View Full Version : Mobile charging station
shua
06-29-2015, 11:08 AM
So I wanted something portable for charging my batteries lake side.
I would need to haul around a marine deep cycle battery to power my charger.
Started with this.
http://images.tapatalk-cdn.com/15/06/29/41ccb84128d25d7e31a51633f32b54ea.jpg
And wanted to run 2x deep cycles for 24v supply
http://images.tapatalk-cdn.com/15/06/29/cb60039e1b5644f597aa1bd4935e3098.jpg
A little bracing and some plexi glass.
http://images.tapatalk-cdn.com/15/06/29/f82e5956dba53527ad748f5ebbe7dbaf.jpg
shua
06-29-2015, 11:15 AM
http://images.tapatalk-cdn.com/15/06/29/4b775574eff11f88f4c8599dd41d8ba4.jpg
http://images.tapatalk-cdn.com/15/06/29/0d61a27b861e74e508a29662861f388e.jpg
http://images.tapatalk-cdn.com/15/06/29/c8447e71f2036ccdc65e715ea74a0d41.jpg
tlandauer
06-29-2015, 11:17 AM
Looks good, how sturdy is the handle , can this take repeated pounding on not so smooth ground?
Pardon my ignorance, how many volts is that? 12 or 24?
shua
06-29-2015, 11:21 AM
http://images.tapatalk-cdn.com/15/06/29/f28a053401eddb7faec2e420710f088d.jpg
So this set up worked great but was VERY heavy and difficult to toss in the car and go.
I found that after 3 days of use I had barely discharged the two deep cycles.
I decided to remove one deep cycle batt and reconfigure the set up.
v2.0
http://images.tapatalk-cdn.com/15/06/29/d95e0d4307f62a9f2fe5970e8b535d5b.jpg
http://images.tapatalk-cdn.com/15/06/29/8c90eada4a64930626b2dfbc40137dcb.jpg
shua
06-29-2015, 11:48 AM
In addition to more storage space via a clear, hinged charging platform, I added some usb ports to charge mobile devices and power a pair of external laptop speakers for some lake side tunes.
http://images.tapatalk-cdn.com/15/06/29/957cc0755df026a3f02eb2b8695a9fba.jpg
shua
06-29-2015, 11:53 AM
Thanks!
The handle is steel and very sturdy. It handled dragging it around, with the duel deep cycles (24V), for a long three day weekend. Along gravel walkways and up/down steps No problem. We guessed it weighed right at 100lbs.
V2 is now only one deep cycle (12V) and a good bit lighter.
Jamey
07-29-2015, 04:23 PM
Something to consider also is to add a large solar panel to the top surface to recover some reserves as it sits in the sun. That could be useful for extended outings with no access to a lead acid charger.
JimClark
07-29-2015, 04:39 PM
nice looking setup seems like the weak link is the plastic tool box especially with two deep cycle batteries in it.
kfxguy
07-29-2015, 04:47 PM
Great idea. Harbor freight sells an affordable one.
shua
07-29-2015, 06:24 PM
Very true. This is one reason it is now only holding one deep cycle battery.
shua
07-29-2015, 06:25 PM
I'm going to look into that. Thanks!
Tamelesstgr
08-28-2015, 08:49 AM
Love the build, nice job! Apparently I'm not the only one thinking about this kind of stuff.
