View Full Version : SC33 cut down to 27 inches
RandyatBBY
01-28-2015, 10:31 AM
This boat is to run in the P LTD Offshore class. I will be running a Old Pro Boat 1500 motor UL-1 ESC and BBY Hardware. I was thinking about running the Scat Cat 33 in this class but wanted to try a shorter wider boat so I made this one. I will add more info as I get ti going.
http://imagizer.imageshack.us/v2/640x480q90/537/OmptCd.jpg (https://imageshack.com/i/exOmptCdj)
http://imagizer.imageshack.us/v2/640x480q90/631/o2RsJI.jpg (https://imageshack.com/i/hjo2RsJIj)
http://imagizer.imageshack.us/v2/640x480q90/905/e2KqbZ.jpg (https://imageshack.com/i/p5e2KqbZj)
RandyatBBY
01-28-2015, 10:36 AM
http://imagizer.imageshack.us/v2/640x480q90/540/RppgVD.jpg (https://imageshack.com/i/f0RppgVDj)
Shooter
01-28-2015, 07:53 PM
That is really cool Randy!! How do you glue the deck to the hull?
ray schrauwen
01-28-2015, 11:53 PM
Now that's awesome! A cat that can run in a plethora of classes! N2 to P-spec... etc...
RandyatBBY
01-29-2015, 12:31 PM
Same as all composite builds, sand the inside, tape outside next to seam, mix epoxy with cab-o-seal and milled fibers and apply.
RandyatBBY
01-29-2015, 12:35 PM
Well the hull will need to be cut to fit in the NAMBA N2 rules, this one is too big 27.5 sponson size and over all this hull is 29 inches.
ray schrauwen
01-29-2015, 03:54 PM
Oh shoot. O.k. Still is killer! Loving it.
RandyatBBY
01-30-2015, 12:23 AM
The Scat Cat 26 is or can be correct for N2.
http://imagizer.imageshack.us/v2/640x480q90/122/img1227lt4.jpg (https://imageshack.com/i/3eimg1227lt4j)
I do not build the rudder bracket that long any more but this is the rear view
http://imagizer.imageshack.us/v2/640x480q90/122/img1226od4.jpg (https://imageshack.com/i/3eimg1226od4j)
This is how you get the bottom parallel.
http://imagizer.imageshack.us/v2/640x480q90/905/d8YcxE.jpg (https://imageshack.com/i/p5d8YcxEj)
RandyatBBY
02-20-2015, 12:34 PM
Boat is built and ready for testing Sunday.
http://imagizer.imageshack.us/v2/640x480q90/538/H4ASEU.jpg (https://imageshack.com/i/eyH4ASEUj)
http://imagizer.imageshack.us/v2/640x480q90/661/tyIHHj.jpg (https://imageshack.com/i/idtyIHHjj)
http://imagizer.imageshack.us/v2/640x480q90/673/ofPySX.jpg (https://imageshack.com/i/ipofPySXj)
RandyatBBY
03-16-2015, 12:53 AM
I did a mach race today and win the race. boat is awe some ! I raced three Pro Boats and beat them all with my slower boat, look out when I get op to speed!
