View Full Version : BJ29 v3, 30C lipos ok?
helidan
04-11-2015, 05:35 AM
Just before I place an order just wanted to check if 30C lipos are ok for a stock boat.
I intend to run 4s2p.
Was looking at some Turnigy 4s 3300mah 30C lipos on Hobbyking.
The maths states that even with a discharge rate of 20C per lipo I could theoretically pull 132 amps continuous because of the parallel connection.
Will this be adequate for the Blackjack?
The other packs I was considering were Zippy Compacts, 3700mah, 35C but they are a bit more expensive.
Luck as a Constant
04-11-2015, 07:20 AM
Yeah they should be fine
Dunno the price, but buddy rc has glacier 45c 3300 packs for 50 bucks. Probably better than Turnigy imo
Good luck!
helidan
04-11-2015, 07:41 AM
Thanks for confirming.
I can't really use buddy rc as I'm in the UK but Hobbyking has UK and German warehouses.
Btw, what runtime could I expect from 6600mah?
Luck as a Constant
04-11-2015, 07:43 AM
Gotcha.
It depends how you drive it.
Maybe 3-4 minutes
kfxguy
04-11-2015, 10:31 AM
Have you looked at www.revolectrix.com they are about the same price but far better quality. They are in Singapore so shipping should be no problem. A 4000 40c 4s is 51 bucks.
Edit. The black label 3400 30c are $36.86. Only a few bucks more than the turdnigy batteries. http://www.store.revolectrix.com/Products/BLACK-label-LiPO-batteries/Revolectrix-3400mAh-4S-Lipo-Black-Label
Luck as a Constant
04-11-2015, 10:36 AM
Good point Travis
helidan
04-12-2015, 06:03 AM
They look good but I'd still rather purchase within the UK in case anything needs to be returned etc.
Btw, is a total weight of 932g of batteries too much for the BJ29? I ask because I've seen some 4500mah lipos which would fit quite nicely in the hull but are a bit heavier than the other lipos I mentioned above.
martin
04-12-2015, 08:57 AM
Revolectrix are available in the UK from revolectrix.co.uk. They stock the Platinum & Diamond ranges.
helidan
04-12-2015, 09:23 AM
A fair bit more expensive though especially after I've bought 4 of them.
helidan
04-14-2015, 06:10 PM
On the subject of lipos how are you all securing them in the boat? Using the supplied velcro straps seems a bit awkward so I thought about doing away with them and using self adhesive velcro strips. Is this ok?
kfxguy
04-14-2015, 07:34 PM
It's ok until you flip the boat then they become projectiles and knock your hatch off. In short, no. Lol
helidan
04-15-2015, 04:48 AM
Well I don't particularly want projectiles in the boat!!
I've looked at it again now and repositioned some of the straps to make them easier to secure. I might fit the self adhesive velcro anyway for a bit of extra security.
crispyspa
08-18-2015, 11:13 PM
I hated the stock straps on the V3 so I replaced them with double sided velcro. Works much better.
