View Full Version : x642 or M545
jakevisser10
05-25-2015, 11:55 AM
I just ordered a leopard 4074 2200kv with the 180amp esc. I plan to run this all on 4s with 6mm bullet connectors on everything. I want to get around 50 with good run times (3-5 minutes), while keeping everything at a safe temperature. Which prop would be best for performance and temps? Feel free to suggest any props for this setup!
Mike Caruso
05-25-2015, 01:22 PM
I made my water pickup go out the bottom of the rudder. Best thing I to improve the Revolts cooling. Tracked with Eagle Tree so I know it worked. Good luck.
Make-a-Wake
05-25-2015, 01:37 PM
They will be very similar................... both good choices for 4s.
jakevisser10
05-25-2015, 02:01 PM
I'm going to start with the x642 and if temps are good, then I will move up to the m545
