Aclinml
02-04-2015, 03:53 PM
In looking over my new (but used) Revolt I noticed a couple of things about the rudder. Part of the way up the rudder, there is a 'ding' that looks like a rock hit it head on at some decent amount of speed. As far as the rudder itself goes, it looks like a little filing on both sides will clean most of it up. However, when I hold onto the bottom of the rudder I can move it back and forth about 2MM. I'm not talking about 'play' in the rudder direction left or right. I'm saying that if i grab the rudder with my thumb and forefinger, on each side of the rudder, there is a little 'play' in it. Like it is a little loose in hinge area. This is my first 'hobby grade' boat and I'm not sure how much play is normal?
2nd question.......I saw a post where someone mentioned that the rudder assemble has a nylon bolt or rod that was supposed to shear off in the event of a hard strike on the rudder. He said that it was too strong, and that it might be wise to 'pre cut' about 75% of the way through it to make it actually function properly. What are your opinions on this , and how do I access this bolt or rod?
Thanks guys,
Mike
Thanks guys,
Mike
