View Full Version : BK Bandit S Cat
lferguson
04-05-2007, 08:57 AM
This is a BK Bandit S. It is 29" long and 9.5" wide. Weighs about 1.4lbs. It has a double pick up flush mounted in the sponson and a dual out put on the side. It has a rudder and rudder bracket already installed along with motor mount, a screw off type antenna, power switch, and stuffing tube guide is cut. The rear was deeped to allow a larger prop selection and more power. All glass and motor mount is glassed in and rear cut portion is glass.
http://www.bk-electronics.com/catalog/product_info.php?cPath=41_71&products_id=1556
Rudder and strut not shown....oops
Also available is th e"power package".
6 pole 1350Kv motor. Hextronix Quannum. Cheap but it has power enough for good sport running. ESC is water proof/water cooled 70amp TowerPro.
hammertime
04-05-2007, 12:59 PM
how much.... beautiful lookin cat
lferguson
04-05-2007, 01:01 PM
I am thinking $250 for everything, thats shipped to your door.
lferguson
04-05-2007, 01:12 PM
Beautiful running too. This is the same hull Paul P went 70+ in at FEIII last month.
hammertime
04-05-2007, 03:26 PM
what else builing needs to be done... this will be my first build project!.... is it fiberglass or abs
lferguson
04-05-2007, 03:28 PM
Can I just PM you or e-mail?
hammertime
04-05-2007, 03:29 PM
never mind i see now..... so all i need to do is mount motor buy stuffing tube and flex drive prop and radio.... rudder is already in place? anything else.... dont want to get in to deep for my first one
hammertime
yes absolutly pm would be great
lferguson
04-05-2007, 04:17 PM
I'll give you stuffing tube and I should have a extra servo or two laying around I can include for cheap.
hammertime
04-05-2007, 04:27 PM
i have 5 servos from cars and stuff i never put back together.... the stuffing tube would be great though......... thanx money will be sent in about an hour or so
hammertime
04-05-2007, 04:28 PM
what prop do you think i should start with??
lferguson
04-05-2007, 04:48 PM
SOLD Thanks Drew
lferguson
04-05-2007, 04:54 PM
IT's always best to start off small and work your way up. I would start with a 40 or even a 42mm. I would suggest Stevens CF props to test with. they are cheap but very good.
hammertime
04-05-2007, 05:05 PM
ok sounds good
Danmit...Missed it by 10 minutes
04-06-2007, 04:16 PM
Thats a nice one at a good price!!!
lferguson
04-06-2007, 04:34 PM
Steven ... Take a guess at why I asked $250...... Hint The money is going straight to you when I get it. LOL I'll take one Hydra 240 please...
