View Full Version : Help with HD flex cable and 5mm -187 coupler.
Trevor Boyd
04-14-2015, 05:29 PM
Hello all, i recently picked up those two items and a new prop from the shop and i am just curious as to how it is supposed to install. seems a bit snug using the stock motor. i do realize this setup is primarily for upgraded motors, however the site still says it can be used for stock. Teflon liner is out. I was hoping someone who has done this already may shed some light and or post some pictures. much appreciated.
Trevor.
IRON-PAWW
05-07-2015, 10:27 PM
Did you get this sorted yet Trevor? Not quite sure what you mean by too snug with the stock motor.
ray schrauwen
05-08-2015, 03:16 PM
The coupler if it is steel, might be a tight fit onto motor shaft because it has machining burrs inside that can be fixed with 320 grit paper wrapped around a drill bit small enough to get inside to de-burr it.
Trevor Boyd
05-11-2015, 08:18 PM
hello. iron i have not had a chance to try it yet. i will post a picture hopefully this friday when i will have a sec to work on it. i will let you know !
Trevor Boyd
05-11-2015, 08:19 PM
thanks ray. i will test again and see.
