allowed as well... so I think it would fit there...
Also... It's not quite a "surface drive"... semi-submerged from the looks of it... That'd limit it's speed potential some...
Diegoboy
10-02-2008, 07:16 AM
Thanks for those bottom pictures.
I have now found my next "jet" boat hull!
I'm excited about this one!
Darin Jordan
10-02-2008, 07:47 AM
RIGHT ON! That does look like it would work well for that!
Spot Me 2
10-02-2008, 09:56 AM
Now you have me thinking!!!
Diegoboy
10-02-2008, 10:19 AM
Locktite,
Would you please let me know how tall the transom on that boat is please?
Thank you!
Spot Me 2
10-02-2008, 11:26 AM
Locktite,
Thank you!
What Diego?? I'm no good for you??????? Is Locktite the only one that can serve you needs?????? I'm going to erase my pictures now and maybe locktite can post some for you.
:sarcasm1::just-kidding:
From the deck to the ride pad is right at 2.5 inches.
Locktite
10-02-2008, 11:40 AM
From the deck to the ride pad is right at 2.5 inches.:smile:
SPOT ME 2 BEAT ME:smile:
Diegoboy
10-02-2008, 06:44 PM
Thanks Guys!
Sorry about that Spot.
That hull is perfect! it is exactly what I was looking for in a jet hull.
Wanna trade that boat for the Mamba hull?
Locktite
10-05-2008, 11:20 PM
Here are some pics of my formula Fastech and some SV27's from this past weekend...Those SV27's do like to jump around..I really like the stability of my fastech..:rockon2:'
http://crispycrittershobbyshop.com/photo/10_5_2008/DSC_0434.jpg
http://crispycrittershobbyshop.com/photo/10_5_2008/DSC_0438.jpg
http://crispycrittershobbyshop.com/photo/10_5_2008/DSC_0444.jpg
http://crispycrittershobbyshop.com/photo/10_5_2008/DSC_0445.jpg
http://crispycrittershobbyshop.com/photo/10_5_2008/DSC_0447.jpg
Locktite
10-05-2008, 11:21 PM
http://crispycrittershobbyshop.com/photo/10_5_2008/DSC_0448.jpg
http://crispycrittershobbyshop.com/photo/10_5_2008/DSC_0449.jpg
http://crispycrittershobbyshop.com/photo/10_5_2008/DSC_0451.jpg
http://crispycrittershobbyshop.com/photo/10_5_2008/DSC_0456.jpg
http://crispycrittershobbyshop.com/photo/10_5_2008/DSC_0463.jpg
http://crispycrittershobbyshop.com/photo/10_5_2008/DSC_0464.jpg
Locktite
10-05-2008, 11:22 PM
http://crispycrittershobbyshop.com/photo/10_5_2008/DSC_0465.jpg
http://crispycrittershobbyshop.com/photo/10_5_2008/DSC_0467.jpg
http://crispycrittershobbyshop.com/photo/10_5_2008/DSC_0474.jpg
http://crispycrittershobbyshop.com/photo/10_5_2008/DSC_0475.jpg
http://crispycrittershobbyshop.com/photo/10_5_2008/DSC_0479.jpg
http://crispycrittershobbyshop.com/photo/10_5_2008/DSC_0480.jpg
Locktite
http://crispycrittershobbyshop.com/photo/10_5_2008/DSC_0484.jpg
http://crispycrittershobbyshop.com/photo/10_5_2008/DSC_0487.jpg
http://crispycrittershobbyshop.com/photo/10_5_2008/DSC_0496.jpg
http://crispycrittershobbyshop.com/photo/10_5_2008/DSC_0501.jpg
http://crispycrittershobbyshop.com/photo/10_5_2008/DSC_0507.jpg
http://crispycrittershobbyshop.com/photo/10_5_2008/DSC_0508.jpg
Locktite
10-05-2008, 11:23 PM
http://crispycrittershobbyshop.com/photo/10_5_2008/DSC_0509.jpg
http://crispycrittershobbyshop.com/photo/10_5_2008/DSC_0511.jpg
http://crispycrittershobbyshop.com/photo/10_5_2008/DSC_0512.jpg
http://crispycrittershobbyshop.com/photo/10_5_2008/DSC_0514.jpg
http://crispycrittershobbyshop.com/photo/10_5_2008/DSC_0516.jpg
http://crispycrittershobbyshop.com/photo/10_5_2008/DSC_0521.jpg
Locktite
10-05-2008, 11:24 PM
http://crispycrittershobbyshop.com/photo/10_5_2008/DSC_0525.jpg
http://crispycrittershobbyshop.com/photo/10_5_2008/DSC_0528.jpg
http://crispycrittershobbyshop.com/photo/10_5_2008/DSC_0537.jpg
http://crispycrittershobbyshop.com/photo/10_5_2008/DSC_0542.jpg
http://crispycrittershobbyshop.com/photo/10_5_2008/DSC_0544.jpg
ZarkSniper
10-06-2008, 07:07 PM
You sure take some really amazing pics...beautiful
domwilson
10-06-2008, 08:26 PM
Dude, those are some beautiful pics! What camera are you using?
Locktite
10-06-2008, 09:34 PM
Aldo from Crispy Critters Hobby Shop took the pictures..I am not sure exactly which camera but I do know it is in the $3,000 range..I can get exact model name tomorrow for you guys..They are some awesome pictures...:rockon2::rockon2:
sewerpit
10-07-2008, 03:20 PM
that yellow sv looks pretty good crash dummy!
