View Full Version : Need Hull Advice!
jakevisser10
05-21-2015, 10:56 AM
I am getting back into the hobby again after a few years ago when I sold everything. I have been looking around and decided to basically build my own instead of buying rtr. My main concern is what hull to buy. I need something that can handle a little bit of chop and speeds of 55+ with no problem. I am just getting back into the hobby, so I want to keep this as cost effective as possible. Here is what I have so far. Let me know your thoughts! Thanks!
Motor: Leopard 4082 1600kv
ESC: Seaking 180amp
Hull: Traxxas Spartan
Batteries:Turnigy 5000mAh 3S 40C Lipo Pack (2)
Charger:Duratrax Onyx 245 AC/DC Dual Charger with Balance
Prop: Octura x642
Connectors: 5.5mm bullets on everything
kfxguy
05-21-2015, 11:56 AM
So you want a v hull? If so a good budget one would be a delta force. If you want a pretty much bullet proof hull I'd recommend a Keith Bradly 34" mono. I have one and chop at 55 is nothing to it.
Make-a-Wake
05-21-2015, 04:44 PM
http://www.offshoreelectrics.com/proddetail.php?prod=df-pirate-35
http://www.offshoreelectrics.com/proddetail.php?prod=df-delta35
kfxguy
05-21-2015, 05:06 PM
I've been meaning to add the links. Been busy all day. Here's the kbb, it's twice the price but it's worth it. Very strong and capable of pretty decent speed.
http://keithbradleyboats.com/product/34-mono/
kevinpratt823
05-21-2015, 05:23 PM
For a delta Force, the Cyberstorm is a touch smaller, but everybody comments on it as being one of the best in the chop, I do own a Cyberstorm, but I haven't driven the others. If I build another smaller mono, though, it will likely be the KBB34.
kfxguy
05-21-2015, 05:40 PM
Here's a video of it, I can't find one in chop tho. This is my sport setup. I tuned on it some and swapped props and it's a little faster now. Note: it would turn even better if the turn fins weren't so small.
http://youtu.be/5O9BZMBfDNQ
jakevisser10
05-21-2015, 07:28 PM
Is there a certain hull that the motor will fit in with little/no work? I dont care if it is a mono or cat, I just want it to be solid enough to withstand the speeds that setup will push it. Are there any RTR boats with that setup already in it?
ls1fst98
05-21-2015, 08:36 PM
The kbb mono is a solid hull that wouldn't really require extra work. Just drop the mounts n hardware in and it'd be a great boat.
jetnfast
05-21-2015, 09:47 PM
Jake I am like you, looking for a new hull to use some of my electronics and motor (Leo 4082 1600kv and T180 ESC) into another boat. I discovered this KBB34 the other day and KFX's build threads on OSE and KBB forums pretty much sold me. Its probably not too much work to get a boat like this in the water. I think with our similar motor and ESCs we are looking to use it would be a decent sport setup with plenty of room for improvement (bigger motor, esc, etc.)
If you really want a nice RTR boat, check out the RTR pursuits for sale on kintec's website. They can even be ordered with custom paint and look awesome. They have some RTR cats like the mean machine and a few others. If you want a mono, and the KBB34 seems like too much work or cost, then a pursuit isn't a bad choice either.
KFX guy, can you list the hardware components you used for the build? ie - turn fins, tabs,. rudder, etc. I haven't seen it listed in any of the threads (unless I missed it somewhere...)
It looks like you went with the strut setup over the stinger? To do that, you need to build a flood chamber, correct?
I am seriously considering this boat and have come to the conclusion that building a quality boat from a hull isn't too hard as I did with my carbon fightercat Daytona. That boat has been light years better than my Spartan.
Luck as a Constant
05-21-2015, 10:10 PM
Here's my df 35 pirate.
Running 6s 1500kv
http://youtu.be/0b67m5-bSFs
kfxguy
05-21-2015, 11:24 PM
I'll be glad to help any of you guys get one together. I'd recommend doing one layer carbon inlay. It doesn't need it for the strength, but mainly for looks. Off white fiberglass gets dirty and nasty looking in a hurry, you can't do an inlay, I can do it for you. Now on to hardware...
A 4082 and t180 will push it fairly well. This hull is quite efficient. It's should do mid 60's with that setup.
Rudder: http://www.offshoreelectrics.com/products.php?cat=Rudders%2C+Struts%2C+Brackets+%26 +More
Strut: You could do a stinger, which would be easier but does not have the adjustability so speed capability essentially goes down some. How much? Depends on how far off you mount the stinger. Make sure you get the round bottom one! http://www.offshoreelectrics.com/proddetail.php?prod=ros-spdss-001
I chose a flooded tube for my strut. I'm pretty sure I outlined it in my build.
I used the kintec adjustable motor mount.
Savox servo http://www.ebay.com/itm/Savox-SW-0231MG-Waterproof-High-Torque-STD-Digital-Servo-W-FREE-ALUMINUM-HORN-BK-/390938334341?pt=LH_DefaultDomain_0&hash=item5b05bd9485
.187 flex, mbp collet (highly recommend) http://www.offshoreelectrics.com/proddetail.php?prod=mbp-1000
I used the xl battery trays, I chose to run them along side the motor for balance and lots of adjustment.
Trim tabs. http://www.offshoreelectrics.com/proddetail.php?prod=ose-80925
I used the smaller carbon turn find but larger ones would be much better if your looking to turn
Here mine is on 6s (it did go 68.2 when batts were fresh)
http://youtu.be/OeiTiTwyM1I
Whatever else you need let me know.
jakevisser10
05-22-2015, 12:09 PM
I appreciate all the help guys! Sadly, that's out of my price range. I was hoping to try and get everything for around 500-600, including batteries, a charger, and upgrades...I am getting back into the hobby so I have to replenish my setup first!
kfxguy
05-22-2015, 02:18 PM
I don't think your going to buy everything you need to get started that cheap. You may want to rethink your budget. A couple batteries and a charger will eat up at least $200. Esc $100, motor $100, hull $100 and I'm guesstimating it on the low side. Well good luck to you!
jakevisser10
05-22-2015, 02:26 PM
I understand that, but that is why I am trying to find the best deals :/
kfxguy
05-22-2015, 02:40 PM
I have a nice hydro I could sell you. If you'd be interested in a hydro.
http://i218.photobucket.com/albums/cc243/ltzguy/20141109_133119.jpg (http://s218.photobucket.com/user/ltzguy/media/20141109_133119.jpg.html)
Peter A
05-22-2015, 03:53 PM
How about a Pursuit? The only thing you will need to fit the 4082 motor is a rear support. It should fit your budget and is a great running and handling boat.
785boats
05-22-2015, 04:00 PM
I run a TP 4060 1600kv motor in an Ariane 2 with a seaking 180 on 6s spinning a 646/3 blade prop. Just needed a tail ring mount added is all.
Here's an early test run. Running a bit wet in the smooth conditions.
https://www.youtube.com/watch?v=B5596xnRs6s
Cheers.
jetnfast
05-27-2015, 09:24 PM
KFX - thanks for all the info that's was a great post! I am really leaning towards this hull and would be interested in doing the same setup with the strut like yours. What size carbon tube (diameter) did you use for the flood chamber? It looks like you did brass stuff tube nested in that as well and then the .187 flex? Is the outer carbon tube large enough that you were able to do a slight bend on the stuff tube? I am just trying to conceptualize how that works compared to the standard mono stinger setup....
kfxguy
05-27-2015, 09:55 PM
I used 16mm of tube. I used a generic cat strut. I only had to make a very slight bend. This allows a lot of up and down adjustment of the prop. This boat has seen over 91mph so far and I toned it down not long ago. In "sport" mode with a 1500kv motor it went 84.7 lol.
jetnfast
05-28-2015, 05:21 PM
Awesome info again, thanks! I have an email into KB about the availability of the hull, waiting on a reply, but I am trying to get a parts list and gameplan together to build one of these.
84 MPH "Sport setup" ha ha, that's awesome!
