View Full Version : MHZ 114 High End Build
nata2run
03-02-2015, 06:31 PM
Hello Folks,
Time to build another Hi-End boat, its been awhile but I'm getting stuck into it again. Sadly this boat is not for myself but a custom build for one of our fellow forum members :thumbup1:
Hull: MHZ 114 Carbon/Kevlar
Motor's: LMT 2240/7 LK
ESC's: MGM X2 25035
Drives: MHZ Hi-Speed Drives
Rudder: MHZ Scale
Collets: MBP
Servo: Savox 1252
Props: Andy Brown x447
This should be a very capable setup, and I'm sure a fun project to put together.
...let the build begin
nata2run
03-02-2015, 06:36 PM
Couple of images of the hardware...
128629128630128631128632
srislash
03-02-2015, 07:18 PM
Hey, hey ,hey. Right on my friend. Which MGM's are those ones Kent?
nata2run
03-02-2015, 08:57 PM
Hey bud! They are the 250A up to 8s lipo
Local Boy
03-02-2015, 09:38 PM
I really enjoy following your builds...
Looking forward to this one...
Thanks for sharing...
Aloha
TheShaddix
03-02-2015, 09:48 PM
Great part list! Where did you get the high speed mhz drives? They aren't listed on the site.
srislash
03-02-2015, 09:58 PM
That's what I thought. Have you run these before? They are reasonable in my books as long as they hold up.
nata2run
03-02-2015, 10:32 PM
Aloha
Thank you, keeps me on top on the build knowing I started a post LOL
nata2run
03-02-2015, 10:34 PM
Thanks,
The 138 Hi-Speed's were listed some time ago, When I placed the order I asked Shirley at MHZ if I could get them for the 114 and she sent them :)
nata2run
03-02-2015, 10:37 PM
Never ran those, but I have good experiences with MGM in general and have seen some heavy abuse on the 25065 without failing. I'm positive they will hold up fine for this project and have good control over the LMT's
TheShaddix
03-02-2015, 10:39 PM
So you're using drives made for a 138? OR they have 114 drives but just don't list them? I would be really interested in these drives too! The mbp ones are a bit too costly.
nata2run
03-03-2015, 12:10 AM
The drives are made for the 114, but cost wise they are close to the MBP mini drives. But keep in mind these were made specific for the 114 and you don't have to modify or shorten them in any way. They seem like a cool design with small "fins" on the tip of the drives. If proper installed in line, I think they will perform very well.
Pheyd
03-03-2015, 09:39 AM
Those are some mighty fine parts. Looks like another great build!
nata2run
03-03-2015, 10:18 PM
Hello again,
Thanks Pheyd :)
I got some more work done last night (I'm always a day ahead of the post by the way LOL) as most of you have seen, I'm a fan of templates, jigs and tools in general that will make the job easier for me. That said, it don't mean that it cant be done in other ways, I just don't like taking risks that result in "fill in epoxy jobs" Since I was dealing with a new power drive I had to make a completely new jig. This new drive uses 2 M4 screws appose to 3 M3 in the standard drives. It also requires a smaller hole for the stuffing tube as it don't have the bushing/bracket on the inside of the hull. In my book, this calls for an even more precise drilling and alignment. (because of the 2 point hold down compared to 3). This is how I did it. I first apply a few pieces of masking tape on the hull. 2-3 layers are usually good! once that was in place I used a scalpel to cut off the excess tape from the edge. After I pealed off the tape gently and applied it onto a standard sheet of paper and scanned it with my scanner. From then on I traced it and did a print out to see if it all fit. At this point I realised that I needed to lover the drives by a mil or so (1/20') roughly.
128668128669
...continued
nata2run
03-03-2015, 11:07 PM
...After all that was completed, and I redrew the jig, I cut it out in 12mm acrylic (1/2") Before any further actions I had to make sure the drive train would fit as planned. Here is the complete unit. I should mention I'm using an aluminium 8mm tube to fit the thick walled teflon stuffing tube.
128670128671
Here is the final jig ready to install on the hull
128672
Now to the very important part! Since I was asked about drilling holes, I will elaborate on the subject a little closer than planned.
I always make a habit of using tape for cutting/drilling/milling, sometimes multiple layers. The reason for that is, most tools (drill bits, router bits) are up-spiral, meaning they exhaust their cuttings away from the material. That also mean that they "eat" what they come in first contact with. If its gelcoat, it usually result in chipping. By using tape and a jig it will eliminate that with up to 90%. By using a high speed drill it will eliminate that even further. Vibration from the drill is also a major issue, again the jig will help to reduce the vibrations. I even have jigs made up with pre-drilled holes to keep the drill vibration free (egg shaped holes) when just drilling a random hole.
nata2run
03-03-2015, 11:17 PM
Here is the jig against the hull
128675128676128677
nata2run
03-03-2015, 11:18 PM
A few more to show the enter/exit hole, and the very clean alignment of the drive housing
128684128685128686128687128688
TheShaddix
03-04-2015, 02:14 AM
Awesome, man! Very professional work there. Even the masking tape trick alone is a great one to take from this thread. Never thought of doing that, makes a lot of sense to layer it up to keep the gelcoat from cracking.
nata2run
03-04-2015, 08:40 AM
Thank you, to give you an idea of how I mask and cut cf plate chek one of my videos http://youtu.be/9EZyOlME6xg (my attempt of fancy editing lol) it just shows that it's a habit for me to mask everything I cut to avoid burr and get a cleaner cut.
Steve Dean
03-05-2015, 09:32 AM
Wow Kent, this is like deja-vu. It's like watching my own MHZ Mystic 114 coming together. I have been taking photo's of every stage just like you. I'll have to get round to starting a build thread. Then folks can watch how are builds are progressing and see how we diverge when it comes to the internal fit out.
People maybe interested to know that my component list is a little different:
Motors: LMT 2240/8
ESC's: MGM 28026-3 X2 Series Pro
The rest is pretty much the same with the motor mounts heading towards me from Custom Carbon Fiber Parts in OZ. Kent made them for me with a little visual design feature …….. all will be revealed later !!!
I'll keep you'll posted as things progress.
nata2run
03-09-2015, 04:18 AM
Hey Steve,
You should do a thread! would be interesting to see what you have come up with, I'm sure it would look great!
Ok, back to the build. I am forever trying to find the best way to get the drives aligned. This may not be the easiest or best way, but its so far the most accurate way I can think of. The ole "drill bit trick from Manuel W. still tops it off as a final alignment" But the "drive hold down's" are still made in a way on the MHZ's that make it complicated to place on the hull and use as a template. For that reason I made my own block that can sit flush on the hull and allow me to drill the 4 holes to hold it down further.
128858128859128860128861128862
nata2run
03-09-2015, 04:23 AM
Here are all the blocks used...
128863
After everything was aligned and the 4 holes were drilled, I used the 2nd block as a drill guide. This block was stuck down with double sided tape and also the 4 screws through the block. ( I didn't bolt down the block, just used to screws to hold the block in place)
128864128865128866
nata2run
03-09-2015, 05:23 AM
When all secured, I just drilled the hole with a 14.5mm NEW drill bit. I'm quite happy with the result.
128867128868128869128870
Pheyd
03-09-2015, 09:09 AM
Just wow, this build is looking very clean and I like it! Can't wait to see this cat come alive.
nata2run
03-16-2015, 11:28 PM
I'm finding less and less time to post and upload pictures of this build. But I thought I'd keep you in the loop of whats going on. I had to completely redesign the motor mounts for this particular build, as I want to use CF veneer for decor also. I have so far made 3 different versions and not 100% happy :( but good news is, I think I got it!! once installed, I will post some photos. After that stage she will go straight to the painters....
TheShaddix
03-17-2015, 12:29 AM
Kent, do you take the hardware off when you send it to the painters?
I'm also building an mhz 114. Does your rudder bracket fit onto the hull? Mine doesn't want to slide into the cut-out area which seems to have too much gel coat. What do you recommend to shave off some of the material precisely?
royalcasa
03-17-2015, 08:23 AM
You must be a tool maker or mold maker by trade, I used to be one. Fantastic work my friend.
Best Regards.
nata2run
03-17-2015, 08:35 PM
I only install the whole drive train and rudder, then I strip it all and send off for paint. Water Pickups, exit tubes I drill and install after the painting is done. I don't like the look of paint over predrilled holes, they tend to look egg shaped or become smaller then what they were suppose to be. If you then have to open up the hole, its more likely to chip. Regarding the rudder, it fits really bad, not bad but tight! fit and drill it while its tight, then file a bit on the hull to make it slide in better. You will most likely chip a little paint once you install it. Its one of those things, hard to tell how thick the paint is going to be, so very hard to judge
nata2run
03-17-2015, 08:44 PM
Best Regards.
Thanks for the compliments! No, not a tool or mold maker, but a graphic designer and graphics instructor for the past 20 years. Not teaching anymore thou, but have my own visual display/sign shop as an everyday occupation. I guess if I can think of it, I can make it :)
nata2run
03-19-2015, 08:36 PM
Got a bit more work done the other night. Instead of using just plain washers where the drives mount to the hull, I decided to install a support plate. It's commonly used in builds like this, but I haven't done my builds this way prior. The reason why I'm using it this time around is because I really want some support on the stuffing tube in that end. I think it came out nice and serves the purpose. I also got the motor mounts cut and will be posting the update a little later when I complete the inlay.
129346129347129348129349129350
flraptor07
03-19-2015, 09:28 PM
Hello Folks,
ESC's: MGM X2 25035
Rudder: MHZ Scale
Collets: MBP
Servo: Savox 1252
Kent, who you tryin' to kid. Everything you build is a High End Build! :thumbup: I'm Watchin' :biggrin:
nata2run
03-19-2015, 10:23 PM
LOL, that's funny... I didn't mean it that way!!!! but, thank you for the compliment, and thanks for watchin' LOL
nata2run
03-22-2015, 08:13 PM
Got some more work done over the weekend, as I explained in an earlier post I had to redo the motor mounts a couple of times. (just cut them in acrylic to begin with) I try to match the mounts to the specific build and the placement in the hull also. The aligning is a bit tricky! I usually spend a bit of time on that part. I have gone away from trying to measure inside the hull and and judge the distance. I now always complete both flex cables/shaft to the exact same length and use them as a guide to where the mounts need to be. That way I know they are in the same position. I then use what ever I can find to elevate the motors from the sponsons. I also don't complete the stuffing tube until I'm happy with the bend of the cable. In other words, I feed through the cable and make sure that it has the perfect bend, and can spin freely without too much slack, then I build the stuffing tube around it.
A couple of pics...
Since the owner is Canadian, a sneak peek of the theme..
129689
Redrawn motor mounts for close fit
129690
Measure up for alignment
129691129692129693
nata2run
03-22-2015, 08:24 PM
The gluing part as usual....masking up the area, then sand and clean both motor mounts and hull with brake disc cleaner.
The process for gluing in the mounts was:
CA spot gluing to make sure mounts were in the right position, then a mix of epoxy with CF cuttings. Once it started to set, I then laid 2 layers of tight glass weave around the edges (roughly 1/2") and on top of that some tinted epoxy with a small amount of micro baloons.
129694129695129696
Pheyd
03-23-2015, 10:56 AM
A couple of pics...
129689
Now that's what I'm talking aboot eh!
nata2run
03-29-2015, 10:39 PM
Got some more work done over the weekend. I always try to get nice looking stuffing tubes :) I made a set wrapped in Carbon and a set with mesh wrap as well just to see what looked the best. Although I really liked the mesh wrapped I went for the carbon in the end. I also cut the lipo trey's but will post about them a little later. at the moment I'm working on a stuffing tube support (wanna try something new) but I'll have to see if it works first. I really like using aluminium on the stuffing tubes and it bends really smooth, and could be polished to a chrome finish for some fancy effects. As its a little soft, I would recommend that it gets some sort of epoxy coating to keep it firm.
Here are some images to keep the build rolling....
130168130169130170130171
TheShaddix
03-30-2015, 02:28 AM
Looking great! Do you put a clear coat over the tubes or just leave as is? Also, i see you doubled up the motor mounts. I have the same mounts but worried they might be too weak. Do you double them up only to be able to fit that colored layer in between or do you do this to add strength as well?
nata2run
03-30-2015, 04:40 AM
Hi,
I don't usuall clear coat the tubes, as they come out quite clean. You could brush some epoxy on them if they needed I suppose. The double motor mounts are purely for strength, the fact that they have features cut into them is just a bonus. I would say the way I glue in the mounts hold better than a single mounts with a back support. Of cause everything is relative, but a friend hit a fence in a large 185 going 90mph and no mounts came out. If you have double mounts you should use them and support the sides of the mounts with glass or cf cloth.
Pheyd
03-30-2015, 07:55 AM
Hi,
https://www.youtube.com/watch?v=sSq5B_Q6cfw
Classic video. While seeing a boat like that crash hurts me in the feelings, the way he guy screams "SH!*" is too perfect.
nata2run
03-30-2015, 08:46 AM
Yup, that ain't good!!! NO! But that's the one I was talking about. Hurt my feelings too to see that happening. Angry sounding boat thou! I wouldn't recommend trying the same to see if mounts hold up thou. Anyway, I've been on the drawing board all night as my drawings didn't entirety fit the layout of the ESC's. They fitted but I wanted to move the ESC's in a way that I didn't have to lengthen the wires. The way it's setup now seems perfect to me. 5" or there about of wire directly from ESC to motor. Will post some pics later
nata2run
03-30-2015, 08:51 AM
this is how it looks so far
Pheyd
03-30-2015, 09:29 AM
130202 this is how it looks so far
Attachment doesn't appear to be working.
nata2run
03-30-2015, 09:57 AM
Uploaded from phone, seems to work when I click on it, hmm wired will upload from comp in the morning
Pheyd
03-30-2015, 10:11 AM
Nevermind, it works now!
nata2run
04-01-2015, 10:46 PM
Got some more work done over the past few days. As promised here are some pics of the lipo mounts. We decided to go with the Mystic theme for those since its a mystic hull, but I'm yet to do some color inlay and just smooth off the edges a bit (not that they are bad) just some tiny tiny fibers. I have also cut some stuffing tube supports (with the Mystic M logo) but they are a little too big for the very low alignment of the motors, so I have to rework them a bit. Sadly all of this takes a bit of time, specially when you have to redo a few parts. But its definitely coming together nicely.
130350130351130352130353130354
nata2run
04-06-2015, 08:18 PM
Hi all, here are some updates. It has been a busy Easter with family and WORK! but this project is really starting to come together. I got all the carbon for the project cut, but also spend some time on the drawing board making little mods here and there. Although we knew exactly what the interior was going to look like, I wanted to create some more details like little "M" logos in all the mounting posts and so on.
Here is what they look like
130537
The supports for the stuffing tube and servo horn were also modified, and some more details was put into the servo plate also.
130538130539
nata2run
04-06-2015, 08:38 PM
Getting the posts in was a real PITA, as they had to be slightly elevated (tunnel is V-shaped) but I got there in the end. The servo mount was designed to be a stand alone unit so the boat can run with minimum components, but at the same time be at the right height for the pull-pull system. The top plate is also elevated to cover the ESC's and made in 1.5mm carbon instead of 3mm. With x6 30mm oval shaped mounting plates and M4 stainless stand off's the servo mount should hold up to almost anything.
130540130541130542130543
royalcasa
04-06-2015, 08:42 PM
BRAVO you are the maestro of the orchestra. looking good
nata2run
04-06-2015, 08:47 PM
LOL thanks, that was funny!! (some wired picture came into my head when I read that LOL)
nata2run
04-06-2015, 08:56 PM
My idea of the interior was designed around something "water related" and of cause CANADA was VERY important also. For some reason octopus came into my mind so I started drawing around that idea, and this is what we ended up with. (A MYSTIC Canadian Octopus) ...or in other words, Spirit of Canada
130544130545130546130547130548
nata2run
04-06-2015, 09:08 PM
Here is the final layout before the build started. She should be a stunner!
130549
flraptor07
04-06-2015, 09:13 PM
Very cool Kent, stunning as usual! :thumbup:
nata2run
04-06-2015, 10:39 PM
Thank You, appreciate the feedback. It's been a fun project so far. It's also a very practical build and I will definitely apply some of the methods to my future builds. :smile:
Pheyd
04-08-2015, 12:27 PM
130541
Hard to tell from the picture, but how did you secure the ESCs to the mount? Looks like the mounts are holding the ESC like bookends.
She is really coming together though, looks top notch.
nata2run
04-08-2015, 07:54 PM
That's a good question. Since the smaller MGM's has no mounting holes, I figured I can attach a "U" channel from one bracket to the other, so there will be a carbon strip going across the 2 ESC's and mount onto the sides. That part is still on the drawing board but will hopefully work. Its going to be one of those PITA jobs LOL I feel it!
nata2run
04-13-2015, 12:08 AM
Hello,
Although I had my big 4'O on the weekend I still managed to get a few hours into the build. Not much to do anymore, but I managed to get the pick-ups installed (very tight fit), some carbon veneer on the motor mounts, the servo horn completed and all the standoffs to keep the plates elevated. I will get the hull to the painters in the next couple of day and in the meantime work on all the electrics...
130721130722130723130724130725
nata2run
04-13-2015, 12:09 AM
...some more pictures
130726130727130728130729
kfxguy
04-13-2015, 12:24 AM
Looking awesome as always Kent! I'm almost 2 years behind you but the big 40 is coming up fast for me! O well. Nothing we can do about it except being big kids playing with our toys! Happy late b day!
nata2run
04-13-2015, 12:46 AM
Thanks Travis! LOL very true, kids with toys. By the way, very impressive with your mono. I have one sitting around waiting for a build. How are you liking the MGM controller? getting hot or playing up in any way?
kfxguy
04-13-2015, 12:51 AM
This is my first taste of mgm and lehner and I'm hooked! Love them. The mgm runs about 105f to 115f the whole time. It's not really breaking a sweat. I love them. Building Rivercat with the same setup now. It should easily pass 100.. Thanks btw!
srislash
04-13-2015, 08:08 AM
Hello,
Although I had my big 4'O Happy belated Kent, sorry I just caught this.
nata2run
04-13-2015, 08:20 AM
Lol thanks Shawn, hope you are doing well.
Pheyd
04-13-2015, 08:31 AM
Happy Birthday Kent. Enjoy the 4-0! I'm a few years behind, hitting 35 later on in the year.
The veneer looks really sharp, these little details are really making the boat fantastic.
The pickups are certainly uber tight. I honestly didn't think you would be able to fit the pickups that far back on the hull. Looks like it was a pain.
Is the maple leaf and Mystic "M" logo on the ESC plate going to get the same red detail like the original design? or leave as is?
srislash
04-13-2015, 08:52 AM
Yup, doing great. Real busy with the pups and all but still found time to top 100mph with 'cheap Chinese equipment' lol.
Hope you had a great weekend.
Just wanted to add in case that comment on the 'products' came across as snippy that now that goal has been accomplished it is time to get going on my LMT powered HPR.
nata2run
04-13-2015, 09:43 AM
Thank you for the wishes, looks like you got some catching up to do. (5years) funny how time flys. The leaf and M is still going to be red and the mystic chrome to match all the bolts. She should look really cool once done.
nata2run
04-19-2015, 08:38 PM
Hello,
Everything is now complete and ready for the painters (she's off today) Was getting the inlays ready to glue in and also cut the tear drops for the pickups, and installed the rudder. I ordered a different pull pull system for the rudder, but didn't like the look of it and the way it grinded. Basically going back to the MHZ system with the wires coming out where the rudder attaches. Its actually a much smoother running system. By the time shes comes back from the painters, I should have all the electronics sorted.
131012131013131014
TheShaddix
04-19-2015, 11:11 PM
Hey Kent, this looks amazing! So inspiring. That water inlet is the cleanest I've ever seen, that's some skill! My question is regarding your hydraulic rudder system... How do you make sure that no water gets into the holes/tubes for the rudder cables? As far as I know, those "feet" have holes in them, then you drill similar holes in the hull, but how do you attach the tubing?
nata2run
04-20-2015, 12:59 AM
Thank you for the compliment! :)
There shouldn't be any problems with water entering the hull, as there will be 2 tubes feeding the wires and they are both above water level. The Hydraulic arms are attached by 2 screws also, and they will be sealed from the inside of the hull. I will have a look for a pic on the first build to show you how I did it.
nata2run
04-20-2015, 01:37 AM
This was sorta what I could find from the old build. Actually worked amazing with that steering. It don't look 100% scale but it don't look bad either. With a setup like this I would pick performance over looks. Regarding water tight, it was the rudder that was the trouble maker on the other build :)
131047131048131049131050131051
TheShaddix
04-20-2015, 01:52 AM
Oh wait, so those hydraulics are just dummies then and you have a secondary cable system like in that pic? If that's the case, it makes more sense now. I was wondering when the cables actually run through the hydraulic arms.
nata2run
04-20-2015, 02:13 AM
Correct! It's a very stable system that way. They have been modified by some, but I wasn't going to attempt. I just wish MHZ would make a system like HPR
nata2run
04-26-2015, 08:06 PM
All soldered up, and waiting for the hull to come back from the painters. Any day now :) Should be very exciting!
131191
Luck as a Constant
04-26-2015, 08:46 PM
damn dude, you build some killer boats.
can't wait to see this thing
nata2run
04-27-2015, 08:32 PM
Thanks dude! your mono build is awesome to BTW!!! :thumbup1:
nata2run
04-27-2015, 08:35 PM
Ok guys coming to an end... went to painters yesterday just to check, and WOW! what an amazing job. pics do no justice and the phone photos are even worse. But shes a nice deep candy red with metallic flakes "almost anodized red" . I think this is going to look awesome!! just one more clear coat and I can bring her home!
131235131236
castellina
04-27-2015, 09:16 PM
Wow this is amazing!
Pheyd
04-29-2015, 09:34 AM
That candy red is freakin sweet!
jj2003
04-29-2015, 09:56 AM
Even though I'm a Yank, I love the Canada theme! This would go great with my Canadian and USA flag's in my garage! er .... the Hockey forum I should say!
Go Hab's! 131340
Hey I'm from Buffalo and the gaybre's are out so I gotta root for someone close!
Sorry to hijack Kent! Back to your regularly scheduled program....
Pheyd
04-29-2015, 10:46 AM
Go Hab's! 131340
I'm from Toronto, whom are also out (no surprise), so I'm rooting for the Habs as well!
Tamelesstgr
04-29-2015, 12:48 PM
Amazing color!
flraptor07
04-29-2015, 12:51 PM
Hey! What about the Tampa Bay Lightning? Still in tied 3-3 with Red Wings but they gotta win tonite or it's over... BTW Beautiful color Kent, that's really gonna pop!
Pheyd
04-29-2015, 01:37 PM
I hope Detroit takes it then gets knocked out by Montreal :)
nata2run
04-29-2015, 08:52 PM
Hijackers!!! LOL
Ok got the hull home, she's quite slick. Almost impossible to get a good photo with the phone as its just too glossy and reflective. But here is what I could get out of it anyways. When done Ill take some proper shoots with the D-SLR
131367131368131369131370131371
Luck as a Constant
04-29-2015, 09:04 PM
Hot damn!!!
flraptor07
04-29-2015, 11:10 PM
Sorry Kent, gotta do it!! TAMPA BAY LIGHTNING just won 2-0!!:banana: The boat looks AWSOME as do all your builds!!:thumbup:
nata2run
04-29-2015, 11:18 PM
Thanks guys for all the nice comments!!!, and game results LOL
srislash
04-30-2015, 12:53 AM
Hey!! That is a GREAT colour and really brings the interior to life(slight Canadian bias here).
ls1fst98
04-30-2015, 05:37 PM
that color is gorgeous!!! reminds me of my camaro. lol. very nice build, makes me want to start on the c5009. i may have missed it but are those CF stuffing tubes?
nata2run
04-30-2015, 07:52 PM
They are aluminium tube wrapped in carbon cloth :-)
royalcasa
04-30-2015, 08:11 PM
Sorry Guys GO TAMPA BAY LIGHTNING great seventh game
Oh and your boat is FANTASTIC lol
nata2run
04-30-2015, 08:31 PM
Latest updates....
There will be no more boat building as I'm changing HOBBY and moving!
GO TAMPA BAY LIGHTNING LEADERS ...... LOL
131407
flraptor07
04-30-2015, 08:51 PM
Latest updates....
131407
Well if ya do move to Florida I'll give ya the grand tour..:laugh:
nata2run
05-01-2015, 12:09 AM
Tempting offer!!!!
I have temporary changed my mind, so back to building again. I got all the hardware installed back on again, and also did the tubes for the steering cables. Came out good with no paint chipping LOL, next on lipo slide system and drill the holes for water outlets.
131414131415131416131417
Shar75
05-01-2015, 01:24 AM
Great job! A masterpiece!:w00t::w00t::w00t:Thanks for the detailed photos. The existence of such carbon parts you want in your Mystic 114.
Sincerely, Alexander
spectre
05-01-2015, 08:03 AM
Latest updates....
131407
That boat is going to pop in the sun when on the water. Looks awesome. I would like join ur new hobby is there room for me, never new I enjoyed cheerleading :drool:
nata2run
05-03-2015, 09:01 AM
Always room for people who share the same hobby lol, anyway... Got a fair bit done over the weekend. Will post a bit later on
nata2run
05-03-2015, 09:14 PM
So, got the lipo tracks glued in. Not a fun part and also a bit messy. I have over time made a few tools just to be able to get it looking ok, and be able to align masking tape. Definitely the windscreen adhesive is still the way to go.
131511131512131513
nata2run
05-03-2015, 09:22 PM
Almost Done!! got the rudder pull-pull system completed. only stuff left is drill and install the water out lets, install electronics and of cause the decals.
131515131516131517131518
flraptor07
05-03-2015, 09:34 PM
131511131512131513
That windshield urethane is some nasty stuff, we use it at my shop and it gets everywhere. Most of the time it gets places and you can't figure out how it got there!! :laugh::confused1: Boat's lookin' awsome!!
nata2run
05-06-2015, 08:41 PM
So far so good! Nearly complete. time to get her in the pool on the weekend to see if water tight!
131639131640131641
flraptor07
05-06-2015, 08:51 PM
Kent, that thing is beautiful as all of your builds are! Can't wait to see it with graphics and all!!
ECSURFER84
05-06-2015, 11:34 PM
what whats going on with the underside of the keel in picture three? looks like an unfinished gap?
nata2run
05-06-2015, 11:38 PM
??? :confused1: ??? where
ECSURFER84
05-06-2015, 11:44 PM
page 1 of these posts before you painted, this pic131642
ECSURFER84
theres a gap in the transom offset, or is that just black marker?
ECSURFER84
05-06-2015, 11:51 PM
those are some beautiful builds of yours from the website. how come no monos?
nata2run
05-06-2015, 11:54 PM
oh LOL too far back, was not sure what you were referring to. What you see is sanding marks, there was a little knot/lump in the gelcoat, so I sanded it down to see if it effected the laminate. It was a gelcoat flaw only. Many of these hulls have either air pockets or other flaws in the gelcoat. Once sanded and painted its all good. :smile:
nata2run
05-07-2015, 12:00 AM
Thank you! Mono's? good question, I'm not much into monos myself and no one has ordered one yet LOL. I do have a DF I need to look into and maybe I'll pimp it up. There has been some nice monos on this forum lately so I might do one up.
ECSURFER84
05-07-2015, 12:29 AM
Id love to pimp out my spartan, however i dont feel like a plastic hull will be justifiable for pimping... it does need some serious strength added tho, ultra flemsy. Not sure what to do
ECSURFER84
05-07-2015, 12:32 AM
like you do super sexy boats, i do super sexy computers :)131659
nata2run
05-07-2015, 12:57 AM
That' SICK!! very nice and neat. Regarding your spartan, I think keep it as it is and let it be what it is. If you like monos there are some really cool boats out there from Delta Force, H&M to MHZ and HPR just to name a couple. Still lots of others!!! Of cause depending on your pocket size and interest in this hobby.
Xcesive8
05-07-2015, 02:25 AM
131639131640131641
Very Nice buddy, I still come back just to check out your builds every so often.
Love the Paint on this one!
What are the 2 holes up the front for? Cant see any stand off underneath
Ryan
nata2run
05-07-2015, 02:32 AM
HEY RYAN!! Nice to hear you still alive, we should chat some day!! 2 holes up front do have stand off's But the screws I'm using are all 50mm S/S M4 so have to grind them down. Its one of the things that are still on the "to do list" takes a little effort to do!
nata2run
05-08-2015, 09:46 AM
So I couldn't hold off.... Cut the decals and started to apply them. Had to change the layout slightly to keep letters at a descent size. But I think it looks very cool. Still some small ones to be applied.
131691131692131693131694131695
nata2run
05-08-2015, 09:53 AM
Also, changed the color from white to silver metallic to suit the paint work. Was definitely a good choice! The hatch was a pain to wrap because of the sharp curves, but I cut plenty spares lol
Pheyd
05-08-2015, 10:02 AM
Absolutely amazing work Kent. I'm pretty sure it's your best one yet!! (no bias on my part:P)
nata2run
05-08-2015, 10:24 AM
Lol, thanks for the compliment. Hard call if it's the best one, I think every boat I've done had something unique to them. I guess because of the size of this hull, it has been the hardest one yet, there is a possibility my fingers are getting bigger too and finding it hard to reach. Some elements of this boat was definitely a challenge and all mouts and templates have been completely redesigned to suit this build
ECSURFER84
05-08-2015, 11:55 AM
where do you get your decals from? id say the tag boat was the best, the one that matched the man spray bottle
nata2run
05-10-2015, 03:46 AM
Just need to drill and install the water outlets and she will be all done!... What a cool boat it worked out to be.
131747131748131749
kevinpratt823
05-10-2015, 06:15 AM
Beautiful work once again, another truly impressive build.:bowdown:
Shar75
05-11-2015, 05:51 AM
:rockon2:Really High End !!!:thumbup:
nata2run
05-17-2015, 09:24 PM
She's now completely done!!! just need to make a cool acrylic boat stand.
132132132133132134132135132136
Pheyd
05-17-2015, 09:51 PM
Amazing! Love the detail with the decals on the bottom.
nata2run
05-17-2015, 10:01 PM
Thank you, lets hope it doesn't show off the bottom decals too often LOL
Hi
i watched this building on Facebook.It is a incredible fantastic work :thumbup1:
greetings from germany
mudl
nata2run
05-20-2015, 09:18 PM
Hi
mudl
Thank you mudl, you have some amazing builds yourself.
nata2run
05-30-2015, 09:48 AM
Acrylic Stand finally done. I think it came out very cool in 10mm Acrylic. would be cool to ad an RGB LED light to light up all the details
132688132689132690132691132692
srislash
05-30-2015, 11:51 AM
Oooh, I like that stand idea Kent. Nice job buddy.
Pheyd
06-01-2015, 09:08 AM
Very nice Kent! LED idea is pretty good too. Will have to look into it.
spectre
06-01-2015, 11:19 AM
looks awesome
nata2run
06-03-2015, 12:31 AM
The boat has now been shipped to its owner, hopefully we get to see some video of her running, and some first thoughts of impression. I Would like to thank all you guys for the nice comments and watching this build, and of cause "Canadian Mike" for letting be build this boat.
Pheyd
06-16-2015, 08:18 PM
She has arrived safe and sound. The pictures don't do her justice. Absolutely fantastic build Kent. I can't thank you enough.
I will post a video of the maiden run once I get the radio system installed and programmed and then get my butt to the lake. Life is keeping me very busy but I will get to it.
nata2run
06-16-2015, 09:09 PM
My pleasure Mike, look forward to see her in action!!
Pheyd
07-15-2015, 07:40 PM
Little teaser before the maiden voyage....
https://www.youtube.com/watch?v=RZFujglLXGM
nata2run
07-15-2015, 08:58 PM
Very Cool!! whens maiden?
Pheyd
07-15-2015, 09:09 PM
This weekend is my son's 2nd birthday and we are throwing a carnival in the backyard, so it'll probably happen the following weekend.
Mxkid261
07-15-2015, 11:31 PM
This boat is unreal Im in awe Lol
Pheyd
07-26-2015, 03:54 PM
Couple photos from the maiden run.
http://i.imgur.com/NhcDM70.jpg
http://i.imgur.com/bQyuV2j.jpg
http://i.imgur.com/ng5Rc6D.jpg
http://i.imgur.com/tSNwfTn.jpg
http://i.imgur.com/U3EmdMV.jpg
and the video:
https://www.youtube.com/watch?v=uT0QppX0_2w
As you can see, it was very choppy, but I didn't want to wait. Wanted to just get her in the water for a quick test. As you can see there was some radio range issues at the very end of the video which I'll have to troubleshoot.
dmitry100
07-26-2015, 04:50 PM
Going 15 mph ... and someone says "Is that full throttle?"
:huh:
I found the dry throttle blimps of previous vid to be more exciting than that... Come on man, you have like $1k of "ferrari" motors in that thing along with a bulletproof hull! Punch it!
Pheyd
07-26-2015, 05:03 PM
:huh:
My buddy doesn't know much about r/c boats. Don't hold it against him.
This was a maiden run of a very expensive boat in choppy weather. Wasn't meant to show it off. Just a functional test. I'm not gonna push it yet and risk losing my investment. I have some things that I have to tweak. One of which is to figure out why I lost radio signal at the end of the video.
flraptor07
07-26-2015, 05:47 PM
I had the same problem with Spektrum radios in a couple different boats, put my Futaba in the same boats and never had a problem.
dmitry100
07-26-2015, 06:02 PM
Lol i know, it just made me crack up.
Expensive yea but the hull was made to withstand high speed crashes... Kevlar inlay there after all ;)
Is the water always this choppy a lot of the time or is it just lately? Is this saltwater or fresh?
nata2run: Does that thicker teflon help with the smoothness of those drives?
Pheyd
07-26-2015, 06:06 PM
I'll get it up to higher speeds, don't you worry!!
Fresh water lake. And no, it's not always this choppy. Just one of those days. Even on most days, at dawn and dusk its always calm. I just took it out in the middle of the day when I had some spare time.
littlepooper206
08-07-2015, 01:55 PM
What happened in the video you posted with comment of "Fire!" ???? Did you figure out what caused that misfortune because obviously that is not a good sign sadly to say :( i really hope you can fix it ! That boat is killer and would love to see some fast videos to come
Pheyd
08-07-2015, 02:13 PM
Motor was sent back to LMT to be investigated. Waiting on the results and replacement. I'll get more videos up once she's back in the water.
golfito
10-01-2016, 08:05 PM
Totalmente impresionante!
nata2run
10-03-2016, 06:11 AM
Thank you
Pheyd
10-08-2016, 10:27 PM
I still have yet to take her to full speed, but it will be documented when it happens. For now, she's sitting gorgeous in my man cave now that winter is approaching once again.
