View Full Version : Stumped about my proboat geico electric
Wavewalker
03-12-2015, 11:05 AM
Hello, I hope I am in the right or closest forum for my problem(if not please redirect me). I am new to fe boats, But have over 20 year's in flying Thermal Duration gliders. I got a geico 29 stock except a 42 octuro prop and two 2s 6500 mah 70c new batts to try it. I made a few flawless runs. On one run one battery dropped a cell causing it to swell and heat up. So I got two new 5200 batts when I installed it I had nothing the receiver wouldn't even power up D.O.A. So from there I checked the ESC power going in but nothing going out. I ordered a seaking 120esc and a frysky gt3c with receiver. once I installed the new ESC my old spectrum mr200 powered up but still no servo or motor so I installed the new tx and rx binded it but still no motor or servo. The color of wires from new ESC to proboat motor are different I installed according to directions. Still nothing. So now the receiver powers up but I still have nothing else. I am open to any ideal's and would like to thank anyone now for answering this post.
Please Help
Thank You
Chris
srislash
03-12-2015, 01:29 PM
You may need to program that ESC. But first, do you have ANY brushless motor around to try. Bad motor may have started it all.
Wavewalker
03-12-2015, 01:37 PM
Yes I will try that and post back.
Thanks
JimClark
03-12-2015, 01:51 PM
In your initial post you state "On one run one battery dropped a cell causing it to swell and heat up" how long was this run?
Wavewalker
03-12-2015, 09:32 PM
I took it for a easy run half throttle only about 20 minutes
JimClark
03-12-2015, 09:45 PM
I suggest you read a lot more about these boats on this forum before you run again
srislash
03-13-2015, 12:17 AM
I agree with Jim here. 20mins??? Half throttle??? You most likely heated up the ESC and possibly motor as well. We run maybe 7 minutes farting around. About 4-5mins full throttle and 10,000mah. This is real dependant on the setup, size, weight of the boat. Boats do use the juice.
Wavewalker
03-13-2015, 06:34 AM
I checked the motor, You guy's are right. At the time I was using a onyx 245 charger that was malfunctioning so I was just trying to run the batts down from a full charge so I could get them in a storage mode. Is 3.8 v correct. Also what is a good replacement motor that wont brake the bank.
Thank you all for your advice and I am always open for more advice.
Respectfully Yours
Chris
srislash
03-13-2015, 08:56 AM
Dynamite at Horizon is the replacement I believe. But anything within reason size wise and maybe 1600-1800 kv.
Wavewalker
03-14-2015, 09:36 AM
I want to thank all of you for your expertise and time. If I am replacing motor I definitely want to step up. Is hobby king a bad ideal, I also have seen a lot of people using leopard motors. Because I am fairly green to the boating world I want something that would hook right up. Any recommendations is greatly appreciated.
Thank You
Chris
srislash
03-14-2015, 10:26 AM
Well, the 'hot' setup is a Castle 1515. Dastuffuwant should still have a few. It would bolt in place but could use a bit of support from floor to can of motor as would most any other motor you get. With a 642 your 120 ESC should be fine.
I don't really deal with HK so have no experience with their motors. TPpower is another good one for the price. I have extensive experience with them and the Castles so can vouch there.
JimClark
03-14-2015, 01:45 PM
I think he would be good to learn more about the stock setup before going to the "Hot Setup"
srislash
03-15-2015, 03:13 PM
Good point Jim, especially if running at the part throttle to get used to things.
In that light perhaps something 1400-1600kv in an 4068-74 size can(the 1515 is 4074 but 2200kv). This will give you a nice operating RPM on 4s and you can play with props. In the future you can always bump up to 5s.
Wavewalker
03-17-2015, 08:09 AM
Again Thanks, I wanted to point out I usually run this doing wide open passes. Just that day I was only trying to bring the charge down on my new batts because I had a full charge on them and my charger did not have a storage mode or a way to bring down the charge that I know of. I like to store my batts at about 3.8. So for me speed is good slow is bad, But I also don't want to over power it to were I will be getting blow overs. And again I want to thank you guy's for the advice and I welcome more it is the only thing in life that is great and still free
