View Full Version : swordfish 240 esc help
DeltaForceMan
04-24-2015, 08:19 PM
Just recently put power to this esc and hooked up my program box to it. The screen "update your esc or press ok" when I press ok the screen goes blank??? Would appreciate any input thanks.
pescador
04-24-2015, 11:27 PM
Do you have both leads from the esc plugged into the box like Diagram 2 opto esc in the instructions?
Switch on?
Brian
DeltaForceMan
04-25-2015, 09:36 AM
Yes, the receiver lead and the lead that consists of a black and red wire. Bolth have been plugged in and it won't get past the first screen after o press ok it just goes blank... maybe its a program box problem??
Thanks for your response
pescador
04-25-2015, 12:19 PM
Did you try checking the box firmware thru the pc link? A long shot mine was up to date.
Brian
DeltaForceMan
04-25-2015, 12:23 PM
Maybe that's the problem.. I'll have to get the USB link and try it.
flraptor07
04-25-2015, 08:44 PM
It's probably a firmware update problem, have you had this ESC a while and just now using it?
DeltaForceMan
04-25-2015, 08:54 PM
Just got it a couple weeks ago.
flraptor07
04-25-2015, 09:07 PM
Do you have these instructions? http://media.wix.com/ugd/6bc562_69a7fe2473b2494d9a8295e1a9f4b490.pdf
DeltaForceMan
04-25-2015, 09:20 PM
I did not but I haven't done anything out of the normal with this setup. I will go over all options.
flraptor07
04-25-2015, 09:32 PM
Go through those instructions and see if you missed something.
jcald2000
04-26-2015, 07:53 AM
The controller HAS to be connected to the computer to update software, other wise where is it going to get the update from?
