Lucas Oil strut adjustment & Skeg
  • boatracr157
    • Aug 2012
    • 6
    My new Lucas Oil Cat, out of the box, had the strut set so the back of strut was a fraction below sponsons with about .0025" negative angle at the front of the strut. That seemed like it was very deep with a lot of negative trim. I've was told that about 1/16" above bottom was good place to start & I could go as high as 1/8' above with a little negative angle (about .0010) at the front of the strut.
    1- Is that good advice?
    2- Any input on running a strut with a small skeg?
    I just tuned up the bottom. I haven't had the boat to the water yet, still waiting for props.
    The boat will be run in P-LTD. Cat on 4s.
    Thanks, Jim
  • Luck as a Constant
    Make Total Destroy
    • Mar 2014
    • 1952
    Yeah raise the strut up to at least 1/8
    • BHChieftain
      Fast Electric Addict
      • 1969
      Hi,
      I have a setup guide for the Lucas Oil that covers setup, maintenance, upgrade options, prop selection, and a bunch of useful links, if you'd like a copy shoot me an email at [email protected].
      Chief
