View Full Version : Exceed Racing Flowmaster Catamaran 650mm build help.
studioRS
03-07-2015, 03:18 PM
I plunked down and bought this, couldn't resist. Super nice scale looks.
I would like to request some help on deciding what motor, ESC, prop and other upgrades.
I'm willing to remove all ply and reinforce with CF kevlar cloth and epoxy if needed. I don't want to go too ballistic, but faster than stock would be nice.
Stock
2848 2636kv, 27A Feisuda, ~299w with 3S
Prop: 32mm three bladed
Slightly Modded?
Leopard 2845 2550kv 4D (6) ~800w
Prop: x437/3? (I'll need to shim up from 4mm)
Modded or too much?
Leopard 2860, 3400kv
or
3650 1900kv
I have a Turnigy Marine 120A
http://www.nitrorcx.com/99b-10117-650-ep-kit.html
http://site.nitrorcx.com/Boats/99B-10117-650-EP-ARTR-02.jpg
http://site.nitrorcx.com/Boats/99B-10117-650-EP-ARTR-04.jpg
http://site.nitrorcx.com/Boats/99B-10117-650-EP-ARTR-05.jpg
http://site.nitrorcx.com/Boats/99B-10117-650-EP-ARTR-12.jpg
studioRS
03-08-2015, 12:49 PM
Would this setup work well or should I stick with a smaller Leopard 2845 800W motor and go slightly higher kv?
LBP2860/2Y, 2730KV
MAX: 60A, 21V, 1300W
Resistance: 0.0113
No Load: 1.9A
Weight: 176g
2 2S packs - 4S batteries, 50C on up, 2200mah range
37mm 3-blade prop
studioRS
03-09-2015, 11:02 PM
This arrived today. Wow. What a piece of art, the paint and graphics are top notch, hull fiberglass and build is very nice too.
I dug into my parts bin and found a new Turnigy 2860-2700kv motor rated at 660w and 60A on 3S, should do the trick. Some have reported up to 975w on 4S.
TheShaddix
03-10-2015, 06:08 AM
Surprised that no one has replied yet... This is looking really nice! The motor choice is good too. I would unbolt everything at the back and apply silicone to bolt threads to prevent leaks. I sold the same boat to a buddy, he's running it on 4S at around 40 mph and really likes the boat.
studioRS
03-10-2015, 09:02 AM
Thanks for chiming in, beginning to wonder…
Glad to have your thoughts on this. I'll take more detailed photos but yes my idea was to run 4S. Looks like smaller 2S 2200mAh will fit on either side of each hull, I'll have to take measurements for what batteries will fit. I do have a Zippy 4000mAh 3S 20C, but just don't like the thought of it sitting in the middle so high. The hull looks pretty stout, still wondering if I should at least try to reinforce the bottom, tips and transom with CFK fabric or just mixed epoxy?
What are your thoughts on an upsized prop? I was thinking a sharpened, balanced X437/3.
Pheyd
03-10-2015, 09:39 AM
I definitely like the hull, looks sharp. I always vote for CF inlay, it does so much to increase the hull's integrity. I have no idea what your budget is, but if you want to go crazy try one of these motors:
LMT 1530/6 LK (4763 KV), 155g, 70,492rpm on 4S ($251)
LMT 1535/5 LK (4899 KV), 175g, 72,505rpm on 4S ($260)
Both of the above motors are rated for 85,000RPM!
I'd start with a x432 prop with the above beasts and work your way up.
Also, if you consider the above, take a look at the flex shaft first, hopefully its beefy enough to take it.
studioRS
03-10-2015, 10:55 AM
Thanks for these suggestions super helpful. It's always nice to hear from others experience. More Lehner Motoren love, someday I'll own one, they are dakine…
For now a little over my budget which is low—mostly dig in my parts bin! Found a Turnigy 2860 2700kv and I already have a spare Turnigy Marine 120A. I'm sure this hull will be a keeper and mod it up as I go.
Ok with x432, but couldn't I go larger (x437/3) to start with my lower 2700kv motor on 3S? Yes, I should drop down in size for 4S.
Yes, CF inlay will happen. Wonder if I can do it without having to remove the wood that is already glued in?
Received some CFKevlar cloth I ordered from HK. Guess I need some special cutting shears too, any recommendations for cutting kevlar?
I've been using System Three for building my 1/10 scale boats (Breathless U-22 (http://forums.offshoreelectrics.com/album.php?albumid=1064&attachmentid=128715)) and like how this epoxy works, but now out, so totally open for other alternatives. Has anyone tried US Composites brand 635, with 3:1 hardener?
Has anyone installed a twin rudder on this hull? Wonder if I should think about that also or is one offset ok?
studioRS
03-10-2015, 11:17 AM
The motor mount has some tapped holes in the top (mine is silver). Quick look, I didn't see any spare brass water cooling nipples in the parts bag. In some of the stock photos, looks to have allen stubs installed? If these are cooling ports, this beckons for additional cooling.
http://site.nitrorcx.com/Boats/99B-10117-650-EP-ARTR-13.jpg
studioRS
03-10-2015, 11:20 AM
Will the stock 4mm flex shaft be adequate with the 2860 2700kv motor on 3S, and 4S?
Pheyd
03-10-2015, 11:23 AM
Running on 3S and 2700kv, a x437/3 should be alright.
The more slits you cut in the CF, the less solid it becomes. However, having to re-glue all the mounts is a pain and easier said than done. Since I'm not doing it, I'll tell you to remove all the wood and cf inlay everything :P
with a 650mm hull, I wouldn't bother with dual rudder. Stick to a single, either in-line or offset, whichever you prefer.
Motor mount doesn't appear to be used for cooling. Get an aluminium water jacket for the motor and it should be enough.
TheShaddix
03-11-2015, 05:26 AM
Definitely keep it as single rudder, inline just like the stock one is. If you need to make it longer, add a bracket to the base to extend it, but do not offset. The stock flex shaft is fine for that kind of power too.
This hull, as nice as it looks, is very fragile. A few crashes and you'll start seeing stress cracks in the paint. I cracked the top deck just by pressing on it gently... I reinforced mine with a cf inlay, upper decks, hatch, etc. I poured mixed/thickened epoxy into the transom to flood it as well as the tips. Then I used 2 part foam as well. I was trying to go for some high speeds, but the hull just can't handle it as a single motor, it wants to roll. So don't over-power it, keep it simple and you'll be happy.
And do not over-prop it! Start with a small prop like a 38mm, go up to 40 tops. Then you can try something with a bit more pitch which won't have as much torque but will give more top speed. From what I noticed, this hull benefits a lot from more weight so feel free to do all the reinforcement you want!
studioRS
03-11-2015, 12:42 PM
Ok, thanks guys, keep the tips flowing in!
- Rudder will stay as is.
- Great tip on sealing bolts with silicone.
- @Shaddix - I noticed you added a transom water connector, rather than drilled and stuffed though the hull raw, I'll add one to the parts list.
- I have the following 2-blade props: TFL 432, TFL carbon 435, and s/b Octura x435 drilled out to 3/16" (but can shim back down to 4mm). The stock factory prop is a 3-blade D32, 1.4.
I'll go ahead and buy two props, 38mm 2-blade and Octura x435/3, which the latter I think will help keep this hulls rear arse up in the turns?
This is where I need help, I've never reinforced an existing FG hull before. You guys all make it look so easy in your photos (Shaddix I did review your Genesis CF mod photos too). I've come to the conclusion I need to add CF Kevlar and remove the factory glued in plywood and motor mount. Prying it off looks like it will lead to stress cracks all on the bottom as you mentioned. Take the Dremel to it and remove slowly?
Qs
- Looking down the inside at the transom it appears the nuts for the strut and rudder are blobbed over with factory glue… ugh. Tips on removal?
- I was planning to use 1/8" Birch ply to reinforce, then epoxy over, but now have second thoughts on any wood going back in. Trace outside of hull transom and cut CF plate to fit? Not any room back there!
- Toss the factory white foam stuffed inside and use 2-part foam. How much did you mix up?
- Any experience on US Composites 635, 3:1? OR should I stick with West Systems?
- Shaddix what did you thicken your epoxy with? (I'll buy black dye too)
- The factory mount certainly does have tapped holes for cooling, I will try to find some brass metric barbs that bolt in and use it.
- I was thinking that 3M Super77 will hold the CF Kevlar down well, then roll on the epoxy. Should I rough sand the FG surface first? I did see how you layer down the CF on clear saran wrap then how in the heck do you get it to lay in nice and smooth with it all loaded up with epoxy?
- How in the HECK did you get CF on the inside and the sides of the top of the hull? Confusered.
There will be more Qs, sorry to ask so much and TIA. I've been involved with RC boats since my first job at 16 working for Charlie Pottle at Marine Specialties back in 1976. I'm comfortable building wooden classic hydros, FG work, just need to get caught up with modern CF building and modifying methods.
Top 36" 1/10 Scale 1954 Breathless U-22, 25.5" Exceed Racing Flowmaster Cat, 18" Dumas Atlas Van Lines FE project
https://farm9.staticflickr.com/8635/16598425078_a2cd9778c8_c.jpg
https://farm8.staticflickr.com/7607/16784907962_32e5c4b41e_c.jpg
Bow
https://farm9.staticflickr.com/8574/16785999125_be62f99f79_c.jpg
Transom
https://farm9.staticflickr.com/8591/16784859831_ddb1cd9541_c.jpg
https://farm9.staticflickr.com/8676/16784859291_01ffb27a0b_c.jpg
https://farm8.staticflickr.com/7589/16163687904_d924cd77c2_c.jpg
TheShaddix
03-11-2015, 01:31 PM
The wooden plates will have to go if you plan on reinforcing, no doubt! They should come off without much of a fight. Tape up the underside (quite a few layers of tape), that might help avoid stress cracks. When you remove glue, try to "turn" it to break it loose instead of prying it off with pliers. For all the small remaining bits you can use flush cutters/nippers, then just block sand it flat. I had to do all of that on mine too. It's a project for sure!
To reinforce the upper decks you just gonna have to lay CF fabric as far in as you can reach. Sand it with 60 or 80 grit first. Then flip the hull upside down. Keep pressing the cloth into the hull throughout the cure. It doesn't have to go that far to make it stronger.
For the tips and transom, mix resin with some milled fiberglass/silica to add strength, then pour equal amounts into the tips, all you need is just a bit to fuse the two halves better. Roll the hull side to side once poured so the resin flows around a bit creating a thin layer that covers most of the bow tip area. Do the same with the rear. Make sure the hull is vertical when it's ready to cure.
For rear transom nuts: just unscrew the bolts first. Then use a larger drill bit and drill into the nuts, that'll break them loose for sure. But then you'll have to use new, larger (and longer) bolts for your rudder. Worth doing if you want it really strong.
I would not recommend using any adhesive first for your cloth as that will block the epoxy and be held on by said adhesive till it comes apart later. I always prefer to saturate cloth outside of the boat as you get it perfect this way with no puddling or dry spots, and you can remove excess resin with a foam roller too.
Once you lay the cloth in, just keep massaging it into all the corners continuously throughout the curing process. Work in warmer temps too as that'll speed it up. Don't worry about messing up the hull with resin, wipe it with alcohol afterwards.
Definitely get rid of the stock foam as that won't help keep the boat afloat with heavier motor/batts. I had a blackjack 29 sink like that only because the batteries were a bit heavier. It should have been accounted for in the first place when they designed it.
Be careful with the 2 part foam. If you mess up on the ratio, you get brittle or soft depending which part you mixed in more of. Also, pour both parts into two separate cups. Then mix them really fast in one. You can use some black dye for this too. Mix for 20 seconds, then pour into the boat. Try to aim for 2-3 pours total, don't do it all at once. Work in warmer temps too as that will expand the foam more. And always use a water bucket to dip your hull into as the foam gets really hot and will distort your boat no exception. When you mix the foam by weight, that's 1.2 of part A to 1 of part B if you buy it from us composites.
For resin, west system is great if you can afford it. There are always cheaper alternatives though. Just don't use kleer kote, i learned that it's not a good option for anything other than bar tops...
NativePaul
03-11-2015, 02:18 PM
I would really recommend getting Kevlar shears as it will be 50 times easier and you will get a neater cut too, but for a one off project it can be cut with fresh sharp razor (not scalpel) blades at a low angle on a cutting mat (not a wooden board), use very light pressure going over the same area again and again till it is through before moving on, and changing out for a fresh blade frequently.
TheShaddix
03-11-2015, 02:29 PM
My suggestion is go cheap on the scissors because even really expensive ones will dull out quickly whereas even the cheap decent ones will cut nicely for some time. I just buy fiskars or something cheap for $10-15 from Lowes. I had a nice pair of shears at some point that I got for about $80 and was really disappointed when they got dull so quickly from cutting cf.
studioRS
03-12-2015, 11:17 AM
Located some inexpensive carbon steel Kevlar shears by Clauss for $18 on Amazon, thanks for the tip. Also nice for all the kind notes on CF / Kevlar fitting process. I might use pink foam carved to fit in each sponson and bow nose area and glue in with Gorilla Glue, then it won't heat up the thin FG hull. Used this method on the Breathless build.
I'm only fitting a slightly longer (by 15mm) and not that much more powerful motor. I studied the glued in wood, disturbing this even in the slightest pull produced small resin crack sounds, but thankfully no stress cracks on the outside, so I left it alone. I'm going to leave all wood installed as is. Mostly a time issue for me at this point. Also, the glued in wood adds to the FG hull strengthening there already. I'll lay in carbon fiber kevlar 3k all around on any exposed FG surface I can reach, leaving the wood as is. Need to decide on System Three or US Composites 635 epoxy. I know this might be the not preferred method for ultimate strength, I just don't need to over build it, or over remove and then over rebuild it, just reinforce what is already there. I do too much of that stuff (and time in the hobby shop away from my family…) on my scale sailplanes!
Because the 2860 motor is longer and heavier, the only thing that might need adding is a rear tail clamp for added support. I ordered a single rigger mount for 28mm motors that looks trick from Kintec Racing. Also ordered some TFL props and a better collet for the motor/flex. Photos when parts arrive.
studioRS
03-12-2015, 11:19 AM
I tried cutting some of the CF Kevlar last night with some Titanium scissors laying around the house, phhht! This stuff is like superman cloth, stops bullets, dang. I see what you mean.
grsboats
03-12-2015, 06:37 PM
here's a tip I use to do when cutting kevlar: aplly CA glue on the cloth where you want to cut,wait some time till the glue dries....you will see how easy becomes this task but kevlar scissors is a must if kevlar is part of your work as mine.Gill
studioRS
03-13-2015, 08:26 AM
Gill, Thank you for this CA glue tip I will try this. I use CA glue and thin cloth or fiberglass to stiffen scale sailplane parts and can see how this would work.
TheShaddix
03-13-2015, 01:30 PM
Hey guys, I thought I would mention one thing, the CA method has one major problem that I have found. Once dried, the cloth becomes rigid and brittle, you can't bend it much anymore or it starts to crack and breaks the fibers. It does help avoid the fraying but there are better ways. If you're using this for an inlay, grab some fabric glue at a crafts store, they have a lot of different types to prevent fraying on fabric but it works the same for carbon too. You want the cloth to remain perfectly flexible to conform to the hull contours.
studioRS
03-13-2015, 01:33 PM
Nice :-) Planning this weekend to go kevlar shear shopping and now to a fabric store, krickey!
wingnut
04-09-2015, 08:55 PM
kinda off topic but hows the little dumas atlas coming? what have you got planned for it? thanks carl
studioRS
04-09-2015, 11:16 PM
Aha, keen eye on the vintage Dumas Atlas Van Lines! I've had that kit for ever and dusted it off and started to get after it. Gutted the center bulkheads for more room and plan to drop in a small inline brushless motor, make it FE of course. The Mahogany is so brittle though, and will use ply when needed. I'll lay down a section of 1/32 birch ply down the center and fill the sponsons with foam. In true vintage form I will use the remaining mahogany. I'll make another thread for this.
Back to the Exceed... Got my CF Kevlar from HK and the Kevlar shears, new water jacket is on and just waiting to buy a big refill of epoxy.
wingnut
04-10-2015, 01:24 AM
i have a the atlas and the thriftway so ill look forward to the other thread. thanks carl
Meniscus
05-15-2015, 01:59 PM
Do you mind taking a picture of the underside, showing the steps? I'm also curious to see a transom shot showing the steps. I've looked a few time online and have yet to find pictures from these angles.
As for the comment regarding 85k RPM. Please note that no brushless motor should go in excess of around 50-55k safely because of the bearings. For most sport setups, 32-36k unloaded RPM will be more than sufficient. More typical setups are from 30k to 33k and deliver plenty of fun without always worrying about flipping the boat. In case any reader is not aware, you multiple KV times the voltage to get the unloaded RPM. :smile:
So far as setup and lower amp draw, a 36mm motor would be good running on 4s. Apply the typical setups for the Blackjack26. There are lots of affordable motors out there for this size. Also, the UL1 power plant would be a good choice for a model like this. Both the original Blackjack 26 and the UL1 employed 6-pole motors which, because of their torque, pulled less amps.
Meniscus
05-15-2015, 02:11 PM
Another thought to consider. You mention running 3-blade props. Keep in mind that as a rule of thumb, 3-blade props pull more amps than the 2-blade props. :thumbup1:
Brushless55
05-15-2015, 05:22 PM
Man that is a killer little CAT !!
and not that bad of a price :biggrin:
I might have to get one to go with my DF23
and maybe try a sweet heli 3300kv outrunner on 4s with a small prop :thumbup1:
studioRS
05-15-2015, 05:46 PM
Yes I can shoot some more photos of the underside steps and transom, no problem.
I have a 3650 1500kv ProBoat motor, but planning to start off using a Turnigy 2860 2750kv on 3S. I'll play around with props on the this set up 2 and 3 bladed.
studioRS
05-15-2015, 05:47 PM
Yes, it is very nice for the price. Sweet little hull, just waiting to buy some more Systems Three epoxy so I can reinforce and ready to run.
Agitator
05-15-2015, 08:57 PM
All you need to cut kevlar/CF/ Fiskars 9 Inch Premier Titanium Nitride Shop Shears. Got mine at Home Depot $15.00
Brushless55
05-16-2015, 12:19 AM
Nice
do you think it is a solid hull without the mods ?
studioRS
05-23-2015, 09:34 AM
Bottom photos as requested…
https://c1.staticflickr.com/9/8787/17954172181_f62fbde0dd_c.jpg
https://c1.staticflickr.com/9/8757/17765888350_585c062e9c_c.jpg
https://c2.staticflickr.com/8/7744/17765640648_10bfd1498b_c.jpg
https://c2.staticflickr.com/6/5344/17330915124_16a8d19da5_c.jpg
https://c2.staticflickr.com/6/5464/17332975723_b3248cbc22_c.jpg
studioRS
05-23-2015, 09:45 AM
Finally able to buy some epoxy, this stuff isn't cheap and hands down the best in my opinion. Somewhat local purchase old skool on the phone through Merton's Fiberglass in MA, no need to order from WA state. Best part, ships ground UPS next day to Northern Vermont. System Three 1 1/2 QTs will hopefully last me for several more all wood builds that I have lined up.
- 1/12 Scale www.Classichydros.com Karleson Style kit from Doug C himself
- 1/10 Scale Wafarers Lady build
- 1/10 Pay n Pak (mostly finished, just need to build canopy area top)
- 1/5.2 Scale Sid-Craft F Hydro, Dick O'Dea
- 1/10 Scale Cozy F1 build
https://c2.staticflickr.com/6/5327/17330919064_97d388ef63_c.jpg
studioRS
05-23-2015, 09:54 AM
Nice
It is a far eastern built hull, which means not necessarily made from good epoxy resin, but with possibly polyester resins. The paint, build quality and overall looks and scale is stellar, super cool, trick little hull for the cost.
I'm going to reinforce with the kevlar I bought and new epoxy, but instead of ripping out all the already glued in wood and mounts, just leave them intact and reinforce and integrate. I don't really feel like creating stress cracks by removing something that is already glued into a fragile hull. This will cut down the time too.
I will leave the factory hardware installed and just use a slightly larger spec than factory 2860 motor, 2700kv on 3S. This will be a fine little runner as is. I have bigger builds that will require more mods and faster equipment. I basically bought this because it was already finished. Just needs a little internal strengthening so is can withstand some good stashes at speed and still look good afterwards.
Cheers, Thompson
ls1fst98
05-23-2015, 02:06 PM
Looks like a lynx cat or mini zonda. I did mine a twin....it's a pain but looks cool.
studioRS
06-01-2015, 11:54 AM
It certainly is a cool little Cat hull. Wow, a twin? Love to hear and see the details, did you do a write up?
studioRS
06-01-2015, 11:57 AM
Did a little work this rainy weekend on the baby Cat. WTHeck was Exceed manufacturers thinking using white silicone to glue in the nylon nuts??? :strange:
Had to use a little creative nut removal tool, an old Tamiya wrench. This removal redefines blind nuts. The operator is definitely blind getting the top two! Thanks to the iPhone camera, I was able to see what is still in there, still more to remove... The sharp edges of my Hudy allen wrench work pretty well at removing the white silicone. Fortunately, this comes off really easily.
Planning to get some 1/8" birch ply, carbon kevlar and epoxy back there.
https://farm1.staticflickr.com/368/18300077706_2816bd0dda_c.jpg
https://farm8.staticflickr.com/7776/18140325729_f9510cd444_c.jpg
https://farm9.staticflickr.com/8796/18300077046_082282d3da_c.jpg
785boats
06-01-2015, 01:12 PM
Nice work.
I wouldn't use ply in there. I've found that after a while the ply tends to compress where the nuts are & so they, in effect, become loose. Then you have to get in there again & re tighten them. Carbon or aluminium would be better.
studioRS
06-02-2015, 10:13 AM
Good call on the aluminum plate, thanks!
studioRS
06-02-2015, 10:20 AM
Here is a transom piece of 6 layer 1/8" birch ply (not lite ply) and measurements if anyone is interested. This fits well in the back, but took me several cuts to get one that fits! I just need to get more layers of ply (or hardwood block) behind to fill the square area and then get longer socket head bolts and add a 1/16" aluminum plate over the plywood after it is finished—like a giant washer for the nuts.
https://farm8.staticflickr.com/7797/18386593231_2f07ca578b_c.jpg
https://farm8.staticflickr.com/7761/18358463156_fd8389f696.jpg
https://farm8.staticflickr.com/7748/18358467386_966a4e1c28.jpg
785boats
06-02-2015, 03:25 PM
Good one.
Make sure you seal it well with epoxy. Especially the edges. It will get wet from time to time
Meniscus
06-05-2015, 01:56 PM
An option to aluminum is Lexan. I've used this in several models that have survived high-speed crashes at over 80mph. I know that a lot of folks may have issues with polycarbonate cracking, but the thicker Lexan has served me well. It may weigh just a tad more, but I doubt it will make much difference for such little material as is used on an application such as this. In my applications, I haven't noticed any loosening of the nuts.
studioRS
06-05-2015, 03:20 PM
That's interesting using thicker lexan. Hmm. I'll have more progress and photo over this weekend, thanks for the tips.
Brushless55
07-07-2015, 01:43 PM
Looking good man !!
love this little cat :thumbup1:
studioRS
08-17-2015, 10:21 AM
Finally had some time to get back on this project!
Opened up the wood channel for 3S 4000mAh 20C battery.
https://farm1.staticflickr.com/494/20312539370_8d188d1410_c.jpg
Carbon fiber kevlar prep
https://farm1.staticflickr.com/520/20312528950_d4e09cedef_c.jpg
I was able to get two strips almost down the length of each sponson, just shy of the tip by about 2.5"
https://farm1.staticflickr.com/412/20500631835_3c0e764607_c.jpg
Chopped glass, 1/8" birch ply transom added with poured in epoxy.
https://farm1.staticflickr.com/422/20506941111_ab4a490fdf_c.jpg
https://farm1.staticflickr.com/375/20474403456_ab0c88c00c_c.jpg
https://farm1.staticflickr.com/445/20312534020_b7b522489b_c.jpg
studioRS
08-17-2015, 10:24 AM
Added a separate water pickup for either the motor or ESC. Curved at the bottom and flush. Used CA glue to fix position, then epoxy with ply reinforcements.
https://farm1.staticflickr.com/430/20319495149_13c2054956_c.jpg
https://farm1.staticflickr.com/735/20533419431_a684a3fb8d_c.jpg
https://farm1.staticflickr.com/431/19883525914_224818fe2a_c.jpg
https://farm1.staticflickr.com/672/19897683044_22f87d2862_c.jpg
Didn't like the Z bend on the rudder connection, so soldered a tight clip—no play now! Graupner/SJ 658 BB MG servo.
https://farm6.staticflickr.com/5791/20338683480_5076e8d9fd_c.jpg
studioRS
08-17-2015, 10:30 AM
Added flotation
https://farm1.staticflickr.com/751/19963121184_30d8d2bffb_c.jpg
Turned out I didn't even need to add an aluminum plate on the backside of the new ply transom. The epoxy / chopped glass filled the void and I even added a second layer of ply before to the transom just in case. I used the stock length bolts and just tapped the epoxy / chopped glass. No need for nuts!
Installing a water cooling tube on the transom water inlet proved to be a little challenging, no room for fingers. This was also tapped into the epoxy, so to be a water tight fit. Idea! I used a slightly larger brass tube over the silicone tubing and pushed it on.
Specs
- Turnigy 2860 2700kv motor with 28x58mm water cooling jacket from OSE.
- Turnigy Marine 120A ESC, Graupner 658 BB MG digital servo, Airtronics / Sanwa MX-V 3-channel radio.
- Battery: Zippy 3S1P, 4000mAh, 20C with 4mm connectors.
https://farm6.staticflickr.com/5747/20576736812_8b40214e2f_c.jpg
https://farm1.staticflickr.com/777/19963115894_824a725909_c.jpg
https://farm1.staticflickr.com/666/20592276071_ba9689e729_c.jpg
https://farm6.staticflickr.com/5784/20397720938_8093e93b7a_c.jpg
studioRS
08-17-2015, 10:31 AM
More...
https://farm6.staticflickr.com/5638/20399018899_6b736448d8_c.jpg
https://farm6.staticflickr.com/5773/19963115304_0edbfe2214_c.jpg
https://farm6.staticflickr.com/5717/19974231293_d83b492633_c.jpg
studioRS
08-17-2015, 10:34 AM
And finally a video of the maiden.
https://www.youtube.com/watch?v=s2uYC9nUG6M
In the video, I used the stock 432/3 carbon prop, stock 4mm flex cable and shaft.
I have a 436 CNC and 436/3 TFL (needs balancing). Might try these both.
studioRS
08-25-2015, 03:50 PM
Swapped to a CNC Aluminum 436 prop.
https://www.youtube.com/watch?v=eEkRrsp5K2c
Brushless55
09-05-2015, 01:33 AM
Was this on 3s ?
looks good man !
studioRS
09-05-2015, 11:09 AM
Thanks! Just need to pull out all the blue flotation foam and add CF/Kevlar epoxy to the sponson tips and front area. Don't want to have this happen if I catch a tip WFO…
http://www.rcgroups.com/forums/showpost.php?p=32506512&postcount=720
Davey80
04-20-2021, 01:01 PM
Thoroughly enjoyed the read-up on this build. So much great info and excellent pics! I just recently picked up this boat and am going to apply what I learned here to take a shot at doing a CF inlay.
Bit of an older thread now, but would love to hear an after-action on how you liked the boat and its performance, given all the work you put into it.
Mark
studioRS
04-20-2021, 02:08 PM
@Davey80 - Thanks! There was only one item that I neglected to fully address, getting enough epoxy down into the sponson tips, before adding the flotation foam. I did add some epoxy, but could have added a little more. You don't want to add too much weight though. The CF reinforcement definitely helps, just keep the epoxy application light.
It's a fun little scale hull and certainly fast. I was about at the limit with power and battery, as you can see in the video, the torque roll was significant on full throttle. I've since sold this on, so can't really help out with further performance tuning.
studioRS
04-20-2021, 02:09 PM
Was this on 3s ?
looks good man !
Yes, 3S, 4000mAh 20C.
