View Full Version : Inexpensive retrieval barge
Phrnzy
05-24-2015, 11:47 AM
Put this together in a couple of days and it was really low cost, uses a NQD jet drive, a $7 waterproof box from Menards, 1" PVC and a noodle bored to fit the 1" PVC. It's not fast, but does the job. The emergency light has about 6 patterns and runs on channel 3.
132437
kfxguy
05-24-2015, 02:49 PM
Looks good! Very close to mine. I might angle the tips up on mine like that.
Heath M
05-24-2015, 03:33 PM
Very cool can we see some more pics please :)
Deepvee
05-27-2015, 09:13 AM
Pretty cool man. I need one of these. Is there a DIY build thread on this or did you whip it together yourself
132437
Phrnzy
05-31-2015, 10:54 AM
Here are few more pictures showing a bit more detail
The frame is 1" PVC, the 4way PVC pieces for the handle/warning light support are furniture PVC, the mounting straps for the box are 1" PVC hanger straps, the mounting shelf for the battery and esc is 1/8 plastic supported by a 1/2" CPVC frame, jet pump is a NQD 757-6024, servo is a SG90 mini, light bar is available here: http://www.ebay.com/itm/281492806433?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
I started this build because I had a HPI SC-15 brushed esc laying around. The total length if 41", width is 18", capture bay is 27" x 12-1/2". The noodles are available at any big box store. The most challenging part of the build was trying to figure out how to bore out the noodles to fit the 1" PVC. After a few failed attempts, I settled on putting a copper cap on a piece of 3/4" copper pipe, heating it with a torch and sliding the noodle over it. Turn out it melts nicely and works well. The "waterproof" box (it does have an o-ring seal) was a great find at a Menards here: https://www.menards.com/main/tools-hardware/tool-storage/storage-racks-containers/slim-storage-box/p-2456270-c-9189.htm
The jet pump does the job but if I make any changes it will be to put a bigger jet pump in it with a reverse gate. I know recovery boasts aren't meant to be fast but I can't help wanting everything to go faster. I built this one on a very low budget. It balances well at the handle and I like the fact it does not have a rudder and prop hanging down to get damaged. it can just rest on the ground without a stand.
132734132735132736132737132738
Phrnzy
05-31-2015, 10:57 AM
Thanks for the kind words. I built this using ideas from others that I have seen posted in these forums. I listed components in another reply, if you have any other questions, let me know.
Phrnzy
05-31-2015, 11:07 AM
Thanks, I can't take credit for the angled tips, saw it on another one posted somewhere and it looked like a good idea.
Heath M
05-31-2015, 03:30 PM
Thanks for the pics very helpfull. One of our club members brought one to the lake yesterday, he had a 100mm steerable jet fan unit mounted to it. Looked very cool, could move over ground as well as water.
Phrnzy
05-31-2015, 08:29 PM
That really makes it cool
revoltrunner
06-01-2015, 12:52 PM
Here's Mine. I went with the all air system since the lakes
I run in have a few weeds and Lily pads. I tried it this weekend
on my upside down 37" Daytona and it work great.
Phrnzy
06-01-2015, 05:43 PM
I like that idea, no problems with trying to keep running gear dry and sealing everything, nice little rig!
kfxguy
06-01-2015, 11:25 PM
I like this! A lot!
zooma
06-07-2015, 05:55 PM
That one is just what I want to do. What dia pipe, and how did you attach the platform? Thanks.
revoltrunner
06-07-2015, 10:11 PM
it is 3/4" pipe. I cut a square notch in the foam pieces
and glued it down with silicone.
zooma
06-08-2015, 09:19 AM
Thanks. I can see the notch, but still expected some fasteners. Looks very easy to build.
revoltrunner
06-08-2015, 09:29 AM
with a full bead of silicone all around it's not coming off.
the 2 front legs are not glued so I can take them off for transport and storage.
the main frame is glued with silicone so it could be taken apart to change the
foam at a later date. the pool noodles do deteriorate after a time.
