View Full Version : Lipo use as power supply? Anyone attempted?
shua
06-15-2015, 08:59 AM
I am looking for a lighter weight option for lake side charging other than hauling a deep cycle marine battery around.
Has anyone ever used a few 3s lipos(12v) or 6s (24v) to power thier charger?
kevinpratt823
06-15-2015, 09:16 AM
Watt hours are watt hours. You would only be able to charge the equivalent of the packs supplying the charge, minus some efficiency loss in the charger, not sure why you would do that, just run the extra set of packs.
I guess you could charge (3) 2s packs if you powered the charger with a 6s of the same mah rating, but that's a lot of hassle.
Sent from my SM-G920V using Tapatalk
shua
06-15-2015, 09:27 AM
Thanks Kevin. Thats what I was afraid of. I have about a 10 Min walk from car to shore and I'm Looking to reduce the load that I have to carry.
kevinpratt823
06-16-2015, 08:47 PM
Sounds like you need to build yourself a wagon of some sort.
shua
06-16-2015, 09:32 PM
read my mind Sir!! I have an old busted two wheel cart and I'm planning to build up some mobil charging/tool cart from that!! Or I saw a rolling tool chest at Northern tool the other day that may fit the bill as well! I have found a deal on some "aged" (new old stock) pair of deep cycle marine batteries to supply the 24v. Its a start!
shua
06-17-2015, 02:04 PM
And so the Mobil charging station build begins..... http://images.tapatalk-cdn.com/15/06/17/9439056e50088583dc80aeae6ed62330.jpg
http://images.tapatalk-cdn.com/15/06/17/3de8b6d4a7080cfa6f7a051fb6cee329.jpg
kfxguy
06-17-2015, 05:16 PM
That's going to be pretty awesome!
shua
06-17-2015, 05:24 PM
Thanks! I will post up a build thread on it.
Make-a-Wake
06-18-2015, 07:12 AM
Very nice!! Trays for driveware and props, and lipos underneath the trays.
spectre
06-18-2015, 08:23 AM
Yes I need one of these also, nice setup.
shua
06-18-2015, 08:42 AM
In my build I'm thinking of adding some 5v usb ports for charging/using Phones, mobil devices, etc AND some sort of intergrated sound system for streaming music lake side! YEAH!
