View Full Version : Hpr 150
hanspeter
02-24-2015, 09:39 AM
hello
here a small build process from my HPR 150. i will make the old good victory.
hull is bullet proof ultimate.
greetz hanspeter
hanspeter
02-24-2015, 09:44 AM
Mounts from the waterp pickups drives rudder
hanspeter
02-24-2015, 09:54 AM
drives an rudder
ls1fst98
02-24-2015, 06:57 PM
Very nice!!
Fella1340
02-26-2015, 01:13 PM
You never disappoint! Really looking forward to seeing what happens here. I'm curious about the drill and solid rod going into the drives, I had written a few guesses from lapping the bushings(if bushings are used), seating and running in bearnings and also it being a special tool for drilling into the hull for stuffing tube arrangement. None seemed to quite fit. What's going on there:-)!
hanspeter
02-27-2015, 01:51 AM
hi
this is a Special tool for Drilling the hole for the Flex and shaft tube. the drive is mountet in the optimal Position.
so i have the propshaft and the Flex 100% in the centrum
greetz hanspeter
Fella1340
02-28-2015, 05:28 PM
Very good idea, takes any guess work out of things that's for sure. That's the type of stuff I love seeing in the high end builds. It really helps us newer builders become better. Thanks
TheShaddix
02-28-2015, 06:26 PM
How does this tool work? Seems like a great idea to make that perfect angle from drive to stuffing tube entry point.
flraptor07
02-28-2015, 07:14 PM
It's probably a long drill bit.
TheShaddix
02-28-2015, 09:17 PM
maybe some kind of a tube that holds a drill bit? Hanspeter can shine a light on this mystery!
Fella1340
03-01-2015, 02:08 PM
It would be a piece of precision ground shafting or tube the same size as the inside diameter of the bearings with a drill machined to fit the end. Nothing fancy but a really great idea. Every little bit helps getting things to run as true as possible.
hanspeter
03-15-2015, 12:07 PM
hello
thank you. the next step is the mounting from the engines. i have make a Special
Support,and build this out from the boat. so i can make this 100% exact.
greetz hanspeter
srislash
03-15-2015, 02:18 PM
hello
greetz hanspeter
Ahha, the flexible tubing for the stuffing tube. That is what I have been watching for. Where did you find that Hanspeter? I have been watching for old oil cans but that looks new. I have had thoughts of it for my HPR 115
Shawn
