View Full Version : Rearwheelins Rumdog Re Do Rico 31" HD Speed Version
rearwheelin
04-18-2015, 02:49 PM
I got this hull from a long time experienced FE vet here who is on break from the hobby currently . I plan on fixing this one up special with things that more than likely aren't necessary . High power and semi good turning. That's a CC 1717 in there I will probably get rid of. It will be a slow build let's see what happens :blah: :noidea:
130967
Spartanator
04-18-2015, 03:01 PM
I would want that 1717 except mounts are hard to find for it....
We will be waiting on the build thread! Less wiring this time?? lol
rearwheelin
04-18-2015, 03:03 PM
I can Make you a nice mount .
rearwheelin
04-18-2015, 03:52 PM
I am going to make a 1717 mount for a deep v and post picks soon. I will keep my templates for future mount should anyone want one for a fee.
rearwheelin
04-18-2015, 04:36 PM
Lexan template for the mount130969
rearwheelin
04-18-2015, 07:25 PM
Someone was saying you can't hardly find 1717 mounts . If you have those troubles you can't call Uncle Rearwheelin :buttrock:
The mount is in raw form I will bling it up later :beerchug:
130976
rearwheelin
04-18-2015, 07:37 PM
It's a perfect fit for this motor and jacket.130977
rearwheelin
04-18-2015, 11:36 PM
130986 130987 130989
Luck as a Constant
04-18-2015, 11:48 PM
Nice work duuude!
rearwheelin
04-19-2015, 12:12 AM
Nice work duuude!
Thanks luck it's made to rock your face off ! lol
Spartanator
04-19-2015, 12:39 AM
Wow, that's a nice mount.
I wish I would have seen it before I spent some $ at Kintec and OSE....
rearwheelin
04-19-2015, 03:13 AM
I'm thinking about doing a run on them. China is hard to compete against though .131001
Spartanator
04-19-2015, 03:37 PM
It would be cool but I am not sure how many would get it.... I would prefer to have it made here in the States, even if would cost a chunk of change. I might have to buy another hull for that Leo. 4092 now....lol
Would you do one with a rear support? My boats are subject to waves from big boats... lol
rearwheelin
04-19-2015, 03:50 PM
I can do a rear support but I would get the Chinese one from kintec more than likely . These mounts are strong enough to run with no support if the motor can is up to the task. If you you like send me a long motor and I can see how I would go about making the rear support . I may need to modify the side plates a little for a rear support. I would advise a rear support on the real long motors although I have run 1527's with no support and no issues after crashes although I have seen pics of what can happen with no support .
rearwheelin
04-19-2015, 05:22 PM
I want to get rid of the stinger drive and go with a strut setup . I have built a couple monos in the past with struts and never did a flood tube . Adjusting strut height was always a pain. I bought a stick of red pex shark bite tubing at the Depo that I think will be perfect !
131003
rearwheelin
04-19-2015, 06:40 PM
I just sent the old setup back in time ! lol131004
rearwheelin
04-19-2015, 06:44 PM
I'm getting ready to do a putty test on this hole .131005
rearwheelin
04-19-2015, 06:58 PM
Step 1 tape131006
rearwheelin
04-19-2015, 06:59 PM
Step 2 putty131007
rearwheelin
04-19-2015, 07:00 PM
Step 3 peel 131008
Luck as a Constant
04-19-2015, 07:06 PM
Jb putty I see
rearwheelin
04-19-2015, 07:34 PM
Jb putty I see
It's QuickSteel but I'm sure they are close.
rearwheelin
04-19-2015, 08:12 PM
Looks like it's time to go to HF and score a bigger step bit !131009
rearwheelin
04-20-2015, 06:06 PM
131059
flraptor07
04-20-2015, 10:08 PM
Mount looks real nice! I think Dave @ HRC does the 1717 mount too, I don't see it on his site but I'm almost positive he does one.
rearwheelin
04-20-2015, 11:23 PM
Thank you !
tlandauer
04-20-2015, 11:43 PM
Been too busy this past week, couldn't keep up with you, looks great. Them motor mounts are lovely. I see how easy it is to take the motor out with the front plate.:buttrock: Also is this boat going to have a wet tube, the transom center hole is rather large...
rearwheelin
04-21-2015, 12:51 AM
It will have a wet tube for the extended strut I'm putting on it . It may be a little bit before I get too far into the build . I kind of need to earn more boat money lol
I'm working on perfecting the mount JIC others may want one hint hint :tape:
tlandauer
04-21-2015, 12:57 AM
:drool::drool: :spy:
If I ever get to my ML 400 build.......:unsure::crying:
rearwheelin
04-21-2015, 10:35 PM
On the left is a TP5650 mounted to the first 3 production components templated from the original and has the motor plate in hydro form , these parts will interchange with each other and be duplicated the same. It also can bolt up standard 25mm and 6 bolt 30-35mm . The universal bolt pattern is extra time and $$ . Pic your one pattern or spend more and bolt them all up ! Ok I'm dreaming again lol :drool: :tongue_smilie:
131116
tlandauer
04-21-2015, 10:42 PM
They look SOOO good, I don't know which motor to use yet, I wanted a CC 1717, but was told that will be too big. I was adviced to use a Neu 1527, but I have not looked at the hull for so long and it's been stored at my Mom's.
Will the standard one come with a roll of holes on the side plate for epoxy grabbing?
rearwheelin
04-21-2015, 11:02 PM
It will ! It will have all the holes as the original and will probably look even better. I haven't completed the side plate template fully yet but adding holes to it is the next step.
I'm pretty darn excited about this mount ! :thumbup:
rearwheelin
04-21-2015, 11:09 PM
My short $150 56mm TP motor is rated at 4500 watts continuous and 8400 watts peak. This mount will have no troubles with that . The mount is 2" tall and I can drop the bolt patterns lower should you want a single pattern and a long motor so you can get better clearance .
rearwheelin
04-22-2015, 10:57 PM
The one on the bottom has one extra epoxy hole than the original on top. I got crazy with the holes on the production cut out trying to figure out the production pattern but it was a fail ! lol the original is a much more optimal approach lol I will make a duplicate of the holly one pm me if anyone is in interested in it . These epoxy holes will be in the final design.
131130
rearwheelin
04-23-2015, 10:32 PM
This is the updated side plate. It's what they will look like.131146
Luck as a Constant
04-23-2015, 10:39 PM
Nice dude!
rearwheelin
04-23-2015, 10:44 PM
Nice dude!
You just let me know when you need one Luck I'm going to give you a nice discount ! Just PM me when your ready.
tlandauer
04-24-2015, 02:41 AM
Awesome, I will let you know as well.
rearwheelin
04-24-2015, 01:37 PM
I have a low pro mount I designed for a 1527 to fit in a H&M Intruder . I kept my spec sheet on it . This was my original one. So I got you covered if this new one is too big. I will probably make these ones again too, but aluminum :)
131149
rearwheelin
04-24-2015, 10:51 PM
11 hp 31" Rico :buttrock:
131158
tlandauer
131158
Yup!
Spartanator
04-26-2015, 01:05 PM
PM me your address so I can get the 4092 sent out!
rearwheelin
04-26-2015, 02:28 PM
Thanks ! PM sent ! I think peoples hang up with the mount is no rear support so this is a good opportunity to implement one ! :thumbup:
Spartanator
04-26-2015, 04:46 PM
No problem!
I do to, this is my opinion: I believe some like the CF because it does have some give IF they have a real bad crash and it looks nice. The mount could be painted or even wrapped (maybe a HyrdoDip would work too) so it could match the paint. Maybe we could work a trade (plus $) on that 4092 for the 1717.....
rearwheelin
05-03-2015, 08:46 PM
Are you looking for a indestructible layout ? Then Rearwheelins "SAW Boat Shenanigans" drop in unit might be for you ! LMAO ! This thing should keep you on the lake unless you break your boat in half ! :cool:
It's still a work in progress .....
http://i1208.photobucket.com/albums/cc374/rearwheelin/Mobile%20Uploads/IMG_4570_zps3058e0ab.jpg (http://s1208.photobucket.com/user/rearwheelin/media/Mobile%20Uploads/IMG_4570_zps3058e0ab.jpg.html)
rearwheelin
05-03-2015, 10:13 PM
http://i1208.photobucket.com/albums/cc374/rearwheelin/Mobile%20Uploads/IMG_9897_zps59f9eae2.jpg (http://s1208.photobucket.com/user/rearwheelin/media/Mobile%20Uploads/IMG_9897_zps59f9eae2.jpg.html)
rearwheelin
05-03-2015, 10:16 PM
Now on to new drop in unit specific side plates for the motor mount .
rearwheelin
05-06-2015, 07:09 PM
Getting very excited about the new drop in unit. I have had a couple days to kick around some design improvements . I threw the first one together in a couple hours and now it's time to make the real deal ! I will get a good one built and see if Steve would be so kind to let me post my own thread in the unique products and services area :thumbup:
rearwheelin
05-07-2015, 11:21 PM
I didn't expect to get the final mock up done allready ! But I did , I think lol131687
rearwheelin
05-07-2015, 11:28 PM
http://i1208.photobucket.com/albums/cc374/rearwheelin/Mobile%20Uploads/IMG_3666_zpse43f68cc.jpg (http://s1208.photobucket.com/user/rearwheelin/media/Mobile%20Uploads/IMG_3666_zpse43f68cc.jpg.html)
tlandauer
05-07-2015, 11:29 PM
Wow, looks good as usual, Randy!:rockon2:
Spartanator
05-08-2015, 01:09 PM
Looks heavy duty! Still doing the rear support?
rearwheelin
05-08-2015, 04:53 PM
There is no possible way I can do a nice rear support so I'm going to have to recommend this. For the motor you sent me I would just run 6 motor bolts and call it good :)
131696
Spartanator
05-09-2015, 06:28 PM
131696
Ugh. I think you can get one in there, I know you can. It would probably be more trouble than it is worth though. Thanks for trying at it!
I will let you you know where to send that motor back when your done playing with it... haha
rearwheelin
05-09-2015, 08:07 PM
Just let me know and I will get it to you ASAP ! The front support OSE has would be the way to go in my book :thumbup1:
rearwheelin
05-10-2015, 07:54 PM
Just a update on the drop in unit. It's comming along but could be a couple weeks before one is ready . They are a lot of work ! They will have plenty of CF too !
rearwheelin
05-10-2015, 10:42 PM
A real labor of love :tongue_smilie:
http://i1208.photobucket.com/albums/cc374/rearwheelin/Mobile%20Uploads/IMG_5517_zps2bf14312.jpg (http://s1208.photobucket.com/user/rearwheelin/media/Mobile%20Uploads/IMG_5517_zps2bf14312.jpg.html)
Spartanator
05-13-2015, 10:09 AM
Is that the rail?
rearwheelin
05-13-2015, 03:45 PM
Is that the rail?
Yep ! I was testing my notching skills for a battery tray , I ordered up $106 in cf :spy:
