View Full Version : ESC waterproofing gel??
Sykojsy
09-14-2008, 06:38 AM
Hi Guys,
I've been hunting around and can't find what this is called, or even where i can get some! Any help would be good!
The gel coating is starting to come off my Etti ESC and i don't want to get a new one just cause of that, if i can repair it with some gel, great. Was also thinking of maybe using it on the circuit board of a receiver?
All help much appreciated!
Jez
lonewolf
09-14-2008, 09:11 AM
The most common is dp 270 which is avail here under water proofing and hatchtape...
Sykojsy
09-14-2008, 05:35 PM
Thanks Lonewolf, do you know if this goes solid or stays as a gel? Like what is originally used on the Etti ESC's.
lonewolf
09-14-2008, 05:37 PM
it gets hard. I am not sure of what is used on etti esc's but I do know that the dp270 works well...
ED66677
09-15-2008, 09:52 AM
silicon sealant?
09-15-2008, 09:57 AM
Its a gel? I would be cautious on using the dp270 on that esc. You are going to have to somehow remove all the gel first.
lonewolf
09-15-2008, 11:07 AM
Good point Steven Corrosion x might be a better method???? Unless you can remove all the old coating...
Sykojsy
09-15-2008, 02:06 PM
Thought about the silicon sealant, but been told it won't stick well once the esc warms up a bit.
Yeah, the Etti has a gel coating under the heat shrink but that came off after it was used a few times (heat shrink that is). Corrosion X is just an inhibitant....not a sealant so i'll guess i'll have to remove the old gel and try with the Dp270.....try it on a cheap ESC first!!!
ED66677
09-15-2008, 02:26 PM
sorry to say that but this is not thrue! all my ESC's are moded with silicone sealant! and mines are "coated" so that the silicon make a kind of shell all around the ESC and also glue and holds the cooling plate in place!
basic silicon sealant will resist at least to 200°C (400°F)
the Etti has a gel coating under the heat shrink heat transfert compound, for better heat transfert from MOSFet's to heat sink!
if you have access to, conformal coating material are better, few of them are acrylic, lot of them are silicon based and most of them are polyurethane.
Sykojsy
09-15-2008, 02:47 PM
Ok, maybe thats the cheaper way to go then!!! I'll have a go with silicon sealant, thanks. The guy that told me works with sealants too......oh well!
Think you misunderstood the 2nd bit you quoted....i meant under the heat shrink (the shrinking plastic that goes around the batteries too, easiest way to explain it!!) the circuit board is covered in gel. The heat sink, is still well stuck to the circuit board!
ED66677
09-15-2008, 04:32 PM
Think you misunderstood YEAH! you know I'm french and sometime understand after reading and reading again!!! They may have injected the silicon in the shrink tube while in place on the ESC??? This kind of encapsulation was commonly used before conformal coating material were designed!
Sykojsy
09-16-2008, 03:58 PM
I'm the same Ed.....as a matter of fact...we are actually quite close....as I'm from Jersey! But saying that....do they do that heat transfer compound on here? Could do with some....
ED66677
09-16-2008, 04:30 PM
you can get some heat sink compound from RS components (http://uk.rs-online.com) p/n is 554-311, 20ml tube for £3.23 and that's the one I'm using!
NorthernBoater
09-16-2008, 08:13 PM
Keep an eye on this product. It would be awesome if we could get our ESCs coated with this stuff.
http://golden-shellback.com/
ED66677
09-17-2008, 01:38 AM
This product must cost a fortune, coating inside and outside of electronic devices whaou!
But I beleive the application process cannot be done without specific equipements, not at home!
We don't really need this stuff for our ESC, just a spray of Humiseal 1A33 and the job is done! I have a 1liter thin at home, it's the best, used in automotive, military certified... bad thing : contains VOCs!
Ub Hauled
09-17-2008, 03:52 AM
Jez,
CC uses "silicone conformal coating (http://www.mgchemicals.com/products/422a.html)" by MG Chemicals.
ED66677
09-17-2008, 04:00 AM
CC uses "silicone conformal coating" by MG Chemicals certainly a good product too if CC choosed it! I've used many different materials when I was in the conformal coating business but not that one.
Sykojsy
09-18-2008, 03:44 AM
Thanks for all the help guys.....That shellback stuff would be the mutts nuts if it can be done at home! Well, I've decided to get some of the DP270 and the CC spray stuff that Ub Hauled said.....i'll let you all know how it works out! But i'm also going to use Silicon for all the receivers i got.....
tylerm
09-18-2008, 05:34 AM
Use DP270 for the recievers, its the shiz and you dont use much doing a reciever.
Tyler.
Sykojsy
09-18-2008, 03:34 PM
Use DP270 for the receivers, its the shiz and you dont use much doing a receiver.
Tyler.
Cool......got quite a few to do that's why i thought using the silicone would be cheaper.....but if not much is used, then that's good enough for me! Thx:smile:
tylerm
09-18-2008, 04:11 PM
heres a good howto
http://offshoreelectrics.com/info-pages/waterproof-rx.php
Once youve coated it you can hit it with a hair dryer which will thin it out, and help the excess drip off.
Tyler.
Sykojsy
09-18-2008, 04:19 PM
Cheers. Saw that the other day after it was mentioned....just sorting an order now with a few other guys from the club!
SweetAccord
09-22-2008, 03:02 PM
http://forums.offshoreelectrics.com/showthread.php?t=5008
ED66677
09-23-2008, 10:20 AM
good description SweetAccord!
SweetAccord
09-23-2008, 04:04 PM
Thank you!
