View Full Version : What is the difference in props?
eric-paul
09-20-2008, 12:19 PM
octura 1440; octura x440; octura m440
are they not the same pitch and diameter?
ReddyWatts
09-20-2008, 12:33 PM
14 are moderatley high lift for hydros and deep V's
X4 are medium lift general purpose props
M4 are like X4 but with the tongues removed to unload the prop
eric-paul
09-20-2008, 04:25 PM
Thank you for the answer.
andym
09-20-2008, 09:44 PM
Hey Blane I think that a 14 series prop on a deep v would not be a great idea. Have run them on my riggers with good results though.
ReddyWatts
09-20-2008, 10:17 PM
I guess a moderatley high lift prop on a deep v can help hold the bow down? Got that from the Octura prop description list.
Different types of Octura props
12 are low lift ideal for submerged drive
Y are like X series but have 10% more pitch
X5 are general all purpose med lift prop
X6 are higher lift than X4 and suitable for surface/semi surface use
16 are high lift props for riggers and hydro's
17 are the highest lift prop for riggers and outboards
P7 are similar to 17 series but more rake and less lifti
19 are high lift for riggers and hydro's
V9 are moderate lift suitable for riggers, hydros and SAW racing
20 are moderatley high lift suitable for riggers
21 are high lift for riggers and hydro's 22 are high lift surface drive only good straight line speed
mtgoat
09-20-2008, 10:26 PM
In practical terms, what effect does this have?
ReddyWatts
09-20-2008, 10:39 PM
The tongue is used mostly when taking off and low speed acceleration. Removing the tongue allows the prop to turn easier at high end rpm for a faster top speed.
Doug Smock
09-20-2008, 10:57 PM
This will help, "areas to cut"
http://rcboat.com/prop.htm
Doug
Ocean Racer
09-20-2008, 11:44 PM
SO the tongue is epual to putting small tires on a car you take off quick but not for long. So from what I got from that is if you mess with the tongue you can get a perfect prop. You can shave a little off and get the right amount of acceleration to fly at the start. Plus you have a small enough tongue that you get a good top end. right:confused1:
andym
09-21-2008, 12:08 AM
Yes,..........................................
Diegoboy
09-21-2008, 07:59 AM
Wow, pretty good stuff!
