View Full Version : Expectations 1/8 scale hydro electric conversion
PJBJ
01-03-2015, 03:29 PM
Years ago I built a dumas model of the 1/8 scale miller hydro with solid shaft. I fitted a 15 cc K&B engine and looked at it for some years (I am a builder) without getting the boat wet. Finally I decided to convert the boat to electric (on a budget) in such a way that I can change back to the K&B engine setup. I purchased the following setup: Aquastar 4084 1050 KV motor and Turnigy 180 Amp ESC with a 55mm diameter prop. The space in the fuel tank compartment is limited and I now have a Roxxy 6s 3300 Mah 25C continuous discharge rate fitted in. Burst rate for approx. 10 sec. is 50c which gives me 165 Amps. I realize that the lipo could be stronger but this is what I have. Total weight 6 kg. I do not plan to race but would like to give the boat a try on a nice day and maybe push the throttle for a couple of seconds just to see what it does. I am curious what the more experienced rc boaters will respond regarding my expectations of this setup.
Doby
01-03-2015, 04:24 PM
Where to start......
Those old Dumas hulls are porky and need a lot of power to run them.
Your motor is physically to small, KV to low...about 22,000 RPM unloaded.
Lipo C rating and capacity are insufficient (assuming a 1P configuration)....burst rate is useless to try and figure out average current draw. Current draw is more based on motor kv, voltage, prop and hull type, weight, overall setup. I doubt that weak of a Lipo would even plane it and if it did, would be dead in about a minute.
ESC , while those are good ESC's in the right boat, a 1/8th scale on 6S will probably destroy it...especially with a 55mm prop(to big).
Big boats and "on a budget" are never very successful.
If you are determined to stay with those components, then keep it nitro.
monojeff
01-03-2015, 05:18 PM
I know that some guys out here had great success with scorpion out runners in 1/8 scale boats.
I don't know the exact motor they used but it was not that expensive from what I remember.
Believe a record or two was set with that out runner and it didn't break the bank to make it happen.
If interested I could probably find out the motor and esc that was used.
JimClark
01-03-2015, 05:50 PM
I think they were running 10s lipos also
PJBJ
01-03-2015, 06:02 PM
Thanks for the info Doby. Out of the water the setup sounds great! I do not want to use the K&B so I am going to give it a try in the pond starting out slow and getting it back quick to feel the components.
If you have any suggestions on how you would proceed with this setup and getting better stuff I am looking forward to your view on this.
Thanks also monojeff and I am always interested. The motor mount I have made limits bigger motors than the one I am using now (40mm + water-cooling).
monojeff
01-03-2015, 06:15 PM
Here is a link to the page that talks about the boat.
http://forums.offshoreelectrics.com/showthread.php?30039-NAMBA-District-8-Puget-Sound-Model-Boat-Club-hosts-2-Lap-Time-Trial-at-Lake-Waughop
Here is the setup.
Qty-2 Gens Ace 4S 5300 packs in series driving a Scorpion HK435 800 Kv motor through a water cooled ICE 200 lite ESC.
Looks like it was 8s
01-03-2015, 06:35 PM
What are your expectations for the boat? The others have given you opionions on what you should change to make it a success. But I believe you asked what we expected to happen using what you have, not what you should change....
Chances are are very good that the boat will not plane out from a stop, especially with the solid shaft drive and unknown center of gravity. Hydros require a lot of things to be near perfect to run right...CG, total weight, prop depth and angle, prop lift, etc. Too, these boats were designed to be launched with a toss, so by all means do that. The prop size and motor Kv are fine for this size hull, but the motor size is small and efficiency will be low. 6s is low power for this boat, and while it can be made to work, the low capacity of your pack will not allow it. With luck you may get to see it plane for your "couple of seconds" with a toss launch, but not for long. The desire to see it run will demand you to hold the throttle down, which will result in a burn-down. Good luck with that.
There are many ways to get where you want but you will need different components.....the Scorpion is no longer available so you can't go the out runner route. But you don't have to.....
PJBJ
01-03-2015, 07:43 PM
Had a look at the site where a Scorpion HK435 800 Kv motor was used on 8s and a water cooled ICE 200 lite ESC. I think this is the Scorpion HK4035 800 Kv which has a power output of 4200 Watts and is still available where my Aquastar has 3100 Watts. This out runner with outside diameter of 48.9 mm is about 35% stronger and could fit in my engine compartment. Something for me to consider together with getting a 8s lipo and charger for this lipo (current charger goes to 6s and so does my ESC so have to change this too). Fluid: My expectations now are that the boat will get out of the water but it will lack runtime. With a better 6s lipo however I think I could have a nice run.
Nice pictures on your site Jim Clark!
monojeff
01-03-2015, 08:16 PM
You do not need 8s batteries.
You would need 2 4s batteries
Lots of people like the T180 esc so would not be difficult to sell
You could also sell the other stuff and get some extra $ if you decide to change things.
Better to sell good newer parts then try to sell burned up stuff because the setup wasn't right.
PJBJ
01-04-2015, 12:18 PM
Thanks for the input monojeff. The only thing I have not figured out apart from the approach of getting the scorpion out runner and a suitable esc is the battery. The lipo has to fit in the front where the nitro tank used to be. This means that I either have to remove the motor (with esc fitted on top) to change the lipo or work with one lipo charging it in the boat. I have no problem with this because I only want to run the boat occasionally. Using 2 4s lipo's will be difficult because I don't see how to reach the balancing pin for charging the lipo in the front of the nose. Any thoughts on this would be appreciated.
01-04-2015, 03:55 PM
If you can find a Scorpion HK4035/800 buy it, these have been out of production for well over a year. I ran one in a 10S catamaran and it performed well but these motors do not like high amps, especially since they can't be effectively water cooled. Keeping runs short helps. They run well on 8S too and will swing bigger props.
Do not be fooled by a motor's rated "power output", that is almost always misleading. The Scorpion is actually rated at 100 amps maximum, but on 8S 4200 watts is about 140 amps. For short runs it will work. The real advantage of the big outrunner over an inrunner is the greater torque of the former to spin larger, more efficient props. Your big heavy hydro will need that.
Some battery sellers can supply balance plug extensions for your 4S packs. I usually charge in the boat with no ill effects after over seven years of doing it...
PJBJ
01-05-2015, 01:59 PM
Expectations have changed and the boat will not run with the current setup.126365
Thanks to the recommendations from more experienced r/c boaters I decided to change the setup. Scorpion HK4035/800 is on its way and because I got a good deal on the motor I decided to break the bank on the ESC and ordered a Castle creations Hydra ICE 240 XL. Looking forward to the data logging option. Now I have to wait...
Make-a-Wake
01-05-2015, 03:18 PM
I ran a Castle 2028 in my 1/8 (50") Hydro on 9s2p and got 60mph out of it, its a solid setup.
PJBJ
01-09-2015, 12:00 PM
126557
Motor arrived. Waiting for ESC.
SJFE
01-09-2015, 12:15 PM
You're not screwing around with that motor mount are ya...
Make-a-Wake
01-09-2015, 12:20 PM
126557
You gonna have any cooling for it.......................a plate?
SJFE
01-09-2015, 12:26 PM
I'd say that big hunk of metal its bolted to will be a pretty good heatsink.
T.S.Davis
01-09-2015, 01:04 PM
I can't vouch for them being equal to the Scorpion quality but Hyperian sells a very similar motor if anyone else is looking for one.
http://www.nationalhobbies.com/hyperion-hs4035-0800-kv-high-rpm-outrunner-motor-p-6239.html
Ronbo
01-09-2015, 03:20 PM
Scorpion makes the motor for Hyperion to rebrand.
01-09-2015, 03:22 PM
I've had one for about a year Terry, although I didn't pay nearly that much for it. Scorpion made them for Hyperion - it's performance is very close to the Scorpion I had (logged and GPS). Not nearly as pretty though. Both are strong motors.
T.S.Davis
01-09-2015, 03:33 PM
Makes sense that it's a Scorpion.
Check out this price!
http://www.empirerc.com/hyperion-hs4035-0800-kv-high-rpm-outrunner-motor-p-4577.html
Namba328
01-09-2015, 05:40 PM
Just got one !!
Make-a-Wake
01-09-2015, 07:27 PM
I actually meant a cooling plate, with waterflow...........the kind that mounts between the motor and mount.
01-09-2015, 08:30 PM
Wow, that is low. I wonder if thees motors will ever be available since Scorpion is no longer making that version....my guess is the low price is for clearance to get rid of inventory of a discontinued product.
PJBJ
01-13-2015, 12:52 PM
Would be nice to cool the mount in the area where it is bolted to the motor but I will try first using without. If I burn up the motor I will take the route with a quality water-cooled inrunner.
The specs of the Scorpion state: ...stators are wound with wire that is rated at 180 degrees C (356 F). The magnets are rated for operation at 200 degrees C (392 F), making a motor that is virtually impossible to burn up in normal use...
PJBJ
01-17-2015, 04:04 PM
I'm more worried about water getting into the motor/ESC compartment. There is a gap between the hull and the cowl which I tried to minimize using a rubber strip. Hopefully you can get an idea from the pictures I made in the dark. I am not happy with this solution and some input would be appreciated very much.
After doing some reading on waterproofing I came up with the idea to tape transparent plastic over the engine compartment and place the hatch over it. This will do the trick.
127048
I also think this has nothing to do with scale hydroplane FE talk. Sorry...
PJBJ
01-24-2015, 06:17 PM
Found a seller for a water-cooled Scorpion HK 4035 but with a little higher Kv-value
http://www.mhz-powerboats.com/E---Motoren/Scorpion-Motoren/MHZ---Scorpion-Motor-HK-4035-1260.html?XTCsid=d66ae1d80d1034e8443ced06de508d6f
PJBJ
05-30-2016, 02:02 PM
I finally tested the boat with a 2 blade 55 mm prop and it went nose down and the prop seems way to small for this heavy boat. I now managed to move back the batteries some and I added some adjustable weight in the back to find the best balance. Now I would like to try and see if the boats comes out of the water with a Prather S265 prop I have without damaging the electronics. Possible??
PJBJ
06-28-2016, 06:42 PM
:confused2:can not get the boat on plane. dumas 1/8 hydro solid shaft 15lbs ready 8S outrunner 4035 800Kv ESC 240 Amp. boat goes under. tried moving batteries front to back and different prop diameter 65 and 57 with some more pitch. Had it on plane before 1 time with big prop, batteries in front and a lot of lead on the rear wing which blew of during that run. after this lot of water in the boat which killed the ESC. Now the boat with new ESC and battery in the back does not come out and went under water akula style :ohmy: > 10 m. I think the prop is to shallow to grip. hull on the wall?
JimClark
06-28-2016, 06:50 PM
can you adjust strut?
06-28-2016, 07:22 PM
Exactly what props have been used? If they are lifting props then the problem may be the prop forcing the bow down. Jim is right, the prop angle may be part of the problem since an angled prop will lift the transom as the boat accelerates. 10S or 8S? Makes a difference on prop choice. The big Scorpion HK4035/800 pushed my 22 lb cat just fine on 10S.
Too, the Dumas hydros were not the best designs and are designed to be toss-launched. This technique could help the OP get the boat on plane.
PJBJ
06-29-2016, 07:52 AM
Can not adjust strut (or remove solid shaft, adjust motor angle, build in flex with strut)
Props used S-265 2.61"/4.0" and 1657/1.6 lifting props? 8S. conclusion solid shaft with dumas hull does not work?
No like handtoss. considering building new wood 1/8 hydro. info on good running hull appreciated. thanks
JimClark
06-29-2016, 10:57 AM
Can you post a picture that shows the strut and shaft.
Sent from my SM-G900T using Tapatalk
PJBJ
06-29-2016, 01:02 PM
144222
added spacers
144223
prop now half inch further back and behind transom.
thanks
JimClark
06-29-2016, 01:16 PM
is that the prop you were using?
PJBJ
06-29-2016, 01:54 PM
last run: the prop on the picture above made the boat go under.
with lipo's in the back, the boat does not plane nicely.
144224
before: 1 time out of the water and on plane.
with lipo's in front and weight in the rear.
PJBJ
06-29-2016, 01:59 PM
144225
prather S-265
PJBJ
02-02-2021, 05:35 PM
Found myself again on this internet because I am building a small roundnose hydro which was lying in the cupboard for some years. Sold the Dumas boat. It never ran the way it should.
I remember one time with full throttle it went under water like a sub and I could see it go for 10 meters or so. Now I will try again with what I have lying around and hopefully make it work. I enjoy wooden boat building because the wood is of a higher quality than balsa in planes. I now have a Osborne models kit 1/12 scale hydro and I need to make the best of it using a solid shaft. I think this tread can be deleted. Bye
