View Full Version : teflon linner ques
waynedawg
09-19-2008, 08:16 AM
i put the fullers hardware on and have a ques how do i get the teflon liner into the end of the strut tks:help:
MAXAMUS
09-19-2008, 02:22 PM
i had the same problem what i did was to run a piece of carbon fiber rod up the Teflon liner then lightly sanded the liner till it fitted, also keep the carbon rod in the liner and use this to insert the Teflon liner into the stuffing tube it prevents kinks and makes the job a lot easier
HappyOne
09-19-2008, 05:57 PM
I had the same question when I did mine. I called Ray Fuller and he told me to use some heat shrink tubing. Mine runs from the stuffing tube all the way to the strut. As far onto the strut as I could then I shrunk it down. Nice and clean. No water gets in and I can still adjust the strut around.
