View Full Version : X645 for a modded BJ29 v2?
champion221elite
03-20-2015, 12:06 PM
Im running a modded BJ29 v2 with a 1400 kv Leopard 3674 motor and a SK180 v2 esc. This is a dedicated 6s setup that ran awesome with a prepped X642. Temps came back under 130 after timed 3 minute runs unless the water was in the 80's.
My X642 got trashed after hitting a piece of rope that was floating in my course area.
Given my setup, is it possible run the larger X645 without issue?
Make-a-Wake
03-20-2015, 12:48 PM
I think you are already at a great prop with the x642, plus your temps are close to being at what I consider the high end(135* to me is tops) The boat should be plenty fast with the 642
kfxguy
03-20-2015, 01:11 PM
I find the x or m 645 makes a smaller hull like that unstable when swapping from a 642. I did this comparison by accident last weekend and the boat flipped easily. I think it had more lift so it will require retuning to adapt for it. I put the 642 back on and it was stable again. The boat does over 70 with the x642 so I know it's enough prop to go fast.
champion221elite
03-20-2015, 01:17 PM
Glad i asked. I will just order another X642 and call it good.
