View Full Version : Details: AquaCraft Miss Seattle U-16 2.4GHz RTR
Diegoboy
01-24-2015, 01:28 PM
http://www.aquacraftmodels.com/boats/aqub1822-miss-seattle/aqub1822-main.jpg
Unlimited Racing Excitement!
The thunder, the roar, the solid wall of water as the boats tear past, skimming just above the surface. It's not hard to see why people love Unlimited Hydroplane Racing. With the U-16 Miss Seattle RTR Brushless Hydroplane, you can bring that excitement to a lake or pond near you! It arrives pre-assembled, loaded with a powerful brushless motor, equipped with a kick-back rudder safety system and totally ready to kick up some spray!
This boat shares many parts with the GP-1 by AquaCraft
FEATURES:
New Tactic TTX300 2.4GHz transmitter with lightweight TR325 receiver.
2200kv brushless in-runner motor with aluminum water jacket.
LiPo-ready (3S) 30 Amp brushless water-cooled motor controller with low battery warning system and battery cut off circuit.
Tough, light-weight ABS construction with square hatch opening for easy taping.
Great-looking, pre-applied Miss Seattle graphics.
Adjustable strut
Music-wire drive shaft
Pinch wire motor coupler
Break-away wedge rudder
One-piece aluminum turn fin
1/8" [3.2mm] prop shaft
Two blade 30mm FRP propeller
Transom drain plug
SPECIFICATIONS:
Stock Number: AQUB1822
Hull length: 16.75 in (425 mm)
Overall length: 18 in (458 mm)
Width: 8.5 in (216 mm)
Height: 4 in (102 mm)
Weight: 17.1 oz (485 g)
RTR requires: 11.1V 1000mAh LiPo battery, charger, safe charge sack & 4 "AA" batteries
MOTOR SPECS:
KV rating: 2200kV @ 11.1V
Operating current: 1.4A, 8V/DC (without loading)
Input: 8 to 14V
Max current: 28A/15 Seconds
Shaft diameter: 3.2 mm (1/8")
Motor resistance: 50 m
Dimensions: 27.5 × 30mm (1.1" × 1.2")
Weight: 71 grams (2.5 oz)
ESC SPECS:
Rated Current: 30 amp
Battery Connector: Deans® Ultra Plug ®
Motor Connector: 3.5 mm Bullet Plugs
Wire Gauge: 14G
Warning System: 9.6V Stutter Bump
LVC: 9V
BEC Max Current: 2A
PWM: 8K
Dimensions: 1.8" × 0.9" × 0.4" (45 mm × 24 mm × 9 mm)
Manual PDF (http://manuals.hobbico.com/aqu/aqub1822-manual.pdf)
http://www.aquacraftmodels.com/boats/aqub1822-miss-seattle/aqub1822-gallery1-lg.jpg
http://www.aquacraftmodels.com/boats/aqub1822-miss-seattle/aqub1822-gallery5-lg.jpg
http://www.aquacraftmodels.com/boats/aqub1822-miss-seattle/aqub1822-gallery7-lg.jpg
http://www.aquacraftmodels.com/boats/aqub1822-miss-seattle/aqub1822-gallery9-lg.jpg
http://www.aquacraftmodels.com/boats/aqub1822-miss-seattle/aqub1822-gallery10-lg.jpg
VIDEO:
https://www.youtube.com/watch?v=t8lNk6RNgKM
